Question about KitchenAid K5SS Heavy Duty Commercial Stand Mixer
No power to motor after removing and replacing brushes.
A rock hard clump of brown sugar stopped the beater on the mixer. At first I removed the two side brushes which didn't seem to fix things so I replaced them. At that point I noticed there seemed to be no power to the motor. I realized that the nylon gear had broken so replaced that and removed all broken pieces of nylon from the grease and re-greased all the gears and replaced everything as before, but still no power or sound from the motor. Is there a reset switch somewhere that I'm not finding or has the motor burned up?
  • RICH NICHOLAS Aug 20, 2007
    Turns out I put the brushes in backward. Once I switched sides everything worked normal. I did have to adjust the speed control after it was working however since I had inadvertently readjusted it to immediate fast speed.
    It's working fine now and making cookie dough with ease.
    Thanks to all for your suggestions!
  • alcarriere Nov 02, 2008
    Same deal I took the brushes out both sides now nothing...
    How do you know the "right" way...
You probably should download the kitchenaid shop manual and it has troubleshooting procedures in it; http://store.mendingshed.com/kitaidparts.html There is a board that controls the speed might be a issue; also check and see if any wiring shorted out. Again, download the manual as it has troubleshooting info and the wiring diagram! Good Luck!
Posted on Aug 19, 2007
    Brigadier General:
  • 6,966 Answers
Hi, if I may suggest, try checking the thermal fuse if it has one. It normally looks like a silver capsule with one end pointed/black plastic or rubber. Sometimes it is connected outside of the motor winding but more often than not taped or very close to the motor winding. It might also be inside a spaghetti tubing. Electrically it is in series with the motor windind. It should normally read 0 ohms with no polarity. Other than that, since I get the impression that you are comfortable with tools, you might try using a VOM (or continuity tester) to check the windings themselves. Hope this helps in addition to the suggestion of snakehead. Good luck.
Posted on Apr 23, 2007
  • Louie  Role
    Louie Role Aug 20, 2007
    There you go. Nice job.
    Genius:
  • 1,074 Answers
Check the motor it could be burnt if it is replace it.good luck
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
I have a KitchenAid mixer Model K5SS, Ser #W83808959. The motor stopped running and in checking the brushes, I found they are are both stuck in the brush holders. I suspect this is the reason the motor...
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
You may have to remove the Motor Housing and use a small screwdiver
to completely remove the brushes or all portions of them if they are broken.
Jul 30, 2011 | KitchenAid K45SS Classic Stand Mixer
One of my blades is stuck and I can't engage the release
Make sure your Beater can slip in and out of the Beater Shaft
easily. Do not force the beater onto the Shaft if the shaft is bent.
If it cannot be removed easily by hand, use a soft rubber mallet
(not a steel hammer) to slightly tap the beater so it can be moved
up and down the shaft or from side to side. Then you can easily
turn the beater left and remove it from the shaft.
From Kitchenaid Manual:
To Attach Flat Beater, Wire Whip, or Dough Hook
1. Turn speed control to OFF.
2. Unplug stand mixer or disconnect power.
3. Tilt motor head back.
4. Slip beater onto beater shaft and press upward
as far as possible.
5. Turn beater to right, hooking beater over pin on shaft.
6. Plug into a grounded 3 prong outlet.
To Remove Flat Beater, Wire Whip or Dough Hook
4. Press beater upward as far as possible and turn left.
5. Pull beater from beater shaft
Jul 19, 2011 | KitchenAid KSM150PS Artisan Series Stand...
First time using bread dough beater It was hard to put on and am unable to remove
as far as possible.
5. Pull beater from beater shaft.
Jul 17, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Bread dough beater will not come off
as far as possible.
Kitchenaid mixer won't run changed out brushes and have changed them out in all 4 different positions
The brushes need to be seated onto the armature. Try going from off to high quickly and tapping the motor housing. Once the motor starts, let it run for 15 min plus to seat the brushes. Keep clear of or remove beaters whille trying to get the moror running. In brief, the brushesaren't making good contact with armature. Good Luck
Aug 11, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
Middle better comes loose
Try placing some "braces" rubber bands around the shafts of the beaters. This should tighten the hold of the shaft with the mixer and keep them more straight.
Dec 15, 2009 | Sunbeam 2346 Heritage MixMaster Series...
Kitchenaid k45ss won't turn on
if you remove the top you will find a tiny fuse wrapped in a black band on the left side from the back. It connects two white wires which power the top-side motor brush. Most likely this needs to be replaced. You can check by bypassing it with roach clips or a copper wire. Unplug the machine first and be careful!
Jan 25, 2009 | KitchenAid KT2651X Epicurean Stand Mixer
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Logo
306 people viewed this question
Top KitchenAid Food Mixers Experts
jack arons
Colin Stickland
Colin Stickland
Steve Allison
Steve Allison
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
