Question about GE 30 in. JP340 Electric Cooktop
My ge ceramic cooktop hot indicator light won't go out
I have a ceramic cooktop, it is a downdraft type. About 2-3 years old. The hot indicator light will not shut off. I've tripped the breaker and checked the connections. Nothing seems to work.
  • Anonymous Apr 07, 2009
    i have the same problem, it's really annoying. Does anyone know the answer??
I know that some people have mentioned that it looks like it's on, even when it's off. Depending on how the light hits it, it can look like it's glowing a bit. This would be normal.
Posted on Apr 01, 2009
  • soniasteve Aug 06, 2010
    are you kidding me? how stupid do you think we are. when it's night and completely dark in the kitchen, guess what? we can tell that the indicator is glowing bright red, duh!
How do i fix a squeaky control knob on a ge downdraft cooktop?
silicone spray works wonders !!!! and most silicone's are food safe too (look 4 it on label) so its safe to use around food prep area's, it however does not taste 2 good to the human palate so use sparely
Jan 05, 2016 | General Electric PP989TNWW GE Profile 30"...
The unit light (not the hot surface indicator light) in my GE Profile ceramic cooktop does not turn off although the burners are off.
Hi Danielle, I reviewed the manual for the GE JP350 cook top. Pg. 6 states:
"The UNIT ON indicator light will glow when any surface unit is on."
If the burners are all set fully to the Off position, this lamp should be off. The off position requires that the knob be pressed in to change to Lo, High or any position between (once no longer in the Off position, depressing the knob to change it is not required). If you're able to change the from Off position without pressing the knob, there is an issue with the switch - that may be contributing to the problem.
The cooktop is a 208 / 240 volt appliance. This is the highest voltage in your home. Voltages as low as 50 in the right circumstances can kill, and for this reason repairs must be performed with safety as the first priority. The cooktop sensors have determined that a control is on. If they are indeed off, there is a problem with either the sensor or one (or more) of the controls. You may have luck by locating the circuit breaker or fuse (2 pole 40 amp breaker or (2) 40 amp fuses) and removing power from the cooktop for a minute or two, and then restore power. This would allow the electronics to reset and if a logic problem - it would clear. If there is a hard fault somewhere, the indication would return again.
You should have the cooktop professionally serviced if the indicator fails to extinguish. I hope this helps & good luck!
Sep 16, 2011 | GE 30 in. Profile JP350 Electric Cooktop
I have a Jenn Air gas cooktop, only about 2 years
If the burner just clicks and won't stare try this (a local tech showed me) Scrape the underside of the burner cap (the removable black disk in the middle of the burner) with a key or knife and watch it work! But be ready to do it again and again. There's a glossy finish left by the factory he said.
Jan 03, 2010 | Jenn-Air Cooktops
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Installing JED8230ADB Cooktop Grill with down-draft exhaust
I can't imagine directing the downdraft vent back up to a traditional hood type system. Why bother, just don't use the downdraft or get a cooktop without a down draft and save money.
In granite, yes for any cooktop as long as someone can cut the correct size hole. Cooktops must be installed so the top is just about flush with the countertop. They all come with a template for cutting the right size hole in the countertop.
Feb 24, 2009 | Jenn-Air JED8430 Electric Cooktop
Hot burner indicator light won't shut off
the switch for the bottom right burner is bad but doent not affect the cooking, just the light
Nov 26, 2008 | GE 30 in.JP950 Electric Cooktop
GE 30 in. JP340 Electric Cooktop Logo
1,267 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
