Question about Tomtom One XL GPS Receiver
Won't turn on
I have plugged my tomtom XL 1 in to my computer and nothing I plugged it in to a power source for 2 hours and still won't turn on, held the button down for 30 seconds and nothing. Please help. Thanks Betty
  • 1 more comment
  • fhirst Dec 30, 2008
    new tomtom xl
    this was connected to my computer for the first time ,both computer and xl were switched off .the xl will not now switch on whether connected or not .
    jack
  • bcambra Jan 10, 2009
    My solution was I called the company and she had me look on the bottom for a pin hole and with a paper clip I reset it, Solved my problem.
  • 1983kev Jan 16, 2009
    mine is the same when pluged in to either the car our computer works fine unplug and it will not turn on
Partial Solution
My Tomtom xl 30 (if it has not been used for a few hours) takes up to one minute of holding the power down to turn on. ie a reset!
Posted on Jan 10, 2009
  • enidnarc Jan 25, 2011
    It took mine about 20 seconds of holding the power button. Thanks!
Hi :My Tomtom does not start from the main push botton. My tomtom kind ONE XL.S
Assuming you have pushed the ON/OFF button, and had no success .... and have also pushed down and held down the ON/OFF button for a few seconds ... up to a minute, and your GPS still does not turn on ... then, you want to make sure the battery is fully charged before you try to start it again.
Note that it may not start while it is plugged in (to a power source) ... because it uses the battery as the primary source of power.
Plug the GPS device into the charger (wall adapter or your USB computer port) ... to charge the battery for a few hours... preferably more, like 24 hours or more. Then try to start the device again.
Feb 10, 2011 | Tomtom GPS
Tip
TomTom XL 330 not coming on?
If you TomTom is not coming on after a long sleep.. I.E. more then a few days with no use, try this......
(1) Plug the unit into either a PC or your Car
(2) Wait for about 2-5 minutes to get some charge into the unit
(3) Press and hold the power button for about 15-20 seconds until you see the start-up screen
Why did it die? I have found and many other have found the battery does not live long without a power supply to charge it, it would seem to me even thou it is powered off, the TomTom is still sucking away at the battery and it would seem there is nothing that can be done about it.
on Sep 16, 2009 | Tomtom XL 330 Car GPS Receiver
Go720 will not turn onbattery charged and plugged
charge it for a few hours via the usb cable to your computer, then press and hold the power button for up to 15 second.
if that fails, let me know and i can give you a few other options to try, but this work 99% of the time if the unit hasnt been damaged in any way.
Dec 01, 2009 | GPS
Green light on but will not switch on
plug in your xl via the usb cable to your computer and let it charge a few hours, then press and hold the power button for up to 15 seconds.
do not use the car or home charger to intially charge your xl. they are to maintain the battery, not a rapid charge.
let me know if you need further help.
Nov 09, 2009 | Tomtom One XL GPS Receiver
Tom Tom suddenly won't turn on. It is 2 years old. Has worked with no problem. Battery continually charged as I drive. Used re-set button to no avail. Need today for a trip!
plug it in to the usb cable to your computer for a few hours, then press and hold the power button for up to 15 seconds or untill it starts.
after it starts run tomtom home and get the latest updates for it.
if you do not have tomtom home, you can get it HERE just follow the directions after you download and install it on your computer.
Oct 29, 2009 | Tomtom One XL GPS Receiver
I have not used my tomtom for a few months , an when attempting to use it today , it was dead . nothing at all help tomtom xl roseden@telus.net
connect it to a power supply and leave it for a few hours A battery that is totally depleted will take some time to recover and not show that it is even being charged as power is too low to light the LED.
It will require a full charge of about 10 hours to get it fully back into service. But the LED will ( or should turn on) after about 1-2 hrs depending on the condition of the battery. If after the charge the battery does not hold a charge lasting on average about 2 hrs , then change the battery.
Please rate our help++++Thanks for using FIXYA
Sep 25, 2009 | Tomtom One XL GPS Receiver
My TomTom1 xl wont power on. I have changed the fuse in the power adapter ,but still nothing. Is there a reset button ? Thank You !!
plug the unit into your usb cable on your computer and let it charge for at least 2 hours, then try again.
if that fails, the reset is on the bottom of your Xl (little pin hole) but make sure remove the sd card and you have let it charge for at least 2 hours before trying to start or resetting the unit.
bill
Aug 30, 2009 | Tomtom One XL GPS Receiver
TomTom won't turn on
Try holding the power button in for about 15 - 20 seconds to see if it comes on, do this whilst plugged into a computer or your car.
Aug 14, 2009 | Tomtom XL 330 Car GPS Receiver
Unit (tom tom 1xl) turning off
One hour is about the time the unit will run without a power source.
You need to check that the cigarette lighter is working. Check the car fuse.
Check the fuse (one of the six bumps) on the cigarette lighter plug has not blown.
Is the cigarette lighter / Tom Tom lead damaged in any way?
Peter
Mar 01, 2009 | Tomtom One XL GPS Receiver
Tomtom One XL GPS Receiver Logo
240 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
