Question about NetGear WGR614 Wireless Router
I am having problems connectin, the adress has changed used to be routerlogin.com
  • myls Feb 02, 2009
    can not connect the NETGEAR WGR614NA using smart broad band
    President:
  • 623 Answers
The correct address is: http://www.routerlogin.net
Posted on Dec 28, 2008
How do I set the network in my netgear N300 for my laptop?
Visit http://www.routerlogin.com. You can also use the following if the http://www.routerlogin.com does not work: Enter the following default login credentials:
  • Username: admin
  • Password: password
Then go to Wireless and chose Name (SSID): and Passphrase :
Jul 04, 2014 | NetGear N300 Wireless Router
Can't get a link when trying to turn a Netgear router WGR614v8 into access point with a xfinity SMCD3GNV as the host router.
Log in to your NETGEAR router by browsing to
http://www.routerlogin.net/ or http://www.routerlogin.com./
Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed.
If you cannot log into your router:
Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults.
however, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection.
Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and Clicking Apply.
If there is a small hole in the front or back of the router push a hair pin in to reset to factory settings.
May 20, 2013 | NetGear WGR614 Wireless Router
Install without cd
Hai,
Go to your browser's adress bar and type routerlogin.net.
Now you will be asked to enter username and password.The username is 'admin' and password is 'password' itself.
Now enter all the settings in their places as said by your ISP.
Aug 07, 2011 | NetGear N150 / RANGEMAX 150 Router
Forgot username & password for netrouter wgr614v7
How do I log into my router?
To log into a NETGEAR router:
  1. In your Web browser, navigate to the router login page. By default, one or all of the following URLs should work:
    • http://www.routerlogin.net or http://www.routerlogin.com
    • http://192.168.1.1 or http://192.168.0.1
    Note: You can sometimes find the login URL on a sticker on the bottom or back of the router.
  2. Enter the username (admin) and the password.
    • The default password is password, or for older routers, 1234.
    • If you have already changed the default password, use the password you assigned the router. Passwords are case sensitive.
    • If you have already changed the password and do not remember it, you have to reset the router to factory defaults in order to use the default password. Resetting a router to factory defaults erases all changes you have made to the router's configuration files.
This information is extracted from www.netgear.com, for learning purpose only.
Hope this will be useful for your question.
Good luck. Remember to rate my answer please.
Jul 13, 2011 | Computers & Internet
Trying to connect netgear wgr614v9 router to new toshiba computer with windows 7 ....setup says unsupported operating system....what do I do
As netgear setup disc doesnot support Win 7.
U need to manually setup the netgear product
-- hard resett the router using a restore factory setting hole on the back of the router
-- open the netgear router page using www.routerlogin.com
-- Username - admin , Password - password
-- run setup wizard
-- if it detects dynamic ip then press next
-- and on the left u will see wireless settings under setup .
-- secure the network using WPA_PSK(TKIP)
-- and then apply .
In case if it will detect static or fixed ip .
Then click on " Basic settings "
-- Under router MAC address
-- select "use computers MAC adress "
-- Apply
-- And then Powercycle the network..
-- And u will be able to go online ..
Jan 02, 2010 | NetGear WGR614 Wireless Router
Browser can not download router login.net site.
Which browser are you using (IE, Firefox)?
Which router model is it?
Try one of the following addresses:
  • http://www.routerlogin.com
If this did not fix your problem or you have any more questions, just come back here and leave a comment with the details I asked above - I'm happy to help.
Aug 09, 2009 | NetGear Computers & Internet
Cant connect to internet
Hi Keshavm,
Reset the router using the reset hole on the back panel of the router for 10 seconds.
Do not use the CD for installation. Instead follow the steps below:
1. Connect the modem to the internet port of the router. Connect the computer to the one of the 4 lan ports of the router.
2. Access the router using http://www.routerlogin.com or http://192.168.1.1
3. Login using username of admin and password as password.
4. Click on basic settings in the left hand side menu.
5. Under router mac address select use computer mac address and click apply.
This should do the trick. If not then turn off the modem and the router and then turn them back on. you should be online by now.
If not then call me at 9891323541 (Delhi, during working hours) and I will be glad to help u.
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpgmoz-screenshot-3.jpgmoz-screenshot-4.jpg
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 10, 2009 | NetGear RangeMax NEXT WNR834B Wireless...
Fixed IP adress problem
You can change it but it looks tricky, when scroll for the ip address hit go then use and up and down buttom to change it, you have to change the numbers too by using up and down buttoms after you finish, hit ok.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Nov 03, 2008 | Kyocera Mita FS 1000+N Laser Printer
Unable to access the router for manual setup
open a web browser and goto http://192.168.1.1 the default password should be admin and the username is admin too
Nov 09, 2007 | NetGear RangeMax WPN824 Router
NetGear WGR614 Wireless Router Logo
404 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
