Question about Dell XPS 410 PC Desktop
Raid failure so my dell desk top had a raid array failure. i replace the raid drive, now windows won't load any sugesstions? My Dell XPS 410 just reported a RAID 1 degrade. What is this? I have two drives, I use Norton Ghost on D: for backups. I never heard of RAID. Do I need this? My computer seems to be working just the same as before.
    Problem Solver:
  • 7 Answers
The only thing RAID 1 does is make a real time backup of everything you do in real time. Its like having a mirrored hard drive. You dont really need it per say.
Posted on Dec 27, 2008
XPS-410 needs to have MCE 2005 Rollup two SP3 replaced by Windows 7 64 bit. Too many problems to list currently but will work limited programs
Not sure what you are trying to do. If you are trying to convert 32 bit to 64 bit Apps, try going to manufacturers website to look for drivers.
Win 7 will actually find the best drivers for your devices.
May 06, 2014 | Dell XPS 410 PC Desktop
Drive replacement and rebuilding Raid 1 on a Dimension XPS Gen 2
Did you format the new drive? Formatted size must be the same or bigger than remaining drive.
Mar 07, 2014 | Dell Dimension Computers & Internet
Drive replacement and rebuil ding Raid 1 on a Dimension XPS Gen 2
Hmm,tricky, I think your best bet would be to save old drive and do a complete new programme install hopefully you have the discs, then once setup and running, connect old drive as a backup and transfer data you require, there may be a better way, this is what I would seriously consider.
Raid failure on Dell Dimension XPS 410 PC
A flag will pop up that says you RAID volume is degraded. Down in the task bar area.
Jun 22, 2012 | Dell Dimension 8400 PC Desktop
Trying to restore to factory settings. i pressed f8 but option "repair your computer isnt there"
try cntrl + F11 at start up
WHAT CAN CAUSE PC RESTORE TO FAIL?
If the hidden DSR (Dell System Restore) partition is removed
If the MBR (Master Boot Record) is modified in any way (such as if you load the Vista Upgrade over XP)
If you change the MBR but the pointers to the DSR partition are left, the DSR will boot, detect that the MBR has changes, and flash a screen that informs you that the MBR has changed and that image restore will not run
If you create additional partitions, changing the MBR, Dell PC Restore will be disabled to prevent it from overwriting these partitions that may contain critical data during a restore operation
If you add a second SATA drive and migrate to a RAID array using the Intel applications accelerator in windows, running PC Restore will put the image back on C:\, but the system will not boot since the boot sector is looking for the ATA driver (factory image) and the bios is looking for the RAID driver (migrated configuration)
If any of these occur, you cannot set the system back to Factory condition. You must manually load the operating system, drivers, and all application software.
Mar 27, 2012 | Dell XPS 410 PC Desktop
I have a Foxconn LS-36 Revision A01 Motherboard. The Model number is: CN-OGC375-13740-5AG-00CU. (The first O might be a 0). At any rate this MB is on a Dell XPS 600 unit, which has died and I have a Raid 0...
Dell has proprietary motherboards, so most retail mobos out in the market would either not fit into the chassis. if the system is still in warranty. call in for a replacement mobo. otherwise try reaching their out-of-warranty dept/ spare parts dept.
Feb 09, 2010 | Dell XPS 600 PC Desktop
The Dell 2950 Server we have cannot reboot the disc drives
The raid may be fine you need to reinstall the OS.
The best way is to drop the raid array astablish a new raid array then install you new OS on a new raid array.Very nice server you have.
Oct 28, 2009 | Dell PowerEdge 2950 (becwfk1_6) Server
How can you remove a raid 1 setup so that I can use the extra storage, without loosing data on one of the drives?
Unfortunately if you remove Raid or change to a different format of raid you will loose data on the drive. If you absolutely have to change it you will want to back up all pertinent data first.
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
Oct 23, 2009 | Dell XPS 410 PC Desktop
Raid failure
Not a lot of details, but here is some basic information, assuming you have a Dell with Integrated RAID
Dimension 9150/9200 and XPS systems have RAID, depending on the model the exact troubleshooting differs. At boot, after the Dell screen, you should get the RAID status listing. RAID 0 will either be normal or failed. Raid 1 can be normal, degraded for failed.
If the RAID array was RAID 0 and one of the drives failed, then all data is lost and you'll have to create a new array then reinstall Windows and drivers
If the RAID array was RAID 1, then you may need to add the new drive to the Array, CNTL+I or CNTL+N at boot (Depending on the system model) add the new drive to the array and reboot. If the system still will not boot to Windows, then you may have a software error too with the OS.
If during troubleshooting, the array was broken in the RAID BIOS, then the array will need to be recreated and Windows/Drivers reinstalled.
Jun 11, 2008 | Dell Dimension 2350 PC Desktop
Dell XPS 410 PC Desktop Logo
362 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
