Coby Mp4 player won't function
My Coby MP605-4G Mp4 player just started malfunctioning after i added some videos to it. It was working fine before but after i transfered some videos and disconnected it from my computer i turned it on and when ever i press a key the screen and lights just flicker for as long as i hold down a button. When i try to turn it off the lights flicker also and it does not turn off. It just stays on the main menu screen, lights flickering whenever i touch something. i tried reseting it but it didnt help.
  • mcsmart70 Jan 02, 2009
    allo! moi aussi j'ai le meme probleme. Apres avoir mis des video le lecteur ne fonctione plus, même en faisant reset.mcsmart70
Psionics
  • 236 Answers
SOURCE: TGE MP4 Player Firmware Upgrade
Did you download the correct version of Firmware? There are 3 different types for your model (i'm guessing you have the HB500).
Not too sure if there is a reset button on the player.. If there is, use that..
Otherwise, download the firmware again and reinstall it
Posted on Mar 28, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: Sansa E250 Black screen lighted wheel, wont do nothing else.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
SOURCE: How to unfreeze mp3 player
We have a toshiba gigabeat f20. today it worked fine, listened to it for hoursbefore turning it off. turned it on within a hour to play it and got a blank screen. nothing in the environment could have caused this. battery had been replaced a week before. so, took the case off to opened it and take a look. realized that one of the plug ins for the screen had come loose or slightly lifted inside. it did not totally unplug, just not pressed down tight. pushed it back in. put the case back on. hit the power button and it's back on, nothing that had been previously loaded was lost.
Posted on Sep 20, 2008
  • 3 Answers
SOURCE: ok i bought a coby
At the top of your coby, there is a switch next to the power button. Push it to the right (towards the power button) and then turn it on.
Posted on Jan 01, 2009
SOURCE: coby mp3 player help
You have to convert the files. On the cd purchased with the player comes a conversion program.
Posted on Jan 02, 2009
Put videos
Coby support mp4 video well, you can convert your own videos to mp4 video, then import the video into windows media player, connect your coby player to computer, sync your coby with windows media player, the videos will be transferred to your coby player.
May 08, 2013 | Coby MP620 MP3 Player
What video fomat does it have
As I know, coby supports mp4 video well. If you don't know how to convert video to mp4 video, this step by step guide will help you a lot.
http://www.reviewstown.com/how-to-convert-avi-mp4-wmv-mkv-flv-mpg-youtube-video.html
Jan 02, 2013 | Coby MP828 MP3 Player
SDCard and USB won't play video
format them first,then when you finish adding files to them,finish it like it would be a cd/dvd
Apr 27, 2017 | Car Audio & Video
Video won't load and play on my mp4
You may get the wrong format for your MP4 Player.
So i recommend you to use a video converter to convert the videos you have to the one you need.
i have used this video converter for long and it is really easy to handle.
Go and have a look.
http://www.leawo.com/leawo-video-converter/
Feb 21, 2012 | Coby MP826 MP3 Player
I cannot put video in my coby mp4 player my coby mp4 model is MP601-4G
Hi!
Your player supports only the MTV video file type...
To convert your videos to the MTV file type, use MTV Video Converter OR the bundled Coby Media Manager (CMM) software (if you don't have it, download it from here)!
Detailed instructions on installation/usage of CMM are found on the User's Guide...
If you are satisfied, rate my solution with 4 "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Apr 08, 2011 | Coby MP-C7085 MP3 Player
How can I get my player to show video? It always says invalid format.
Video Format Support MTV
You need a mtv converter ...after you convert your video files from .avi ,mpeg,or any other format...transfer the converted files to your coby player
MTV converter free download .
Mar 15, 2011 | Coby MP620 MP3 Player
How do you put videos on here?
Run the Install for Coby Media Manager when you plug in your Coby Mp4 player
After you install it run the program,, dont have to register,, then onthe side where it says MOVIES, click there, drag and drop video filesthere, then right click on the video you just added and clickSynchronize [Coby Mp4 player has to be connected],, the program willconvert the file to .mtv itself then transfer the file to your mp4player
P.S. If ur vids are not in mtv format, Coby Mp4 player cant recognize them, so you must convert video to mtv files. Daniusfot video converter always enjoy a high reputation, you can free try it to see it it can fix this up.
Feb 11, 2010 | Coby MP-610 MP3 Player
I need to know what kind of .avi file to convert my mp4 and mpg and mpeg videos to in order to have them play on my Coby 705. This is incredibly frustrating!!!! I see why ipod has WON the war!!!!
I came across a post recently,
It mainly about how to convert video for iPod,
Have a look from this ,Hope it can help you more or less!
http://onlinevideodownloader.net/convert-video-to-mp4-for-ipod.html
Mar 21, 2009 | Coby PMP-4330 Digital Media Player
Coby mp705-4g
COBY MP705-4G I USE THIS AND AFTER 5 MONTHS I FINALLY ARE ABLE TO PUT AND WATCH VEDIOS ON MY COBY... dont try anything else this is very simple just down load and do what this dirrectons tells you its really easy ...
Windows Media Any Video Converter
http://download.cnet.com/Any-Video-Converter/3000-2194_4-10661456.html
select add video,click on the video you wish to convert, in the (profile)
slot (select costomized avi movie), in the (video options) slot, click on (video codec)
& (select xvid), click (frame size) & (select 220x176), click on (video bitrate) & (select 768),
click on (video framerate) & (select 30). Now click on (convert). When converted, right click (on the converted video) & (select destination file location)... Now drag and drop the converted video into the video folder of your (Coby mp705 player).
Jul 20, 2008 | Coby MP-C7085 MP3 Player
MP4 player crash
I have a mp3 and video player with touchpad control Model no..(MP-C70950) Manufactured by COBY. It was working fine. Now when i turn it on,screen shows File Sys Err. I tried to format and reset it. But i can not sycronize the media player files in it.
Feb 26, 2008 | Audio Players & Recorders
240 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
