Question about Edimax BR-6104K Router (br6104k)
Edimax Router disconnects the internet when laptop is on battery
I am using Edimax router BR6215 and everything is OK all the time my laptop is pluged into electric power. But when I want to use in on bateries the internet connection disconnects all the time and never stays connected for more than a minute...
Please help
thanks in advance.
Ariel
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
That has nothing to do with your router.
Its your laptop that shuts off your wireless card every time its running on battery power.
Posted on Jan 09, 2009
My edimax br 6428ns keep on losing its internet connection...i have an internat connection around 30 min but it will stop and i need to run the setup again in order for it to work..
Check the connection type is not "Connect on Demand".
Check the Idle Time Out setting is not used.
This specifies the amount of time the router waits before shutting down an idle connection. This option is only available when "Connect on Demand" is selected. See the manual
See
http://www.edimax.co.uk/edimax/download/download/data/edimax/uk/download/for_home/home_legacy_products/home_legacy_wireless_routers/br-6428ns
Feb 07, 2013 | Edimax Network Br-6428ns Wireless N 300m...
Edimax
Put everything on an Uninterruptible Power Supply (aka battery backup)
Aug 04, 2012 | Computers & Internet
Edimax br6204wg wan led doesn't light up and there is no internet connection
Hi yaminmagdi,
I believe that you are trying to get connected wireless using your Edimax Router, we may need to check some settings in your Edimax regarding the wan light not lit up and could be a possible reason why there is no internet connection.
1. First we will need to find an Ethernet cable for us to be able to connect your Laptop directly to your Edimax Router for us to be able to check and change any settings needed to enable your Edimax wireless connection. also make sure that the Ethernet cable is connected to the Ethernet ports behind the Router not the WAN port then the other end goes directly to your Router.
2. Once connected directly to your router from the Laptop open IE or any Browsers on your Laptop, in the Address bar type in 192.168.2.1 then press Enter this will prompt for a user name and password, User Name will be ' admin ' and the password should be 1234 unless you changed it.
3. Inside the Edimax setting page click on the Tab that says Wireless, check and see if the wireless is enabled if not then enable it or turn it on, after enabling / turning the Route ON save the settings by clicking on Apply or Save then it will prompt that the Router is restarting it will be 30 seconds to apply once the 30 seconds is up that should be done check your Edimax if the WAN light is already lit up, then you can try an connect Wireless from your Laptop.
I hope this helps.
Have a nice day.
Apr 03, 2011 | Computers & Internet
I've a Edimax 7284WnA Wireless N150 ADSL/+2 Modem Router. The problem is, whenever I use its wifi functionality with my sony laptop, the connection keeps disconnecting. Please note that the internet...
You are right, if your laptop has no issues except in your home, your laptop is not the problem. You should read the "Communication Failures" section of my tip entitled "Understanding Wireless Networks". You can read it here. You should troubleshoot this starting with the obvious... Are you in Range? Is there a device causing interference (cordless phones, other access points, microwaves)? If there are other WiFi Access Points in your range, verify that they are on a different channel than your router (you can do this with a free WiFi Scanner called "NetStumbler" or "InSSIDer"). If you follow my advice given in the article, and you still have issues, there is a possibility of the router's transmitter/receiver starting to fail.
I hope this helps,
Livingmentor
Feb 03, 2011 | Edimax BR-6216Mg Wireless Router...
Edimax Router BR-6204WG - setting as
I believe I can help.
As I understand you use your Siemens to get to Internet and you like to use another Edimax 6204 WL Router on another floor.
You don't have to change much !
First check if DHCP on your Siemens Router is ENABLED (it should be) !
- RESET your EDIMAX Router (to be sure everything is set by default)
and disconnect any LAN cables from it.
- If you are using Laptop (or desktop with WL adapter), connect it to your EDIMAX by LAN cable.
- Set (if it is not) LAN adapter IP and DNS of your Laptop/Desktop
to 'Obtain an IP address automatically'
If it was seto to some STATIC IP, after this you may need to 'REPAIR' your LAN connection
to get a new IP from your Edimax router
- Open your browser and type http://192.168.2.1
(admin + pass: 1234)
- Go to Wan port and check it. It should be set to Dynamic IP.
- Go to LAN settings and type IP address of the Edimax Router in the same Class
as Siemens Router is. (e.g. if Siemes router is 192.168.1.1 then Edimax should be 192.168.1.2)
- Change the DHCP range too, but be carefull this range should be different from DHCP range on your
Siemens router. (e.g. if Siemens router range is 192.168.1.100 to 192.168.1.200, then you should
set Edimax DHCP range from 192.168.1.201 to 192.168.1.250)
- Now, connect the LAN cable from one of Siemens LAN port to WAN port of your Edimax.
That's it!
Now you may change SSID, Security, Time etc. on your Edimax router, and also try to connect via your Laptop's WL adapter. (also make sure it has no static IP address)
Hope this helped.
Aug 30, 2008 | Edimax BR-6104K Router (br6104k)
Edimax wireless-g broadband router
please confirm if the router is a 6104K, or a KP or Wg or another model as the K and KP are not wireless, a "W" will denote wireless capability...
Not all manuals are available for download from the Edimax website but heres a start...
Connect the router to your PC with a cable... leave the modem disconnected to start with
open internet explorer and type in enter the default IP address 192.168.2.1 (broadband router’s IP address) into your PC’s web browser and press <enter>
This should bring up a user/password dialog box. By default the user name is "admin" and the password is "1234".
Confirm you are getting this far and we'll go the next steps
Jul 06, 2008 | Edimax BR-6104K Router (br6104k)
Page Cannot be Displayed-IE, Edimax Router BR-6104K
Smartbro account is used directly to the computers LAN port, not on the router, One computer should be made as the server, where the smartbro connection is placed... to share the internet connection... you should have another LAN card to share Internet throught the router... "See New Network Connection" you'll see examples of proper connection.
Good luck... Fixya...
Feb 02, 2008 | Edimax BR-6104K Router (br6104k)
Frequent disconnection of internet service
HI rodelio,
Please give me the backbone of your committed internet rate (CIR), is it burstable bandwidth?  Actually router  is designed for Network Address Translation (NAT) which means it is better to have fast ISP that has committed internet rate (CIR). It is constantly happened for internet connectivity fluctuation cause of very low CIR specially when you are connected with more than 3 computers on the network setup.
Much better to used proxy server with linux, or Kerio Route Firewall for better performance of your browsing.
I am glad if you can extend your problem to me. I am here to help you.
Best regards,
Philip
Oct 02, 2007 | Edimax BR-6104K Router (br6104k)
Edimax BR-6104K Router (br6104k) Logo
320 people viewed this question
Top Edimax Computers & Internet Experts
Prashant M
Prashant M
Michael Vincent Cruz
Are you an Edimax Computer and Internet Expert? Answer questions, earn points and help others
