Question about Microsoft Wireless Optical Mouse
Microsoft Wireless Keyboard Slow and Intermittent
My new Microsoft wireless optical keyboard (usb connection) sometimes works, and other times it is at a standstill. No matter how firmly a key is touched, nothing happens. Frequently after striking control+C to copy, nothing is selected, and nothing is copied, much less the control+V key to paste is ineffective. What is this due to? How can it be fixed?
  • Anonymous Dec 27, 2008
    Thanks...the Microsoft Wireless Laser Desktop 6000 shows a round 2.4 GHz wireless mini-transceiver (connects keyboard to system 'out of the box') on the box, but there was not one inside the box. The installation directions do not show this device, but only the usb device for the mouse. I think perhaps the tiny white button on the underside of the keyboard needs to be pushed? How often? Thanks for continued support.
    President:
  • 1,179 Answers
It can be a couple of things. 1. Try replacing the keyboard & mouse's batteries with fresh batteries. 2. Try moving the wireless receiver closer to the keyboard. 3. Make sure the receiver is not located too close to other electronics like a tv or dvd player. Hope this helps & please remember to rate my answer.
Posted on Dec 27, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 27, 2008
    The usb device is the transceiver. Make sure it is always plugged into a usb port. If you have a cordless 2.4ghz phone system make sure it is located away from the computer as it could cause interference with the keyboard. Make sure there is a pretty much open line of sight between keyboard & computer. White button is for trying to establish a new connection to the board from transceiver when it's lost. Hope this helps.
  • claudiano May 28, 2011
    Yes! My keyboard started to respond very slowly since a few weeks ago. I tried everything. It turned out that the problem was a brand new Cordless Phone 2.4 ghz that I had installed recently in my office. Solved!
How to turn on the microsoft wireless keyboard 1.0a
The Microsoft Wireless Optical Desktop 1000 hardware set includes the Microsoft Wireless MultiMedia Keyboard Version 1.1a, Microsoft Standard Wireless Optical Mouse Version 1.0a and the Microsoft Wireless Optical Desktop Receiver version 2.1a.
The receiver connects to your computer through a USB port.
The product installation CD that ships with the hardware set includes the software drivers that are required to install the Microsoft Wireless Optical Desktop hardware on your Windows computer.
Insert the batteries that are included with the hardware set in the keyboard and mouse.
The battery installation latches are located on the bottom of the hardware devices.
Place the product installation CD in your computer's CD drive.
The hardware installation wizard will open automatically.
Plug the receiver into an open USB port on your computer when prompted.
Follow the wizard to synchronize the mouse and keyboard with the receiver.
Close the wizard when it finishes to complete the installation process.
http://www.microsoft.com/hardware/mouseandkeyboard/ProductDetails.aspx?pid=058
Jun 29, 2013 | Computers & Internet
The keyboard is not working. Nothing comes out
I don't know your level of technical experience, so some of these may seem obvious. These may not be in the best order, I've added them as I thought of them.
1) check the batteries in the keyboard and mouse. They can go through batteries in a big hurry sometimes. If just changed double check polarity.
2) check the connection(s) for the receiver. If you have pets check for chewed wires.
3) have you added any new USB devices. They may be using to much power from your USB ports
4) have you added any other wireless devices, includes non-computer devices.
5) have you tried resetting the keyboard and receiver signal.
6) check USB power output. You can plug in a different USB device and see if it works.
7) does your receiver require batteries (very rare).
8) you may need to reinstall your keyboard drivers and software.
Most wireless keyboards operate in the 400 Mhz range so do most wireless networks and many phones, these can all interfer with your signal.
Jun 30, 2010 | Microsoft Wireless Optical Desktop 1000...
Microsoft wireless keyboard 700 v2-0 not working
Your keyboard MS 700 v2.0 needs a USB receiver to work. They are pert of set. You may also have a wireless mouse MS-700 that is also part of this set.
1. Do you have the receiver ? This has a USB connector that must plugged in to your PC's USB port
2. Are the batteries in your keyboard dead ? If so change them for fresh ones
Then proceed with the instructions in the Quick Start Guide which can be found from this webpage
Microsoft Hardware
Note the light on the receiver only flashes when you press the 'connect' button. At all other times it is normally out. There usually no lights on the keyboard. You should not need extra drivers as they part of the OS if you are using Windows XP or 7.
If you still have problems see
Your wireless mouse or keyboard does not respond or you receive The...
or search on the internet for our specific case
8.March.2015
Dec 05, 2009 | Microsoft Wireless Optical Desktop 700 v2...
Can I use a new MS wireless mouse to replace my existing MS wireless mouse. Currently my mouse and keyboard connect together on the same wireless USB device. Could the new mouse be detected and be used...
I suppose there is a reset button on the keyboard or the software provided so I suppose it could be possible, I don't know.
I use a Microsoft Wired Keyboard...
But Best of luck.
Jul 21, 2009 | Microsoft Wireless Optical Desktop Pro +...
My wireless mouse freezes
I had a similar freezing problem with a wireless Logitech mouse and also a problem with the wireless keyboard, sometimes keystrokes would not register and sometimes they'd repeat a dozen times.
I was not able to fix the problem, so I got a Microsoft wireless mouse and keyboard, hoping it was a driver conflict that wouldn't affect both products. Wrong. The exact same thing happened to the Microsoft mouse and keyboard.
The cause of the problem turned out be that I had the receiver plugged into a USB hub along with several other devices. Moving the receiver to one of the USB ports in the back of the PC fixed the problem.
Apparently these wireless desktop devices don't like sharing USB resources with anything else.
Apr 17, 2009 | Microsoft Wireless Optical Mouse USB...
Wireless Multimedia keyboard volume keys won't work.
Go to start and run then type services.msc or if using windows 7 just go to start and type services.msc in the search box. Once open find the service "Human Interface Device Access". Change it from manual to automatic and make sure that it is started.
Apr 04, 2009 | Microsoft Wireless Optical Desktop 1000...
Microsoft wireless mouse 700 works, slows, then stops
Seems like new batteries did the trick. Should start simple.
But I am not totally convinced. I will keep an eye on it.
Feb 17, 2009 | Microsoft Wireless Optical Mouse
Wireless keyboard & mouse not working
First download and run regscrub xp and ccleaner to clean up your system then try uninstalling and reinstalling the logitech setpoint software and try the keyboard and mouse again. Let me know if this works.
Oct 23, 2007 | Logitech Wireless Access Duo Optical...
Microsoft Wireless Optical Mouse Logo
1,621 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
