Question about Vacuums
Dyson Animal dc07 -- change belt
Dyson Animal dc07 -- beater bar is not rotating. Belt is not broken. I suspect it has slipped off inside -- how do I disassemble to check belt?
Read the manual -- available on the Dyson web site. Brushbar not spinning • Ensure brush control is set on carpets mode. Note: brushbar will only spin when the handle is reclined.
Posted on Dec 28, 2008
The beater bar will not turn
Hello rebh. Generally when the vacuum beater bar will not turn it is because the belt that turns this beater bar has broken.
That said, most of the dyson's require you to buy a beater bar assembly which includes the belt. Any vacuum cleaner repair shop will have this part. OR go to this link http://www.searspartsdirect.com/partsdirect/brands-products/Dyson-Inc-Parts/Vacuum-Parts
Joe
Thanks for choosing Fixya!
Jan 17, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
The beater bar will not rotate but the belt is not broken.
DC07s have two belts - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
I suspect the belt you are to refering to is the one from the bar to the brush. Unfortuenately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay reasonably cheaply, but again good tools and DIY skills are required.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing your machine, but unless you have access to such tools, and feel confident to tackle it, it's probably time to call Dyson or a Vacuum repairer.
Feb 25, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar not spinning
That means that the belt has stretched or broken and it needs to be replaced. Here is a link the belt you need and the manual which has instructions:
Dyson DC07 Belt and Manual
Dec 19, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Beater brush does not work. Brush is clean and belt is not broke. Dyson 07 animal vaccum
Even though the belt may not be broken it might be stretched and if that is the case it will not turn the brush. You can get replacement belts here:
Dyson DC07 Replacement Belts
Nov 16, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Animal 07 beater bar not spinning - belt not broken
if your unit has a clutch it maybe that it is in the off position or the motor belt is broken your unit has to belts if its a clutched model
Oct 27, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Ran across shoe lace and when I pulled it out the beater bar quit rotating
just cut the sholace part that you can see... it will get it into a lot of small peices and just pull out the smaler laces
Jun 02, 2009 | Dyson DC07 All Floors Bagless Upright...
Beater bar not engaging,
The belt is in tact, but the beater bar will not rotate
Jan 25, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The motor is running but the beater bar is not turning
your belt has broken or has come off either replace it or put it back on. hope this helps
Jan 09, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
444 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
