Question about Epson Stylus Photo R220 InkJet Printer
Epson r220 prints mostly red.
I uninstalled it and went to reinstall but lost the Installation CD. How do I get a new one or download one from net?
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
Lost CD-Rom installation disk
Go to the epson website and download the driver from the website.
Aug 10, 2009 | Epson Stylus Photo R220 InkJet Printer
R220 epson printer not printing
ensure u r using original ink cartiges try head cleaning process replace all the ink cartriges
Jan 09, 2009 | Epson Stylus Photo R220 InkJet Printer
My r220 epson will not prit anything
The ink indicator permanently on indicates an ink cartridge problem, (not that the protection counter needs resetting). The status monitor picture of the ink cartridges should show which cartridge is at fault, it will have a red X on it. The cartridge is empty, faulty, or in the wrong position. Alternatively, you may have an internal fault e.g. with the system board. But change the indicated faulty cartridge first.
I have an Epson Stylus Photo R220 Printer connected to a linksys print server, but
Well, The first thing you should do is to try to test of the print server is properly connecting to the printer. Check the linksys printserver manual and look for how to print a status sheel from the print server. Once done, get the IP address of the print server. Go to your laptop and navigate to control panel/printer. See if you have the driver installed or download the Vista Drivers from Epson.com/support. During the installation, it will ask you what connection type your computer uses. cancel out of the installation or choose LPT1 as the port. Once done, go back to control panel/printers.Right click the R220 icon and navigate to properties. Select ports after that and add a new port. Select Standard TCP IP port after that. Once done, the wizard will appear. Input the IP address of the printer and finish the wizard. you should be good to go after this.
Sep 30, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson r220 printer problem
try replacing the black ink cartridge with a genuine epson cartridge.
Aug 18, 2008 | Epson Stylus Photo R220 InkJet Printer
Lost the installation cd
This is the exact link for your printer software just donwload it and reinstall it for your printer http://www.epson.co.id/epson/drivers/driver_download.htm?dc=1&mode=3&m=false&catid=4&pid=1161
Hope that helps..........
Aug 09, 2008 | Office Equipment & Supplies
Red Flashing lights
hi dear
try to resetting your catridge
or here
http://inkjetprinterhelp.us/epsonSSC.html
oke
i hope your problem clear
good luck
Mar 19, 2008 | Epson Stylus Photo R220 InkJet Printer
How do I get my Epson Stylus Rhoto R220 to work with windows vista
I have an Epson Stylus Rhoto R220 inkjet printer for 10 months and i would like to know if its going to work with Vista Windows PC or it won't recognize my printer. How do I upgrade it or get it compatible ?Thaks
Feb 19, 2008 | Epson Stylus Photo R220 InkJet Printer
Mac OS 10.5 Leopard
I had the same problem with an Epson R340 printer and Epson Print CD software after installing Leopard.  Here's what I did.  Go to System Preferences.  Select Print & Fax.  Select the "+" box on the lower left part of the screen.  Select Epson Printer  -- USB and click "Add" and "continue" in the box that comes up (if it does). Now see if Epson Print CD will print to a CD.  If it does, great.  You can now actually go back to System Preferences and Print & Fax and delete the printer you just added by clicking on the "-" box and Epson Print CD will still work.  Now I found another problem with printing. The CD printing is now off center to the right and down, so in Epson Print CD program you have to click on print and from the print screen click on "Position Adjustment" in the bottom left corner.  I've found the perfect position is 3.5 mm up and 3.5 mm left to make everything print perfectly.  Good luck.
Nov 08, 2007 | Epson Stylus Photo R340 InkJet Printer
Epson Stylus Photo R220 InkJet Printer Logo
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
