Question about GE JBP90 Electric Kitchen Range
F2 error code on GE built in Oven Model JKP13GOP
What does an F2 error code mean on my GE bulit in over Model JKP13GOP oven?
  • 8,197 Answers
Your error code means this. F2 For an unknown reason, the oven temperature has exceeded a preset threshold.
Good Lock and Please Rate FixYa!
Posted on Dec 27, 2008
GE single oven with touch pad settings. Getting error code F-4 after selecting any bake or broil function keys. Oven light works, fan for convection oven seems to be working. Makes no unusual noise. will...
Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
Jan 21, 2011 | GE Ovens
JS968SF4SS model gives 'F2' error. Possible
F-2 usually oven sensor shorted or bad. Replace oven sensor an you should be good to go. Hope this helps.
Feb 13, 2010 | GE Ovens
I'm getting a F2 Error and door locked with flashing and beeping after I ran the self-cleaning mode on my GE Model JTP85 built-in oven.
f 2 code states that your oven temp exceeds 590 w/unlocked door .. the oven tempt sensor will need to be replaced .. hope this helped mm
Dec 04, 2009 | GE JTP85 Electric Double Oven
Error code f2
This usually means the oven detected an over-temperature condition (although F2 meaning varies by model). This can be caused by a faulty temperature sensor or a failed control board. Many of the control boards for the older models have been discontinued. We repair these at www.fixyourboard.com.
Oct 05, 2009 | GE Ovens
Built-in oven beeps and shows code F2
check your manual for error codes if no go see the store that it was bought from or ge
Aug 25, 2009 | GE JTP70 Electric Single Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
GE Oven displaying both F2 and F3 error codes; bad ERC or temp sensor?
F3 is Open oven temperature sensor circuit.
F4 Shorted oven temperature sensor circuit .
F7 Component failure.
To fix this you need to read oven temperature sensor circuit at oven temperature sensor ( approx 1000 ohms at room temp); check for cut or pinched wire or loss of contact, if wirings are ok, then replace the probe.
Oct 28, 2008 | GE JRP15 Electric Single Oven
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
GE JBP90 Electric Kitchen Range Logo
1,077 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
