Question about Black & Decker V9660 DustBuster Handheld Vacuum
I switch is stuck and I can't turn it on?  Can this me fixed?
Central vacuum won't turn off when hose removed from wall socket
There is a switch somewhere close to where you plug in the hose. Check and see if the switch is stuck in the down position. If so, it will either need to be replaced or cleaned to allow the switch to raise to the off position.
Semper Fi,
Z
Aug 03, 2017 | Vacuums
I have a Dyson Animal that the on/off switch is stuck in the on position. I can only turn it off by unplugging it. How can I fix it?
A squirt of WD40 and a bit of joggling might help if it is just binding. I have had a look at mine and it is getting a bit sticky! However if the fault is mechical then that probably means changing it.
Oct 22, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Serger motor won't stop running
the switch is stuck in the on position.replace the switch.sounds like you have something jammed up in the motor.openit up to get to the motor and see whats in there
May 04, 2009 | Vacuums
Dyson vacuum cleaner doesn't start
check if something is stuck to keep the motor from turning
Mar 18, 2009 | Dyson DC05 Bagless Canister Cyclonic...
Dyson dc14 power button
I just had this same problem tonight. As I was looking on this sight to find a solution, my husband fixed it. First he removed the extended handle part, then he took the 2 screws out behind the power switch and removed the front cover (directly underneath the power button). He then removed the plastic power switch cover and took the power leads off the switch and removed the switch and tapped on it, then the little button stuck in place:) Sounds silly but it worked! Good luck!
Nov 17, 2008 | Dyson DC14 All floors Bagless Upright...
My NEW dirt devil with hepa made for animal hair will NOT turn off as the switch is stuck. I hate this vacuum. Help please
Take it back. Usually when this happens it means the switch has shorted out, which can be a big fire hazard. If you feel like performing a repair; a switch replacement is relatively simple: but if it's truly "new" it should be covered under warranty, and attempting to fix it yourself will void your warranty and give you no recourse.
-R
Aug 15, 2008 | Dirt Devil Vacuums
Hoover Hush Series Central Vac won't turn on
If the low voltage wires are hooked up to it, then you probably have a stuck relay inside the cannister. It could also be the switch in the hose handle.
Dec 03, 2007 | Vacuums
Black & Decker V9660 DustBuster Handheld Vacuum Logo
Top Black & Decker Vacuums Experts
GG TECHNOLOGIES
Are you a Black & Decker Vacuum Expert? Answer questions, earn points and help others
