Question about Dell Inspiron 1521 Notebook
About hooking up speakers correctly
So...I just spent probably a good hour on the phone with Dell...it was a wild goose chace only to find out that I need to call another number Monday to get the information.
I suppose yes I could wait until Monday....
But this has been a problem for a long time, and I am not sure if perhaps you might be able to help me out.
And also help me understnd why it's only recording in one speaker.
Thank you. :)
David Mathieson
You probably have been hacked.
May 23, 2017 | Computers & Internet
I have a Poulan wild thing 4018. Just replaced the main frame. Had to take apart the whole saw almost. Now the saw will crank but runs at very high speed for a few seconds and then quits. I can goose...
Make sure youmhave connected the primer hoses correctly, the shorter of the two connections on the back of the primer ( suction ) goes to the carb, this pulls fuel from the carb, the longer connection dumps fuel back to the tank, if you removed the cylinder end cap, you need to re seal this to the cylinder with instant gasket, also make sure the air tube between the cylinder and carb is correctly seated.
Jun 29, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Van drives 15//////21 miles then goes into limp mode
this is not a speaker and subwoofer fault.. sounds like its a problem with the vans engine management computer. the likely cause is a faulty sensor somewhere. or it may just be that there is a fault in the engine...
only real way to tell (without loads of swapping sensors on a wild goose chase) is to take the van to a garage and get it plugged into a diagnostic computer. that should tell you where the fault lies
Sep 01, 2010 | Car Audio & Video
When plugged into my tv they are not very loud, why please
Probably because your TV does not have a built in speaker amplifier. You'll need to hook up a small amplifier to your speakers. Hook up audio cables to the TV AUDIO OUTPUT and then to the INPUT of the amplifier. Hook the speakers up to the AUDIO OUT or SPEAKERS OUT on the amplifier. Probaly have to take a trip to a place like Radio Shack to get the correct cables.... Good Luck.
Nov 22, 2009 | Harman Kardon Harmon Kardon SoundStick II...
I need alfatel pcsouit software
Get the real company name, URL, phone number and software and search for it on isohunt. If you can't contact the company or its successor and it's not on isohunt, you were on a wild goose chase anyhow.
Aug 06, 2009 | Computers & Internet
I have dell speakers hooked up to my dell pc but NO sound.
  • Ensure the connection first if the connectors are hooked up to the correct port.
  • check if the speaker is receiving the power there should be an indicator lit up
  • If you have an integrated sound card make sure they are not disabled in BIOS.
  • Then check if the sound drivers are properly installed.
  • check the volume control to ensure if mute is checked(uncheck it) also ensure the volume level it needs to be set to a level so that it's audible to you.
  • Do check the speakers with another devioce to ensure the speakers are fine and working.
  • FOR MORE SPECIFIC INFO PLEASE PROVIDE THE MODEL AND BRAND DETAILS OF THE PC AND SPEAKER AND OS
Feb 21, 2009 | Dell Audio Players & Recorders
How do i reinstall my dell speaker? i deleted them off cp. my bad
The speakers are not the sound device, the sound card is. You ust select the sound device that is installed in the computer. If you PC is a Dell, go to Support.dell.com and enter your service tag in the downloads section. download the latest audio driver for your PC and it should reset everything to the correct parameters.
Good Luck!
Jan 05, 2009 | Dell A215 Computer Speakers
Dell no sound
Guess I am not the only one with this problem. Seems to be something Dell planned for us consumers to by another tv from them.... NOT!
Mar 25, 2008 | Dell W3201C 32 in. LCD Television
Sound Problems on my Dell
It should be having onboard sound card, check from Bio's setup whether the Audio is ON. also check in control panel sound and media devices and check the volume maybe it's very very low or on mute. Also try with other speakers
Feb 28, 2008 | HP JBL Platinum Computer Speakers
Motherboard sound and old speakers
what really matters is the quality of the usb speakers. check specifications such as wattage first and find reviews if possible. however usb speakers will probably not come close to separate speakers. i'd recommend buying a cheap sound card ($20 or so). these work great overall. $20 spent on a sound card will be a better trade off than $20 spent on speakers. just use your old speakers with the new sound card and you'll have plenty of power. after this i'd recommend headphones as they work great in this case. finally moving the sound card would probably work fine, but i have doubts.
hopefully that helped
Dec 30, 2007 | Dell - 0089D Sound Card
Dell Inspiron 1521 Notebook Logo
35 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
