Question about LG LFX25960ST Stainless Steel French Door Refrigerator
Inside lights stay on w/doors closed
Lighgts stay on until time-out, then do not go on when door opened, until time-out is over. I had to remove the bulbs, was heating up excessivly.
  • Anonymous Jan 19, 2009
    LIGHTS IN FF SD STAYS ON WHILE DR CLOSE BURN LENS ECT. HAVE TO UN SCREW BLUB
Remove the bulbs, dummy!
Posted on Dec 28, 2008
Dash light says drivers door is open when it is not open and stays on.
Possible defective door ajar switch. Usually located internal to the door lock mechanism inside the door. I have had some success spraying WD40 inside the lock assembly with the door open and then opening and closing the door several times.
Nov 29, 2015 | 2007 Toyota Camry
Mazda 6 2005 driver door jammed
if you talking about door latch wont let door close.try to reset all door locks.first if you cant get door close.work unlock button with remote or door switch.then hold open door handle while you flat screw driver pull up latch in door latch should stay up so door will close.once get door close.try resetting all door locks by sitting inside vechicle with all doors close.remove key from ignition.open drivers door.wait 24 seconds.turn ignition switch on and back to lock position 3 times.press and release drivers door courtesy light 3 times.ensure doors lock and unlock.if not wait 40 seconds and repeat procedure.if this procedure fails. you have problem in the door latch and lock mechanism inside the door itself.
Jan 04, 2013 | 2004 Mazda 6 Sport
Garage door only closes halfway
If the main light is flashing 10 times when the door reverses when closing it is a door sensor problem. You can override this with the door control but not with a remote. Make sure the door sensors are pointed at one another and the small light on each one is on and not flickering.
Jul 07, 2010 | Sears Craftsman LiftMaster Chamberlain...
96 Ford Windstar the rear left cabin light and slidding door light stays on all the time and the sensor on the dash show that the doors are open when they are not. What can be causeing this?
Use WD40 spray and spry inside lock,Dirt can cause the sensor to stay open circuit either if it door is open or closed. Spray and open and close door few times, and repeat it till light goe's out.
Feb 21, 2010 | 1996 Ford Windstar
Door opens after closing
If the main light flashes 10 times when the door reverses it is a door sensor problem but if the door is hitting the floor and reversing and the main light is not flashing then the door is closing too far and the safety thinks it has hit something. On the side of the motor unit you will find 2 controls. One of these is the 'down limit'. Turn this in the opposite direction of the arrow printed on the cover until the door closes but does not reverse.
Jul 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
How to get to stop light in back window of 95 lincoln cont. Bulb is burnt out. do we change from trunk side or inside of car? also have a problem with interior lights staying on for a long time after car...
First, the stop light bulb is accessible from inside the car. The cover can be removed by pressing down on the center of the unit and pull back toward the front of the car. Once off, you will have access to the bulb itself
You have a sticky door switch. Apart from replacement, best course of action is to spray the switch (all throughout the inside of the door/lock) with WD-40. Since you're unsure which switch is sticking, repeat this procedure on all doors. Once thoroughly lubricated, open and close the doors several times. This should fix your sticky switch problem.. Best of luck.
Greg
Jun 08, 2009 | 1995 Lincoln Town Car
I have a side by side Viking refrigerator and after leaving the door open a little too long the lights went out in both the refrigerator and freezer. I figured that they would go back on automaticlly after...
Remove the center grill of the top grill and shut the power off and back on, the lights should reset
When the lights are working open the Ref door then close the freezer drawer, watching to see if the light in the freezer shuts off. It should shut off when the freezer is about 1" from closing. If it stays on until the door is fully closed then there is a problem with the light switch in the freezer.
Normally when you leave the doors open until the lights shut off, it should reset when both doors are closed
Mar 06, 2009 | Viking DDBB363 Bottom Freezer Refrigerator
2003 Explorer door ajar light stay on when all doors are closed
I had this problem on my 2003 explorer and took WD40 and gave the lock mechanism a good dose where it meets the clasp on the door jam. Then open and close the doors a couple of times to get them working. They get gummed up and sometimes have a tendency to stick.
Dec 29, 2008 | 2003 Ford Explorer
95 jeep grand cherokee laredo 5.4 replaced alternator and battery and cable still have dead battery every morning Please help
the best way to look at this problem is with a12 volt test light then remove the ground cable from the battery turn every thing off inside the car close all doors and remove keys then connect testlight to battery cable and touch the test light point probe to the negitive battery post if test light lights up for more than three seconds and stays on you have draw on the system. dont panic it maybe just a glove box light or door switch. if suspect a circuit simply un hook it retest again .if you open a door that will make light test come on recheck all doors closed. if you still have test light on locate fuse box and remove one fuse at a time until test goes out while holding door switch in.when locate circut use wiring diagram to assist from ther. if the light does not light up check altenator output volt meter shoud be 13.2 -15.5 volts when running.
Dec 09, 2008 | 1998 Jeep Cherokee
LG LFX25960ST Stainless Steel French Door Refrigerator Logo
211 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Mike
Mike
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
