Question about Singer 7466 Mechanical Sewing Machine
Needle & Bobbin out of sync
I was trying to sew through very thick fabric. The machine "jammed" and "beeped" at me. Now, the needle hits the bottom of the bobbin case before the needle bar is at the lowest point of its downward stroke. There is a white plastic disc in the bottom of the bobbin case, and the needle is striking it. If the bobbin case continues its revolution, the needle is pulled to the side or bent, and leaves a scratch on the plastic piece. This is the first time I've used my new machine. I hope you can help me.
  • 4 more comments
  • Anonymous May 13, 2009
    So how do you reset the timing? Mine is a Singer 7462 with the same problem.
  • Anonymous Mar 13, 2014
    needle hitting bobbin casing
  • Anonymous Mar 17, 2014
    Passport machine needle jams, bobbin case spins out of place must remove it to reseat it correctly.
  • Anonymous Mar 18, 2014
    needle keeps hitting bobbin case and will not sew. this is a new machine
  • Eureatha Fugghett Apr 05, 2014
    how do you reset the timing? my machine is a model 4228 inspiration
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 192 Answers
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Posted on Nov 14, 2007
  • la_sac May 12, 2011
    So, how does one fix this?
  • radcal May 12, 2011
    My best advice, take it to Singer repair center.
    I normally find a loose screw somewhere in the machine when this has happened. Remove the bobbin case, put fingers in hook and hold it firmly so it can't turn and rotate the handwheel. If the handwheel can turn while the hook is stationary, you will need to remove the covers and find what has come loose to allow the movement. It's a little complicated to explain. Save the grief and either return the machine for another or have someone set it for you.
I have a ULT2002D Brother sewing machine that keeps catching the thread. From the needle and winds around the bobbin causing a jam. What Can I do about this and can I fix it myself
Sounds like there is a hook of metal either on the needle or the bobbin case (sometimes happens when trying to sew something very very thick and the needle bends slightly and hits the bobbin case.). Suggest changing needle 1st, if this is not the problem, take out bobbin case and look and feel with fingers, if there is a mark where the needle has hit just use your own steel nail file and file the area very gently to remove the bur. Good luck!
Oct 11, 2017 | Brother Sewing Machines
Bobbin thread will not catch. Was sewing fine. What do I do now?
Try a brand new needle--old damaged/bent needle will frequently fail to connect with bobbin thread.
If that does not resolve the issue, most likely the machine has been knocked out of time--most often occurs when the needle hits a pin or is deflected by thick fabric so it hits the needleplate or something in the bobbin area. You can search the internet for sewing machine timing or take it for service.
Jan 02, 2017 | Sewing Machines
What does it mean when the motor jams and the needle is hitting the bobbin case?
Make sure the needle is put in the right direction and a new one. Also, check the bobbin to make sure it is one that fits properly.
Your sewing machine is likely to be out of timing. This means the needle goes under the throat plate to pick up the bottom thread but it is going at the wrong time. The bottom and top have to be synchronized. This is a problem that usually requires the replacement of gears. Anyway, it isn't a home fix problem.
Oct 05, 2016 | Brother BC-1000 Computerized Sewing...
Sewing machine jammed with needle down and material can not be removed. Help I can break the needle, I really just want the fabric out.
loosen the needle clamp screw then you can pull the needle out with pliers not damaging any of the machine or bobbin area .
Oct 30, 2015 | Singer Sewing Machines
My top tension is off. It was factory set for 5. I checked needle size, bobbin tension, thread, and for any build up of fuzz. I have a White Jeans machine. If I turn the top tension dial to 7, the bot
Sandra,
If the needle jams when sewing over thick items, it may be you have a dull needle? Not all machines can hem blue jean material without a hand to help the flywheel around, through the doubled over seams.
Additionally, when sewing the basic two pieces into one piece, start with the presser foot ON the fabric about a half inch sewing in reverse first, backing up to the fabrics edge and then proceeding forward through your fabric.
Fabrics too heavy or too light, are the common issues with home and commercial sewing machines.Knowing your machine and how to operate it; will get you through these "issues" when sewing.
Cheers, Happy New Year!
Kelly
Embroidery Services
San Diego, CA
Jan 01, 2015 | White Sewing Sewing Machines
My Fashion Mate 6160 beeped and stopped sewing & automatic threader doesnt work
if the machine still sews a straight stitch on top of fabric & also on bottom then it should be fine..
it's possible that the thick fabric, needle, & thread were not a compatable combination.
but also some sewing machine are not made to sew thick or heavy
fabric
but having the machine serviced would be a good idea & help to know why the needle thread is not working
Jan 17, 2012 | Sewing Machines
Needle hits
Does not matter what machine you have from a 50's straight stitch to a newer model right out of the box. If your needle is hitting you are out of time. It needs to be reset and on that I can not help you as it is mechancal on the underside. What the needle is hitting is the bobbin arm.
When the bobbin arm swings around it picks up the top thread and loops it over the bobbon thread then releases the threads together for the loops and swings again for the next thread. When you hear the needle hit it is hitting this swing arm. That needs to be adjusted and that is called timing.
Open the bobbin case and turn the needle down by hand. You will see the needle as it goes through the throught plate down the catch the bobbon thread. You will see it hit the arm.
This needs to be backed off or set forward. Takes a trained person as I have never been able to do it myself. This happens when you sew to thick of a fabric, or go over several seams from light to thick. Or is you are pulling the fabric. If you head a CLUNK when it started then that is what I think it is.
Dec 18, 2010 | Euro-Pro Shark 9110 Sewing Machine
Bobbin holder seems to be broke and needle breaks
Here are several things to try.
* When you insert your new needle, make sure it’s positioned correctly (usually with the flat side away from the bobbin, but consult your manual), that it goes all the way into the holder, and that the screw is securely tightened.
If there doesn’t seem to be a problem with your needle, try the following:
* Check your pressure foot and make sure it’s attached securely.
* Change your pressure foot Your pressure foot may be bent, causing your needle to hit it.
* Don’t sew over pins a needle that hits a pin can break. Always remove the pins from your fabric before they reach your needle.
* Don’t pull your fabric as you sew. You could be bending your needle back, causing it to hit your needle plate instead of going into the hole. Just guide your fabric, letting it feed on its own.
* Check your needle plate and make sure it's securely in position.
* Change your needle plate. If you’ve been using a straight stitch needle plate (a plate with a small hole, often used for sewing fine, delicate fabrics), switch to a needle plate with a wider hole.
* Check the position of your needle. Sewing machines with zigzag capability allow you to adjust the position of your needle – right, left, or center. If your needle is not positioned correctly, it may be hitting your needle plate or pressure foot.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin. There could be a nick along the edge of your bobbin spool that’s catching your thread as you sew.
Also, before you start to sew a seam, hold the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope these solutions help you.
Sep 20, 2009 | Brother XL-2230 Mechanical Sewing Machine
The bottom stitch jamming up
seems like the same problem I haad so I tried changing the needle looking for burrs or bent needle. maybe a piece of broken needle in the bobbin holder. or maybe the fabric requires a certain needle or the needle size is too big for the fabric you are using. or the machine needs cleaning I have started using canned air for this. and then if this fails then you should note the tension position and then try adjusting it one point at a time. always puting it back to where it was to start with good luck
Feb 24, 2009 | White Sewing 2999 Mechanical Sewing...
Singer 7466 Mechanical Sewing Machine Logo
2,193 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
