Question about Mongoose 2008 CX200
Broken cover of handle bars
The piece that covers a small circuit board is broken, how can we get a replacement part?
  • 8,197 Answers
Call mongoose at there # an the link below. They might beable to get you the part.
http://www.mongoose.com/usa/eng/bmx/ask_mongoose
Posted on Jan 09, 2009
When vaccum is tilted back suction does not engage.
This can happen if two tiny wires that are connected to the circuit board and lead to the beater bar are broken. These wires brake where they go through a black rubber grommet. You need a torx screwdriver (No: 15) to remove two plastic covers to access these wires . When looking from the front of the vacuum, the circuit board is located under the gray covers on the right side of the vacuum. There is one big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Once covers are removed check both yellow and blue wires carefully. Wires may look intact but the break may occur inside the black grommet. Slowly and carefully push grommet out and then carefully pull wires to the one side. If a wire is loose or broken you will immediately see the break. You can replace wires using replacement part given below or if you are OK with using soldering iron you may be able to repair broken wires without any expense.
Best solution is to replace broken wires with a new set of wires and connectors having fed the wires through the access hole making sure enough wire was available for the movement of the handle. Also ensure that when the covers are replaced they do not trap any wires underneath.
  • UK: Dyson DC15 Loom BB Over Current, Part No: 907280-03, Approx. Pounds 4.45
  • US: Dyson DC15 PCB to Yoke Loom, Part No: 907280-02, Approx. $11.75
See more details and photos at: http://bajwa.net/content/dyson-dc15
Feb 20, 2013 | Dyson DC15 All Floors - The Ball Bagless...
The brushbar stops when the vacuum is pulled back -- works some, doesn't some. DC 15 4 yrs old,on 6th brushbar.
See full details with photos at: http://www.bajwa.net/?q=node/3
Jul 09, 2011 | Dyson DC15 All Floors - The Ball Bagless...
Beater bar not working on newer ball pet unit
HighnTools posted this solution some time ago. I think it can help you solve your issue.
I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
Aug 29, 2010 | Dyson DC15 All Floors - The Ball Bagless...
DC15 Vac comes on but the head will nmot come on. Local Vac shop said circuit board was burn up,can I repair myself. where do I get parts
HighnTools had posted this solution - try it.
I hope this solves your problem.
Aug 16, 2010 | Dyson Ball HEPA Upright Bagless Vacuum -...
The Beater Bar keeps Shorting out, we had to replace it a while back and it was working really good, then it started shorting out, do you know what the problem is?
HighnTools posted this solution a while ago. There are so many people having similar issues. This might be related to your problem: I have finally fixed my sister's dyson dc 15 beater bar problem. It was just 2 tiny broken wires connect to circuit board lead to the beater bar. The wires broke where they go through the black rubber gommet. You need a torx screwdriver tx 15 to remove 2 plastic covers to access the wires. When looking at the front of the vacuum, the gray covers located on the right side of the vacuum. 1 big cover with a black rubber gasket and other small gray cover is on the rotating ball area.
The above by highntools.
May 11, 2010 | Dyson DC15 All Floors - The Ball Bagless...
Bought clearance item Sunday just found out the brush bar was motorized it turms only when i move the vacum back and fourth it should turn on its own right ? I have very little suction from the bottom the...
This appears to be a loose connection. The below post was answered by highntools a while ago. It probably is related to you problem. That is why moving it back and forth makes it go on.
There have been several people who reported loose or burnt wires to be the culprit for the brush bar not working. The DC15 does not use a belt, but a motor that is control by the circuit board. And I really believe that in your instance, the problem is a loose wire between the circuit board and the brush motor.
Mar 09, 2010 | Dyson DC15 All Floors - The Ball Bagless...
When I vacuum the carpet it won't engage into the brush mode, or it does intermittenly. It stays in the brushless mode for the most part
Aug 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Beater brushes don't work, what to do? They only work when the canister is in about an 85 degree up position.
Jul 12, 2009 | Dyson DC15 All Floors - The Ball Bagless...
2003 Ford Explorer back door latch will not open
Mine just did the exact same thing. The latch may be moving freely because it is not hooked to the latching mechanism anymore. In my case, the handle had broken where the handle hooks to the rod that operates the mechanism. Go to the Ford dealer and buy a new handle. Here in S.C. it was $24. You can't get this at the parts houses. Start by removing the plastic "Ford" cover that is over the liscense plate lights. You then have to remove the aluminum rivets that hold the handle to the tailgate from the outside and remove the broken latch. Remove the pull handle loop on the interior side of the tailgate (2 screws), unsnap the inside plastic tailgate interior panel, and pull down the black plastic sheeting that is underneath the panel to make access to the mechanism inside of the tailgate. There is also a hard plastic cover that you will see that needs to be pulled loose to open another access hole. Install the new tailgate latch handle by sliding back into the mounting holes and attach with two 10-32 screws and nuts. The new handle will come with a new yellow rod attachment piece on the handle. You will see inside of the tailgate a small rod hanging down, most likeky it will have the same rod attachment piece as the one on the new handle. Note the position of the yellow piece on the rod, as you will connect the new piece in the same place. Once the rod is hooked up, relubricate the metal mechanism with a light machine oil, replace the black plastic cover, replace the black plastic sheeting, (secure with a small amount of duct tape), replace the tailgate interior panel, replace the pull handle loop, shut tailgate, replace "Ford" cover over lights, and you're done!
Mar 23, 2009 | 2003 Ford Explorer Sport
Beater bar on Dyson upright won't turn when handle is lowered
This my new year resolution is to warn people not to buy Dyson vacuum cleaner ( Junk) design to break down! Shame on you Dyson!!!! Save your money find good old vacuum cleaner with metal parts.
OLD IS IN NEW IS JUNK!
Happy New Year!
Dec 20, 2008 | Dyson DC15 All Floors - The Ball Bagless...
Mongoose 2008  CX200 Logo
75 people viewed this question
Top Mongoose Cycling Experts
Jim Goldsmith
Jim Goldsmith
rigger094
TireSideDown
Level 1 Expert
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
