Dual Dlcd3221 standby problems
When i switch my tv into standyby i have to switch it off by the plug or the main power button on the back of the tv to get it to switch back on, as it's wall mounted having to reach around the back of the tv everytime i want to knock it on or off is causing a problem, it's a dual dlcd32-21 and it also sometimes comes up with grainy colours or negative which switching off then back on again resolves
Joe fix
  • 7 Answers
SOURCE: Unit does not turn off anymore.
Caps in the relay circuit lost value....capacitors in and around the relay need to be checked and or changed....
Posted on Jan 11, 2008
  • 10 Answers
SOURCE: strawberru shortcake tv turns on then right back off
Sounds like the power supply may be going out, or check and see if there is a circuit breaker button on the back. Otherwise there may e a blown fuse that is internal. Don't open the back unless you have training on what is safe to touch as the picture tube can maintain a HUGE electrical charge that can stop your heart if you accidently touch the wrong thing. Sounds like a weak power supply tho. Jay
Posted on Jan 21, 2008
SOURCE: TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Posted on Apr 22, 2008
freetek
  • 5568 Answers
SOURCE: cant switch it on!
Sounds very much like a main power supply that needs a 'kick' to start up. This is often caused by the loss of value of a capacitor in the power supply, one that handles feedback to start the supply initially and carries the signal to shut it down in case of a circuit fault in one of the areas the supply services. Inadequate feedback will make the supply unable to start properly and more likely to shut down even though no fault condition exists. If I'm right, it will get worse and searching for the problem requires an instrument not found in the average home; a capacitance meter with loss measuring capabilities.
Posted on Sep 11, 2008
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Posted on Dec 05, 2008
Tv stuck in standby, red LED is on. How do i rectify this problem??
Could be an open internal fuse or power supply failure
Nov 21, 2017 | Televison & Video
I have a hitachi 50 "plasma that was given to me
First do you see a light indicating that the TV has power? There are two power buttons on the TV (the main power and the regular power button). The red standby light will light up when the main power switch is on. This indicator is just to the left of the remote I/R sensor. You can find the main switch on the bottom front of the tv (it is under the tv forward of the stand). Turn on the Main power if it is not on. Then try the power button on the control panel of the TV again.
Does the standby light change color or blink? (Red is standby, orange is power savings (no signal), blue is on.) If the main switch is on and the standby light doesn't come on, the TV has a problem at the power supply. Try unplugging the unit for a bit (at least 30 seconds) and then plugging it back in. This will reset the internal circuitry. If you see a blinking light, then the TV is reporting a self-test failure. I do not know the codes for this model Hitachi Plasma TV.
The manual for the Hitachi P50H401 TV is available from Retrevo: http://www.retrevo.com/support/Hitachi-P50H401-TVs-manual/id/1233ci869/t/2/ . You will need to enter a code to access the pdf.
I'm assuming you don't have one of the special versions that were intended for large audiences that were only controlled by remote (no control keys on the front of the TV). Remotes.com has the original remote or a substitute remote if you need it. See http://www.remotes.com/remotes/servlet/rs?a=gmi&uuid=13104063628240&smodel=P50H401&brand_pn=HITACHI_P50H401 .
I hope this helps.
Jul 11, 2011 | Hitachi P50H401 50 in. Plasma HDTV
TV DOES NOT TURN ON STANDBY RED LIGHT STAYS ON
Hi Friend,
Check your TV's remote battries. If they are good, then, power off the TV at the main wall socket and unplug the power cord, leave it for 5 minutes. Now, connect back the main power cord, hold the Power On/Standby button on your TV and power then turn ON main switch on the wall. This should resolve your issue.
Thanks,
Shiva
Dec 19, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
TV/DVD unit locked in Standby mode
Did you check the casing for a reset button (sometime it an itty ***** hole)
Hope this helps
Trap
Jan 25, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
Tv lost picture and sound
TRY UNPLUGING SET FROM THE WALL FOR 1 MINUTE. PLUG SET BACK IN AND CHECK. IF PROBLEM PERSISTS TAKE IT TO A QUALFIED SERVICER. UNIT PROBABLY HAS A DEFECTIVE MAIN TOTAL ASSY.
Jan 12, 2009 | Bush 5693D 24" TV
LG 42in LCD Television - turning unit off
The amount of standyby power consumtion is minimal. The only way to turn it off completly is to disconnect the power from the TV. This will however increase your start up time when you want to use the TV.
Nov 28, 2007 | LG 42LC2D 42 in. LCD HDTV
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
