Question about Kodak EasyShare One Digital Camera
Kodak z1012 My video is jerky just all around bad, its better when run through Quicktime but still herky & jerky. My thought is need an H.D. video card. Please tell me what you think.
  • s_renz Dec 28, 2008
    Have kodak z1012 my video is herky jerky kinda slow. Works better when run through Quicktime Player, but still not that good. Any solutions
    Genius:
  • 1,239 Answers
Hi Most Kodak video's are either motion jpeg, or mp4 and will usually play with Quicktime.
Posted on Dec 28, 2008
    President:
  • 2,110 Answers
Actually u need not to buy a card..you just need better digital camera for good video capture quality...
  • 2,427 Answers
I think thats the settings are bad for the video,, or the divers are missing or not installed propperly.
If you mean the fideo you recorded from the camera, check the setttings like resolution, frame rate,, dvd quality id 720 x 480 @30 fps
To check the drivers
right click my computer , select properties, select hardware, then device manager,, look for anything highlighted yellow,, a yellow question mark and a tab labeled unknown,, you see this look ate its name its normally VGA or display then its related to the video drivers reinstall them. use the cd that came with your computer, download them from the manufacturer or use a program called driver magician.
  • 6,487 Answers
Try first a different video like VLC or videolan player you can download it and its free and also check if your video resolution of your computer is high if not try to change the video settings of your computer and set it to much higher...
  • 10,594 Answers
I think you need latest model camera having good writing speed on memory card.
Ordinary Digital cameras are not fine in video mode due to frame rate and writing speed over memory card.
    Genius:
  • 1,550 Answers
Yes you are correct you need to video card .
Posted on Dec 27, 2008
Thunderace running poorly up to 3500 revs then it clears.
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
3. Spark plugs in bad condition or partially fouled.
4. Spark plug cables in bad condition and leaking.
5. Spark plug gap too close or too wide.
6. Faulty ignition coil, module, and or sensor.
7. Loose, dirty, or corroded ignition module connector at crankcase.
8. Faulty CKP or CMP, MAP, ETS, ATS, TPS, O2 sensor.
9. Intake air leak.
10. Water, dirt, or rust in the fuel system, carburetor and/or filter.
11. Fuel tank vent system plugged or carburetor vent line closed off.
12. Vacuum line from intake manifold to fuel valve is broken, cracked, pinched, or missing.
13. Carburetor controls misadjusted.
14. Damaged carburetor.
15. Incorrect valve timing.
16. Weak or broken valve springs.
17. Damaged intake or exhaust valve.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
bike runs rough at low rpm not herky jerkies
http://www.wristtwisters.com/forums/f322/919-runs-rough-around-2500-3500-rpm-30943.html
http://www.kawasakiversys.com/forums/9-technical-discussion/72090-fi-light-running-poorly-low-rpm.html
http://www.syn-ack.com/thunderace/files/data-sheets/yzf1000.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 26, 2016 | 2002 Yamaha YZF Thunder ace 1000 R
My sound has a herky jerky tempo. How can I troubleshoot?
herky jerky tempo?
that is an interesting description. If it sounds like its kind of pulsing, then you may have a bad wire or if you use a 3.5mm headphone plug for any of the connections, it may not be inserted properly or all the way. that can cause phase cancellation effects like you are describing.
Sep 02, 2015 | Bose Solo TV sound system - Black
I have an 8.1 pixel kodak gital camara. I also have vacation and video's I took; however, I have tried to play them in windows media player, but it doesn't recognize Kodak. What can I do to play my kodak...
KODAK NOTE: APPLE QUICKTIME Player is required for some software features. Visit APPLE to download the latest version of the QUICKTIME Player.
http://www.apple.com/quicktime/
Feb 11, 2011 | Kodak Easyshare C813 Digital Camera
How to replace the lcd screen on a kodak z1012
Unfortunately theres No way to replace the LCD, You need to call a repair center to do this LCD is not screen is not available on the market. You can call kodak toll free to process repair for your camera 1 800 235 6325
Nov 09, 2009 | Kodak EasyShare Z1012 IS Digital Camera
I have a stx38 riding lawnmower. The drive is herky jerky in forw
I have seen this problem on other tractors. It is caused by a loose or sticking drive belt between the engine drive pulley and the transmission. There is an idler pulley between them that is spring loaded to keep the belt tight. If the pulley bearings froze so the pulley doesn't spin, or if rust or a broken spring prevents the pulley from swinging over enough to keep the belt tight it would cause the problem.
May 05, 2009 | John Deere Garden
Kodak EasyShare One Digital Camera Logo
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Parshiv Luthra
Are you a Kodak Camera Expert? Answer questions, earn points and help others
