Question about York Yankees Bedding MLB Comforter
York high effenciency furnace not firing all the time
I have a York high efficiency furnace that is not firing all the the time. The unit is about 4 to 5 years old & has been doing this for a few months now and getting progressively worse. (model # GM9S08B12DH11G) The trouble code light inside is blinking a rapid red, indicating a Twinning Error, Incorrect 24V Phasing.
    Sergeant:
  • 359 Answers
Has anyone worked on this furnace because the error would indicate that the positive 120 volt and the neg 120 volt is swapped , these units will also do this when the ground wire to the furnace or gas valve or furnace or @ the panel is lose , corroded , or missing , the gnd must be present to open valve , I am aware that ac is is not usually polarity sensitive but in this case it most certainly is ...have seen many time and know it to be true
Posted on Jan 01, 2009
Tip
2 Stage Furnaces More Comfort and Save Money
Two stage hot air furnaces can save you money and make your high efficiency furnace even better. With your furnace running at low fire instead of cranking up to the highest heating output in mild weather you can be more comfortable while saving money.
Many people think that they are getting the best they can get by buying a high efficiency single stage furnace. What they often don’t realize is that they could do better yet and for a few dollars more have a high efficiency 2 stage furnace that could keep them much more comfortable.
There are 2 stage hot air furnaces that are now available that will only run at half fire if the full fire is not needed. With a two stage furnace in mild weather when only a little bit of heat is needed, the furnace will have longer run times on low fire. This will keep you room temperatures from getting too hot before the thermostat reacts and shuts the furnace off again. This will help to keep your temperatures from overshooting the set point and help to keep your home much more comfortable.
Many of these two stage furnaces also have variable speed blowers that run at a lower speed when heating on low fire. This will also help to save money on your electric bill, because these blowers use very little electric when running at these low speeds. Air noise from the blower running at a high speed is also reduced.
If you are thinking of replacing or installing a hot air furnace, make sure that you ask your contractor to give you a price on installing a two stage furnace. The price difference probably will not be much higher than a high efficiency single stage furnace. However the comfort of the two stage furnace coupled with the electric savings will make the extra money well worth it.
on Dec 14, 2009 | Heating & Cooling
My Xenon high efficiency furnace has a red blinking led light that blinks 4 times and my furnace will not light. What could be the problem?
Gas furnace fault or error codes for common furnaces - Gray ...
www.grayfurnaceman.com/-ifc-failure-codes.html
Each color will also flash a specific number of times to signify a specific error. ... 4 redcolored flashes may be signaling that the "high-limit" switch might be open. ... 3 green colored flashes on your furnace has the same meaning as 2 green colored flashes. ....If a system problem occurs, a blinking LED shows a fault code.Missing: xenon
7 Tips and Tricks to repair your Furnace DIY - YouTube
? 13:25
https://www.youtube.com/watch?v=rAtcvPqUsBA
Dec 18, 2012 - Uploaded by JRESHOW .
Flash sequence codes 1 through 11 are as follows: LED will turn "on" ... 4 RED FLASHES: This indicates that the main limit switchhas opened ... This no-light condition occurred 3 times (2 retries) during .... My furnace trane xe80 is only flashing once my manual says something about flame being locked out ...Missing: xenon ‎efficiency
Nov 21, 2015 | Heating & Cooling
Is there a high effecency furnace substitute?
small dual gas turbine and use electric heating and supplies your home also ....
Apr 19, 2015 | York Furnace Draft Inducer Blower Fasco #...
The furnace fires up 9 out of 10 no problem. when it doesn't for the pilot lights up for a second then cuts out. There is a click every time and it will continue to do this till it finally fires up....
I can't tell by the picture your showing if it's a mid efficiency or the pilot stand by if it's mid efficiency furnace then there's a reset button if the other it sounds like your high and low limit switches are not in sink to each other ,should be able to find out how to set on the internet if not that then check your thermostat
Feb 12, 2015 | Heating & Cooling
Anyone know about high efficiency furnace?
There is a lot of calculations involved in this. You need to know the sqaure footage of living space, the R value of the insulation, the construction type, size and number of windows etc.
Jan 20, 2014 | Coleman Gas Fired Condensing / High...
York diamond 90 furnace burners won't ignite ... igniter glows for a few seconds then clicks off, no burner ignition. Tried resetting the furnace by powering off and then setting thermostat to call for...
The thermocouple could be defective. If this is a high efficiency York furnace, the stack blower should start and run first. If it doesn't the blower controller may have failed.
Dec 06, 2013 | Heating & Cooling
I have a Honeywell programmable thermostat with a York high efficiency furnace. To turn the heat on, the thermostat "clicks" and cycles the furnace through startup (warm the fire starter, turn on gas,...
Well, it is a computer, and they all glitch, now & then, you say it clears with a power off, and thus resets it, It maybe a thermostat, flaking out, they do that, but the 6'o'clock, thing being the "Or" that sets it apart, I wonder if it isn't just a faulty control unit, as two together is too many, for a single cause, now, it sort of points there, but also, may sound silly but first, of there is any, Check your backup battery..
Feb 26, 2010 | Honeywell Programmable Thermostat Heater
I have a direct vent hi efficiency furnace. All
Check the condensate pump if it is full of water and does not come on that will shut the unit down. And might need a new pump. high efficiency furnaces condensate to squeeze the last amount of heat out of the unit. Seen this problem before. But not being there is a little chance that, that is the problem. let me know and we can go from there. okay ken
Jan 03, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
York Yankees Bedding MLB Comforter Logo
867 people viewed this question
Top York Sport & Outdoor - Others Experts
Paul Carew
Shehu Pro
Shehu Pro
ray gallant
Are you a York Sport and Outdoor - Other Expert? Answer questions, earn points and help others
