Question about CyberDrive CW088D CD-RW Burner
CW088D CD-RW drive
Disc drive won't open. After backing up as a file on CD, pulled the cd from the tray and closed the tray. Now the empty tray won't eject. When the button is pushed, the green light comes on but the tray won't open.
    Brigadier General:
  • 6,966 Answers
If I may add to sandrew, it may be a hardware problem. Normally below the tray is a small motor that drives a belt/gear mechanism that ejects/loads the CD tray. Sometimes, the belt slips, is worn out or plain cut, whichever case, the tray won't come out. If you care to take the risk, remove it from your pc (assuming desktop) , remove the 4 screws underneath, carefully pry open the plastic fron and tray cover and check for mechanical/physical faults. It is also possible that something is simply lodged in between the gears. Should you like to try a temporary remedy, normally just below the tray is a pinhole wherein you can push a stiff but sturdy pin (straightened metal paperclip will do) till you feel something yielding. push gently but firmly and the tray should open partways. You may then manually pull it out and try loading/ejecting. If it won't load/eject using the normal switch, guess you're back to the first paragpraph. Hopes this be of help to you. Good luck.
Posted on Apr 23, 2007
    President:
  • 2,961 Answers
All you can do is the usuall checks:- try, go to my computer>properties>hardware tab>device manager and go down the list to cd/dvd drives, click on the '+' and right click on your listed drive and select uninstall. restart the pc and then the drive will be re installed with drivers automatically. if it still won't eject then there is a drive fault.
Cd player door won't open
cd/rw drive has shifted due to unit being bumped, Tray is binding or blocked. Remove the back panel. Remove 4 screws on the bottom holding cd drive. Now you can push the drive slightly back. On the left side of the drive there is a white nylon cam. Push in with a screwdriver and the tray will open so you can manually remove your cd. You should be able to cycle the tray open and closed now. Replace the four screws but cycle several times after tightening each screw. Replace the back.
Aug 30, 2012 | Crosley CR248 Turntable
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
My CD tray will not close after removing a fragmented disc that got stuck
You have damaged the CD loader tray, best thing to do is just replace it, they are not repaired.
Jul 15, 2017 | Dell (0R649) CD-RW Burner
I have tried downloading from the samsung website lastest firmware update, which is an iso file when extracted it saves it to disc as a xuf file and the blu ray wont read this what am i doing wrong??
Read the Upgrade Guide (PDF) for instructions on how to do this. It says to burn a CD. The ZIP file extracts to ISO type. The guide tells you what format it needs.
http://www.samsung.com/us/support/search/supportSearchModelResult.do?menu=SP00&searchWord=bdp1400&searchInputBox=bd-p1400&find_button=
READ the PDF file under Upgrade Guide. Make sure you designate the proper file type when burning CD. Check your burning software.
How to make a firmware update CD
Please follow the below procedures.
1 Download the new firmware file from www.samsung.com
2 If the firmware file is compressed (*.zip), the file should be uncompressed to CD image file
(*.iso).
3 Please burn the CD image file on a blank CD-R/RW disc
1) Recommended CD Burning Program is Nero Burning ROM.
2) Burning Options (in case of using Nero Burning ROM)
A. ‘Recorder’ menu ?? ‘Burn Image…’ ?? Select an uncompressed image file(*.iso)
B. Please check ‘Finalize CD (No further writhing possible!)’
C. Please refer to your own CD burning Program Manual if you want to use any other
CD burning program for burning ISO image file.
D. Make sure if the downloaded software is eligible for your BD-P1400.
E. The System Upgrade will not be executed if using the update CD made with NOT
following the upper procedures.
Warning
The following events may interrupt the upgrade process and MAY RESULT IN PERMANENT
DAMAGE TO THE UNIT WHILE UPGRADING.
