Question about Acer Aspire 5610 laptop vista combo with office 2003 professionalLX.AY10X.008 PC Notebook
I have an acer small notebook and I want to put office 2003 on it because I own the cds. acer has no cd drive, how do I install office 2003 on it?
  • 741 Answers
You can go to Microsofts website to download but it will be expensive. You would be better off buying an external CD/DVD ROM drive. It is used with a USB so it just plugs right in.Then you will have a drive for later if you need to install something.
Posted on Dec 27, 2008
Installing Windows Vista on new harddrive.
All you need to do is insert the CD into the drive and it will guide you from there.
Feb 15, 2012 | Acer Aspire 5315 Notebook
Need to download Office Pro Edition 2003 to a new notebook, mine the old desktop is not on use. Have the keycode and cd but the notebook does not have for cds. How can I install the program?
Copy the CD to a flash drive or use an external CD-ROM drive. If you don't have either of these, then try copying the files over your network to the other computer.
Jan 06, 2011 | Computers & Internet
My disk drive isnt reading the files on the cd
if your cd drive was able to read cds but cann't now then it is broken... if this is your first time testing and it can read cds but not dvds... then thats the way its made... if it cann't read anything its broken...
Dec 26, 2009 | Acer Extensa 5620 Notebook PC
Turns on but wont go pass the startup screen
Try to put an operating system boot disk in your drive then turn on laptop.
When the screen says press any key to boot from cd/dvd press a key.If it is vista when you do boot from cd it will give the option in the lower right corner to repair-click on this-select repair startup option.if that fails try a re-install of your op sys.
May 31, 2009 | Acer Aspire 5610 laptop vista combo with...
Does anyone have clue about the " Pro.Msi" File
An .msi file is a database of all the files, settings, and configuration information for the associated application. When you install Office on your computer, the .msi file is saved in a hidden folder. Without this file, Windows Installer cannot update your configuration, install optional features, or apply software updates. Office cannot be installed, repaired, or updated if the .msi file is not found.
Why is the .msi file missing? The most likely reason for Windows Installer to require the installation CD is because the saved version of the .msi file for Office has been inadvertently or deliberately deleted from your computer. It is also possible that the file is damaged or corrupted.
Occasionally, changing the drive letters associated with partitions on your hard disk can cause this problem to occur — such as changing drive C: to a different letter or moving the hard disk drive from one computer to another. Other possible causes are a damaged or corrupted hard disk or registry file.
What to do when prompted for a missing .msi file If you are prompted for the location of a missing .msi file, you must provide the original installation CD used to install Office on your computer.
  1. Make sure that you have inserted your Office installation CD into the CD drive of your computer. If you installed Office from a network, browse to the network location from which you installed Office.
  2. Click Retry.
In most cases, these steps should resolve the problem and Office can complete the installation and configuration of the needed component.
default.aspx?assetid=za790050011033I don't have the installation CD
Without the installation CD — or for computers purchased from companies such as Dell, HP, Compaq, or Gateway — you need to provide a repair CD to reset the installation created for your computer by the manufacturer. For information on how to apply the repair or installation CDs, you might need to contact the support representatives of your computer supplier.
In many cases, the files that you need are compressed on the repair CD and must be run by using a special program provided by the computer manufacturer. In some cases, the computer manufacturers might have customized the .msi file or changed the file name.
In situations where you cannot obtain the installation CD, your options are the following:
  • Continue with the existing installation of Office without updating. This is not recommended. Your documents and computer might become compromised from security threats.
  • Remove the installation and reinstall Office by using another installation CD. Removing the previous installation may not be possible in severely damaged systems where the registry is corrupt.
  • Run a repair CD provided by the computer manufacturer. For information on how to apply the repair CD, you might have to contact the computer manufacturer or consult the documentation provided with the computer.
If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. A table that correlates .msi files to Office versions is provided later in this article.
Office 2003, Office XP, and Office 2000 provide the Detect and Repair command. You can find the Detect and Repair command on the Help menu of almost all Office programs. Using this command corrects identifiable problems such as missing files, corrupt files, registry omissions, or damaged registry entries. It replaces the .msi file if it was deleted, damaged, or is the wrong version. Using the Detect and Repair command usually requires you to provide the installation CD for the version of Office currently installed on your computer.
default.aspx?assetid=za011526611033 How to prevent similar problems in the future To help avoid this problem in the future, use the following guidelines:
  • Do not delete hidden folders or files from any drives on your computer.
  • Do not move drives or change their disk identifier (for example, C: to D:).
  • Install all needed applications as Run from My Computer instead of using Install on Demand (available from custom installation within Setup).
