I am trying to connect an external monitor to my legacy PowerBook G4 laptop.  I have the original video adapter dongle that Apple provided, which goes from digital video to VGA.  I've tried different resolution settings on the mac, and I've tried a couple of different flat panel monitors, but none seem to be compatible--at least, none seem to be able to detect and match to the Mac's resolution. The basic symptom is this: on the flat panel monitor, all I see is a small portion of the desktop--I can tell, because I can see the custom desktop pattern from my mac--but I can't see the system menus or hard drive icon, at all. The issue is complicated by the fact that the laptop's original screen no longer works... so I can't try to adjust resolutions while the external monitor is connected.  The best I can do is connect the laptop to the only monitor that half-way works (my Vizio HDTV), change the computer settings there, and then try to reconnect to the external VGA monitor. How can I get this to work?  Any advice would be appreciated.
    Scholar:
  • 51 Answers
Since your laptop's display has a problem, that could indicate trouble elsewhere in the computer that is preventing you from adjusting your resolution properly. In fact, a shrunken display points more to a problem in the video processing, not in the display itself.
Posted on Dec 27, 2008
Lg smart tv
G$ powerbook will have a high-density video connector providing (usually) VGA and DVI,
All you have to do is to choose the relevant adapter and connect the two units together with a suitable lead.
Jan 24, 2014 | Apple PowerBook G4 Mac Notebook
Tip
LCD Display Problems with Apple 15" PowerBook G4 Aluminum 1.25 GHz Mac Notebook
During boot-up, Apple logo heavily pixelated. After boot-up, display a riot of colors and vertical lines with nothing readable. External monitor works well
I'll appreciate any input.
~ JO
on Feb 08, 2008 | Apple PowerBook G4 Mac Notebook
I don't know how to connect an external modem to my PowerBook G4 12
You need an Apple modem.
https://www.google.co.uk/search?q=apple+usb+modem&espvd=2&source=lnms&tbm=shop&sa=X&ei=SyT2VN7mE9KXavCJgng&ved=0CAcQ_AUoAQ&biw=1920&bih=971
Jul 28, 2013 | Apple PowerBook G4 Mac Notebook
My 15" Powerbook G4 screen is half blank - it sometimes shows lines or has some blank spots but it's always gone away. This time it seems stuck. What to do?
Hi There,
If you can get your laptop connected to an external monitor it will do the main troubleshooting for you. With it connected and set to display on the monitor, the 2 options below are pretty solid;
1. If the monitor shows your nomal desktop display without any distortion or lines, etc, then you can be fairly certain your LCD screen panel on the laptop is just wearing out.
2. If the monitor shows exactly what the laptop does, i.e., same exact problems, then it means that the Video chip on the logic board is about to fail and you'll have todecide whether to repair or upgrade to a newer machine.
I wish you the best.
Sep 08, 2010 | Apple PowerBook G4 Mac Notebook
15" PowerBook G4 Aluminum 1.67 GHz LCD Display (p/n 1002587) (661-3749 1002587) Mac Notebook: I've a PB G4 1.25Ghz, since few weeks, when I'm tr...
Try replacing the inverter board. If that don't help then the next step is the back light, but replacing it is a bi.ch, so most people just replace the whole screen. Also, check that the video cable wire is not crimped/cut and securely fastened onto the logic board.
May 17, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Display problem
There are severals ways to determine what component is at fault, through some of them may require equipment you may not have on hand.
If the lines move, appear, and disappear as a result of changing the hinge angle, the problem is most likely in your LVDS cable, which is not an expensive part.
If they don't, then you need to attach an external monitor using the short white video dongle that came with your PowerBook. If the lines also show up on your external monitor, your logic board is at fault, which is an expensive fix and probably not cost-effective for a machine of this vintage. If the lines show up on the built-in LCD but not the external monitor, the problem is with the LCD panel itself, which is a medium-expensive part.
Apr 02, 2010 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
How to connect my ibook g4 mid 2005 to an lcd monitor
http://support.apple.com/kb/SP43
From the specs page "Video mirroring supports VGA video out to an external display or projector (requires included Apple VGA Video Adapter) and S-video and composite video out to a TV or VCR (requires optional Apple Video Adapter, sold separately)."
-=/ Daft Tech /=-
Oct 22, 2009 | Apple iBook G4 Mac Notebook
Yellow vertical lines on powerbook g4
Never a good sign.... usually means that your video adapter is shot.
Most laptop video is built on the motherboard, so that would entail the entire motherboard being replaced. Any chance it is still under warranty???
One other thing it could be... do the lines chnage at all when you tilt the screen back and forth? If so, it might be a loose connection between the moterboard and the monitor. That would be significantly cheaper to fix!
Oct 15, 2009 | Apple Powerbook G4 17" 1.67 GHz SuperDrive...
Apple Titanium Laptop
This happens, and unless your startup disk is locked up and needs some swap space, it's just a matter of a screen whose time has come.
Apr 29, 2009 | Apple PowerBook G4 Mac Notebook
Computers & Internet Logo
61 people viewed this question
Alun Cox
David Payne
David Payne