1. Unplugging the power plug
2. Power outage
3. Dirt or scratches on the burned CD-R/RW disc
4. Closing or opening a disc tray during update processing
How to upgrade the BD-P1400
1. Press OPEN/CLOSE button to open the disc tray.
2. Insert the upgrade CD.
3. Press OPEN/CLOSE button to close the disc tray.
4. Please wait about 6 minutes while verifying.
Verifying Firmware Version.
5. When below message box comes up, please check the date of the Firmware version.
Do you want to update Firmware?
>Current Version : 070730.02_XAA
>New Version : 070903.01_XAA
Yes No
6. Press ‘Enter’ button to choose ‘Yes’ for upgrade and please remove the disc on the tray.
If you select ‘No’, BD-P1400 will be automatically powered off.
If you don’t see above message box, try another disc. Generally, this is caused by disc
quality or a disc creation problem.
7. Please wait for about 7 minutes.
Firmware Update.
Now, Processing…
Please, do not turn off the power.
8. When finished, the screen and the power will turn off automatically.
9. Turn on the unit again. The tray will close automatically. Below screen will show up. Please
select the language you want with a corresponding number button.
MENU LANGUAGE SELECTION
Press 1 for English
Pulsar 2 para Español
Touche 3 pour Français
Macrovision : BSS01
10. If you want to do System Upgrade through the network, please refer to ‘System Upgrade’
Article on the User’s Manual.
Aug 18, 2010 | Samsung BD-P1400 Blu-Ray Player
CW088D CD-RW Tray ejects with CD in it but not empty
If the tray retracts but doesn't close 100% then it will open back-up. If it is closing fully then returning open then it is a bad drawer switch. It's hard to get to but if you do get in there, a little WD40 lube might help it actuate. Good luck!
Mar 15, 2010 | CyberDrive CW088D CD-RW Burner
I cannot either delete files or format a cd rw disk. Xl files are on the disk
Correct. Copy all the files into a folder on your disk-drive.
Delete the files. Use software (NERO, or ASHAMPOO Burning)
to "erase" the CD-RW disk, and then to write the remaining files back onto the "now-empty" CD-RW disk.
Sep 18, 2009 | Computers & Internet
Blinking green light on 1 tray
You could have a faulty drive.
To open the tray, you need a paper clip, straighten it and place it in the small hole below the disc tray, push it in and the tray wull pop out slightly, remove paper clip and pull the tray fully out with your fingers.
Then try to close and open the tray with the push button, if it does not work you need to replace this drive with a new one.
Sep 24, 2008 | Acard Technology (CD1TO7T) CD-RW Burner
Need help
Computer CD-ROM drive help and technical information. DVD-RAM - ReWritable drive type that uses a phase-change technology like the CD-RW drives. ... CH000031, CD-ROM receiving power but does not work.
Computer DVD Support The Divix player is more expensive than a standard DVD drive and current DVD drives do not ... CH000327, Will a scratch cause a CD or DVD to not work?
CD or other disc tray does not close or opens by itself. A CD-ROM or other disc drive tray that does not close or remain in the drive ... If the above recommendations do not work, the drive tray does not push all.
Computer CD-R help and technical information The CD-R drive does not actually create pits on the CD, instead the burner ... There were issues with reading CD-R disks in the first revision of DVD.
Device Manager information and help Later versions of Microsoft Windows renamed this category to DVD/CD-ROM drives .... If the device does not work correctly, use Device Manager to remove the.
Computer Cleaning Information CD / DVD cleaning Floppy drive cleaning Hard Disk Drive cleaning .... If a keyboard does not work after trying it again later it is recommended that it be .
Good Luck, Read & follow instructions/Please dont for get to Vote/Thank You.
Dec 22, 2007 | HP Pavilion dv4000 Notebook
CyberDrive CW088D CD-RW Burner Logo
374 people viewed this question
Top CyberDrive Computers & Internet Experts
David Payne
David Payne
Are you a CyberDrive Computer and Internet Expert? Answer questions, earn points and help others
