Question about Panasonic NN-T994SF Microwave Oven
Turns of after 3seconds
When the microwave is turned of it turns off after 3 seconds and has a
burning smell.
  • 2 more comments
  • ljb00 Jan 30, 2009
    Same problem - turns off after 3 seconds with a burning smell. Ours started right after cooking potatoes - I wiped the steam off and attempted to cook a second item and this problem started. The magnetron is still under warranty, but the labor charge would probably be ridiculous. Unfortunately, I had to buy a new microwave.
  • davidscales1 Mar 05, 2009
    i have the same problem , and it is the inverter board or power supply board if yo will ... the original part # is f606y6gooap and has been superseeded by part # f6o6y6goocp witch tells me that this was a common factory problem and to fix it they had a factory updated part to the f6o6y6goocp to fix the poor factory part and the cheapest i've found this updated part is 56.00 if you are a dealerand 72.00 if not but that is shipped to your door price
  • Anonymous Mar 19, 2009
    MY OTR BLOWS THE FUSE AS SOON AS YOU PRESS START, I'VE CHECKED THE DOOR SWITCHS AND MONITOR SWITCH, THEY ARE GOOD,AND AFTER UNPLUGGING THE INVERTER BOARD THE OTR WILL RUN FOR ABOUT 3 SECS AFTER START IS PRESSED, AND DOESN'T BLOW TH FUSE, IS IT THE INVERTER BOARD?
  • Anonymous May 25, 2009
    My microwave quits working after 5 seconds and makes a ticking sound
Ps this part is super easy to change after you get the cover off it is the part in the yellow plastic box ...unsnap the box unplug the three set of wires unscrew the ground strap bend up the tab at the lower left side the same side and behind the ground strap and slide the box and all to the left about 1/4 of an inch and take the box off ... there are 3 screws that seperate the box from the board and the reverse the process... hope this helps .. and if you not sure that this is your problem leave the cover off plug it in and start it lookin the yellow box before it shuts down you will see sparks from the transformer
Posted on Mar 05, 2009
  • davidscales1 Mar 15, 2009
    i changed the inverter board and works like new aftre tax and shipping cost to fix was 85.00
Davidscales is right-on about the fix. Ordered the part from PartStore.com for $68 with tax and shipping. Changed it out in less than 15 minutes. Back in business. I only wish I hadn't paid $60 to have the problem diagnosed before checking the web.
Thanks David.
Posted on Mar 05, 2010
  • Panasonic Master
  • 9,098 Answers
If the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
It may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
Posted on Dec 28, 2008
I have a maytag model mmv1164ws when you turn it on makes a buzzing and smells like something burning!
Something is burning, there are high voltage parts in a microwave oven and they wear out. You probably need a new diode. Part number WPW10492276 google it
Aug 30, 2016 | Maytag MMV1164WS Microwave Oven
Microwave smell like burning rubber
Good Afternoon Friend,
I understand that you are receiving a burning rubber smell from your Frigidaire microwave. I also see that your appliance will run for a couple of seconds, and then you hear a weird noise, followed by a burning rubber smell. I suggest contacting your local authorized technician, especially when dealing with your microwave. They will be able to diagnose your appliance and determine what is causing that sound as well as the burning rubber smell. Hope this is helpful.
-Best Regards-
WP
Jun 17, 2014 | Frigidaire Microwave Ovens
Burning smell and loud grinding noise
If that grinding noise sounds a little like gargling into a coffee cup, that's a defective magnetron.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Jan 09, 2013 | GE JVM1441 Microwave Oven
Microwave timer is locked. how do i unlock it?
Press/hold the clear/off button for 3-5 seconds.
Thanks!
Sep 27, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Buzzing sound when you turn on .also smells like burning
The magnetron is failing, "heats food" and in some cases gives off a burning smell, "classic symptom" repairs will run close to a new microwave oven or more.
Jun 07, 2011 | Whirlpool MH7140XF Microwave Oven
When I turn on the micowave; smell somthing burning
The magnetron (the part that heats the food) may be ready to burn out. If you smell the burning, you should then unplug the microwave, open it up and see if you can determine for sure that it is coming from that part. Unfortunately even if I am right, it is almost more cost effective to just replace the microwave rather than replace that part. You can run this microwave till it dies if you want, but I would be ready with a new one.
Let me know how this works out for you.
Benjamin
Apr 29, 2010 | KitchenAid KCMS145J Microwave Oven
JVM 1660WB 003 GE Profile Microwave humming sound/burning smell
the magnetron the unit has gone bad.sometimes there is burning smell as u mentioned.it is little expensive repair arond $ 150.00.find out the price of new unit plus iistallation/delivery chg and then make a decision.
Aug 17, 2009 | Microwave Ovens
Burning smell , Microwave not turning off
the control circuit shorted out from the cleaning session and kept the microwave on so long with nothing to cook that it has cooked itself I'm sorry to tell you. Probably not worth repairing
Dec 27, 2007 | Kenmore 62702 Microwave Oven
Burning smell from Microwave
If you clean any appliances always plug out the unit power supply do spray any liquid in the unit that can enter inside the control, instead just wipe it with rug not spray. In this situation you have to call for a qualified technician. Maybe there are some wires that burned or rust in the control that cause the short circuit inside the unit..
Dec 27, 2007 | Whirlpool MH7135XE Microwave Oven
Panasonic NN-T994SF Microwave Oven Logo
531 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