  • Occasionally run the Windows Disk Defragment program to repair cross-linked files, recover lost clusters, and remap bad sectors on your hard disk. Any data present in a bad portion of the hard disk is usually lost and commonly associated with physical damage to the disk. This is most likely the result of high-vibration environments, such as the computer being struck, dropped, or kicked.
If you have Microsoft Windows XP as your operating system, consider using the System Restore option to restore your system to a previous configuration. Consult the Help and Support option of Windows XP for more information on System Restore.
Office 2003 .msi files If you do not know which version of Office you have installed, the name of the .msi file requested indicates the Office version you have. The following tables tell which .msi files go with which Office versions.
File name Description accessed.msi Microsoft Office Access 2003 Developer Extensions mui.msi Microsoft Office 2003 Multilingual User Interface Pack (one for each language) muiwiz.msi Microsoft Office 2003 Multilingual User Interface Pack owc11.msi Microsoft Office 2003 Web Components prjmuicwz.msi Microsoft Office Project 2003 Multilingual User Interface Pack Wizard prjstde.msi Microsoft Office Project Standard 2003 pro11.msi Microsoft Office Professional Edition 2003 projproe.msi Microsoft Office Project Professional 2003 ptk.msi Microsoft Office 2003 Proofing Tools sbe11.msi Microsoft Office Small Business Edition 2003 vismuiwz.msi Microsoft Office Visio 2003 Multilingual User Interface Pack Wizard visprolmxi.msi Microsoft Office Visio Professional 2003 Office XP .msi files File name Description dao.msi Microsoft Data Access Object (DAO) lpk.msi Microsoft Office XP User Interface Pack (one for each language) lpkwiz.msi Microsoft Office XP User Interface Pack Wizard ork.msi Microsoft Office XP Resource Kit pro.msi Microsoft Office XP Professional Edition proplus.msi Microsoft Office XP Professional with FrontPage Edition ptk.msi Microsoft Office XP Proofing Tool Kit pub.msi Microsoft Publisher 2002 sbe.msi Microsoft Office XP Small Business Edition std.msi Microsoft Office XP Standard stdedut.msi Microsoft Office XP Standard for Students and Teachers owc10.msi Microsoft Office XP Web Components Office 2000 .msi files File name Description data1.msi Microsoft Office 2000 Premium Edition (all Office products) data1.msi Microsoft Office 2000 Professional Edition (similar to Premium but does not include Microsoft PhotoDraw) data1.msi Microsoft Office 2000 Small Business Edition (includes Microsoft Word, Microsoft Excel, and Microsoft Outlook) data1.msi Microsoft Office 2000 Standard Edition (includes Microsoft PowerPoint, Word, Excel, and Outlook) data2.msi Microsoft Office 2000 Disc 2 (includes Small Business Tools and Publisher) msowc.msi Microsoft Office 2000 Web Components orkdata.msi Microsoft Office 2000 Resource Kit proofkit.msi Microsoft Office 2000 Proofing Toolkit Note In Office 2000, the file name data1.msi does not clearly identify which version of Office you have. In this case, you need to inventory the installation of Office programs on your computer by examining your Start menu entries or click Add or Remove Programs in Control Panel and scan through the list of entries to determine the version of Office that is installed.
Zulfikat Ali
Jan 24, 2009 | Microsoft Office 2003 Pro (269-07387) for...
Acer 5315 elock
Go to device manager and click on your dvd/cd drive. Double click on this and enable the drive.
If driver is missing, go to Acer's website and download your dvd/cd device driver.
Dec 08, 2008 | Acer Aspire 5315 Notebook
Cd drive Acer Extensa 4420
After inserting the cd into the drive click on "My computer" and then click on the leeter of the cd drive. this will show files on the cd.
There should be a file called setup. Just double click it to start installation.(double clicking is clicking on something twice quickly in succession).
Oct 11, 2008 | Acer ASPIRE 3680-2022 Notebook
I misplaced the Office 2003 CD. If I borrow someone else's can I use my product installation product key on a different CD?
The information on the CDs is effectively the same, as long as the CDs are of the same version (Office 2003 has at several sub-versions, like Student and Teacher, Small Business, and so on). If you still have your valid MS cd-key, you can install from a different disk.
Dec 12, 2007 | Microsoft Office 2003 Pro (269-07387) for...
Unwanted Auto Interruption of Application
It seems as though an MS Project installation was accidentally stopped during installation of Office or something and is looking for the installation source, such asthe Office CD or a network drive/resource. Do you have the Office 2003 CD and is it the Pro version?
Nov 28, 2007 | Lenovo Thinkpad T60 Notebook
Acer Aspire 5610 laptop vista combo with office 2003 professionalLX.AY10X.008 PC Notebook Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
