Question about Refrigerators
Refirgerator so is this thermostat something I can fix myself? or do i need to call for help?
  • 916 Answers
You should be able to and most appliance stores sell them with directions included
Posted on Dec 27, 2008
I have an 03 VOLKWAGEN Passat 2.8 4 motion. It keeps overheating! I checked the core and nothing wrong. Changed the thermostat and it still over heats. Now I'm told it might be the water pump. Its fine...
check the water pipes and flexible joints that may have a hole which will drain out the cooling water and this will be known by supervision of the cooling water level
Aug 04, 2014 | 2003 Volkswagen Passat
I have an 03 vw passat 2.8 4 motion. It keeps overheating! I checked the core and nothing wrong. Changed the thermostat and it still over heats. Now I'm told it might be the water pump. Its fine when I'm...
The water pump is a possibility. It could also be a head gasket leak into the water jacket. At idle the pressure may not be enough to overheat the engine, but acceleration would cause rapid overheating.
Ge refirgerator making clicking noise
Sounds like your GE Main Control Board is out. It is a very common problem and easy to change.
Leave a comment on the post if it helped
Jul 29, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Our maytag refirgerator cools but won't get cold.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Apr 22, 2010 | Refrigerators
Tumbler dryer does not get hot
I have a different machine, butthere were only two things thatcould have gone wrong on mine - either the heating element needed to be replaced, or the thermostat died. I bet on the heating element and bought a part and attempted to fix myself. It didn't fix it. We hired a tech. Turned out to be the thermostat thinger,a cheap little part I could have done myself. But, we paid $90 or so and fixed her up.
Jan 11, 2010 | Hotpoint Ultima WD72 Front Load...
Mini refirgerator stopped cooling, interior light
If nothing is running but the light is on you might want to unplug the unit for about a minute. Then plug it in. If it starts up again then do nothing. It just had to be adjusted. If the display shows a er then it could have something wrong with the thermistors. If it shows 2 dashes then let me know and I can try to walk you thru a program to get you backup and running again. If 2 dashes you will have to get to the plug so pull the unit out.
Jul 12, 2009 | U-Line Model: CO1175S01 Compact...
Finding the thermostat polarity
The only way to eliminate the thermostat is to remove and test the 2 connections while changing the settings. Or place a similar thermostat in its place to see the results. Thermostats can stick on or off.
Mar 22, 2009 | Refrigerators
Temp gauge is registering a bit low, thermostat issue
there not hard to change and if it sticks to long it might over heat So ya it is something you could fix yourself
Jan 23, 2009 | 1999 Saab 9-5
Samsung fridge RS2545SH every 7 days freezes fridge coil.
no thermostat in this model but there are thermister it is also on the evaporator (yellow wire)
Aug 13, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
