Question about Cyberhome DVD Recorder - DVR1600
MY CYBERHOME 1600 DOES NOT RECOGNIZE THE DVDS.
IT WORKED FINE IN THE SONY DVD-R, BUT NOW IT DOES NOT WORK WITH ANY TYPE OF DISK.
IT DISPLAYS A MESSAGE "' UNKNOWN DISK" .
Maybe a suggestion. I have been copying all my tapes to DVD. I did not finalize in the machine that it was made in, so it won't work in any other. My first cyberhome broke, so I had to go and get another cyberhome for it to read in it. (my problem is that I lost the remote and I can't get the universal to work. Good luck! you may need to find another sony and finalize it.
Posted on Jan 01, 2009
My dvd recorder will play but not burn anything at all
your laser lens of the dvd doesnt work thats why it doesnt read the disc the same thing was happening to me so u can open it and look if the thing where the laser lens is at is not stuck or your lens they wont work anymore.
Apr 30, 2010 | Cyberhome DVR 1600 DVD Recorder
CyberHome DVD 1600 won't record to Sony disk
I believe the recorder is bad, it should be able to accept all brands and types of disks. You might want to try another brand and type of disk just to make sure, if it does not work, the recorder is bad. Good luck to you!
Jan 03, 2010 | Cyberhome DVR 1600 DVD Recorder
DVD Player cannot recognize any DVDs
Laserunit faulty.Did you cleaned the laser allready?
Jul 30, 2009 | Sony DVP-S550D DVD Player
What format are you recording in?If the recorder is set for DVD +R, and your playback machine won't read the disc, you may need to record on a DVD-R, or a DVD +-R. Or vice-versa. Some DVDRW discs will record on one machine and won't play on another. The media are incompatible. Another problem - if you are copying a copy-protected disc, it might not play back either. Are you sure you are finalizing the disc? This process takes 4-5 minutes and requires two or three responses sometime.
Dec 03, 2008 | Cyberhome DVR 1600 DVD Recorder
Won't Format disk.
try a brand name recordable dvd+r
Oct 17, 2008 | Cyberhome DVR 1600 DVD Recorder
No disk
Hi. I have this problem with my unit. After a lot of research on the net it apperars that this is caused by problems with the laser pickup. The laser is either dead or is on its way out and doesn't have the strength it needs to read sensitive DVDs but is OK with Audio CDs.
A lot of CyberHome units have this problem due to the poor quality of the laser pickup units they use. I have been told that they have since gone bankrupt. If it is still under warranty then it you may be able to get it repaired but otherwise it may be cheaper to get new unit.
Hope this helps
Sep 10, 2008 | Cyberhome DVR 1600 DVD Recorder
Cyber home dvr 1600 problem
Hi. I have one of these units with the same problem
Mine will play audio CD's OK but DVDs are troublesome. I asked around on various forums and it appears that the DVD laser in the unit has failed or is on it's way out. (There are usually 2 lasers: one for reading normal CD's and one for DVDs).
I have noticed that my unit gets quite hot when in use and has very poor ventilation. Unfortunately any build up of heat can cause the laser diodes to malfunction and eventually fail and I think that's what has happened with mine.
If you still have a guarantee on your unit you could try and get it repaired otherwise it will be an expensive job and it may be cheaper to get a new unit.
Hope this helps
Sep 01, 2008 | Cyberhome DVR 1600 DVD Recorder
Formatting New Disc Problems
http://cms-system.cyberhome-dvd-help.com/modules.php?name=Forums&file=viewtopic&t=2579
Dec 28, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVR 1200 acting up; won't format new blank dvds; says no disk,etc
Cyberhome has gone out of business in the US. My DVR 1200 stopped working but I was able to repair some capacitors on the power supply to get it going again. You can find more support information about the 1200 and 1600 on these websites: http://cms-system.cyberhome-dvd-help.com/modules.php?name=Forums&file=viewtopic&p=14183 or www.nerd-out.com and search for Cyberhome.
Jan 02, 2007 | Cyberhome DVR 1600 DVD Recorder
Cyberhome DVD Recorder - DVR1600 Logo
90 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
