I have a quarter stuck in drain pipe before the removeable filter i can see it on a lgwasher model wm2277h
  • 15,935 Answers
You'll need to lay out a towel and remove the drain hoses from the pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Maytag Model # MD87609AWB3 after rinse cycle it stops. I have to push button to finish drying cycle
Hi
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 24, 2011 | Maytag Dishwashers
Where is the filter in my wirlpool washing machine model no. wfs1072aw and how do I clean it
Hello, Erica.
Your washing machine's filter is located behind the kickpanel (or, 'plinth', as they call it in Oz) underneath the door. First, unplug the machine (or otherwise disconnect it from electricity. To remove this panel, grasp it on both sides and press downward and tilt it forward.
The filter is to be opened slowly as water will come out. Tucking a towel underneath the drain may help. The filter unscrews counter-clockwise. When you get it open, check that the pump is spinning freely. Also, if your machine is not draining, a coin or something small may be blocking the drain pipe (a US quarter or Australian fifty cent piece is a perfect fit to totally block the pipe).
When you are done, add 1 quart (liter) of water to the detergent dispenser.
You can read all of the instructions for this (on page 11 of the .pdf download) here:
http://www.whirlpool.com.au/app.cnt/whr/au_AU/pageid/pgsrvifuhome001
Enter your model number in the box.
Good luck from Detroit, MI, USA.
Jul 19, 2011 | Whirlpool Washing Machines
Frigidaire Dishwasher model FGBD2431KW will not completely drain after wash cycle. What might cause this?
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Jun 15, 2011 | Frigidaire Dishwashers
Kenmore 15652 model. won't drain
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Daniel
Apr 22, 2011 | Kenmore 24 in. 15652 Built-in Dishwasher
Washer not entering rinse cycle tube in front near filter won't drain water no kinks in hose
You may have to remove and clean out your drain filter located inside the cabinet between the bottome of the drum and the pump motor. Make sure you hand bail the water out of your drum prior to removing the drain filter. Your model may have a shut-off valve between the drain filter and the tub, if so turn it to the OFF position to stop the water flow. If you do have this shut-off valve you will not have to hand bail the water out of your tub. After you remove, clean and reinstall the drain filter, be sure to turn the valve back to the ON position.
Nov 26, 2010 | LG WM2277H Front Load Washer
I opend Drain Plug on my Noritz Unit N-069M and didn't find filter on it. Where I can buy that filter?
The filter is frequently stuck in the filter hole on that model. Look for a black plastic washer with a circular hole in the center; that's the bottom of the filter. You can remove it with a screw driver. Put the screw driver in the circular hole, turn it at an angle, and use it as a lever to wrench the filter out.
Jun 21, 2010 | Noritz N-069M-DV, N-084M, and N-084M-DV...
There is something in between the drum and housing. We have drained the washer and cleaned the filter still it is still there.
it seems like the drum will have to be removed to get to the offending object. it is probably stuck between the seal and drum, like a coin.
Aug 08, 2009 | LG WM2277H Front Load Washer
Bosch WET2820 integrated washing machine. Cycle gets stuck on "anti-crease 1". Have followed instructions in manual for unblocking drain pipe, hose and suds pump although problem (doesn't drain...
was a hair clip stuck in the drain pump..
fixed like this:
Use the small draining pipe that is fitted to the filter housing to drain the water down.
Take the filter out from front bottom.
Inspect and remove any debris blocking the drain pump.
et voila! working!
Jul 10, 2008 | Bosch Washing Machines
LG WM2277H - OE error
yes,once you have disconected the power supply.open the filter hatch then undo the screw,this willennable you to remove the bottom plinth,unscrew the three screws that hold housing of pump,remove both the circ pump and the drain ,u will find offending item there
Jul 30, 2007 | LG WM2277H Front Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
