Question about Canon PIXMA MX310 All-In-One Printer
How to load the MX310 all-in-one printer
I am trying to load the paper in the printer and fax machine
Lost cd for canon mx310 need to instald
Posted on Dec 29, 2008
Is it possible to reprint a fax I received on my Pixma MX310
Hi! have you tried this:
http://www.fixya.com/support/t6754616-canon_pima_mx340_printer_fax_machine
Nov 29, 2012 | Canon PIXMA MX310 All-In-One Printer
Canon MX310 not complete printing, last sheet may have jambed, took out whole. alarm on; printer display says: Check Print, press OK get 5100 message. On/off reset, open close, checked for paper jamb,...
Before your printer is on press the paper feeder tightly and than press power printer. Don't release your paper feeder until your printer is completing task...... thanks
Aug 11, 2011 | Canon PIXMA MX310 All-In-One Printer
I HAVE THE CANON MX310. RECEIVE THE FAXES IN THE MEMORY AND NOT PRINT.
If you are loading the memory and not printing, it usually indicates a supply issue - out of paper, out of ink.
There may also be an error, If you are using the unit as a printer on your computer, the printer status monitor often gives you the problem.
May 03, 2011 | Canon PIXMA MX310 All-In-One Printer
How do I send a fax?
Are you set up with the phone company? you need to set up your fax machine by putting the other persons fax number in its memory,then you put in the fax number to where its going and . you load your paper you're going to fax and send! it'll come out just like a printer when its done.
Feb 24, 2011 | Canon PIXMA MX310 All-In-One Printer
I am having a problem trying to send a fax using my canon mx310 Im not even sure how to load the paper
There should be an area at teh top of the printer for you to place the paper onto. You will see an icon on the tray up top it will either show you how to place the paper either face down or face up. You will then push the fax button on the left side of the control panel. You will then dial the number of where you are faxing it to with the keypad on the right side. ONce you have entered the number all you should have to do is press the "start" button or the "ok" button. And away your fax will go.
Jun 30, 2010 | Canon PIXMA MX310 All-In-One Printer
Will not feed paper
have you made sure there is nothing inside the printer where you put the paper in at ? the smallest thing in there could keep the paper from feeding through, you may have to turn the printer upside down and shake it a bit,, carefully.. then try to feed the paper again.. ( I am assuming it is a printer and not a fax machine )
Mar 12, 2010 | Canon PIXMA MX310 All-In-One Printer
Faxes are not being printed when sent - Machine
its recieved the fax in memory!The only time that happaens is when there's no toner or paper in the m/c
Feb 25, 2010 | Canon PIXMA MX310 All-In-One Printer
Looks like I have an incoming fax: screen reads, "received in mem
You have the fax setting to use memory or no paper loaded.
Go to the fax menu and change it to print.
Jun 17, 2009 | Canon PIXMA MX310 All-In-One Printer
BARRIE@NORTONBARRIE.CO.UK
RECEIVED IN MEMORY
If the machine receives a fax under one of the following conditions, the machine will not be able to print the received fax and will store it in its memory.
When the problem is resolved as described, the fax stored in memory is printed automatically.
bullet_s.gif Ink is low or has run out while receiving a fax: replace the FINE Cartridge.
bullet_s.gif Paper size/type setting is incorrect: correct the paper size/type setting.
bullet_s.gif Paper has run out while receiving a fax: load the paper and press the OK button.
bullet_s.gif Output Tray is closed: open it.
bullet_s.gif OFF is selected for AUTO PRINT RX: select ON.
bullet_s.gif You pressed the Stop/Reset button to cancel printing of a fax: press the FAX button.
Jul 18, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA MX310 All-In-One Printer Logo
76 people viewed this question
old marine
old marine
