Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door will not go down
I can only make the door go down if I hold the push button down.
  • 1 more comment
  • cvanthomme Dec 30, 2008
    Is there a way to take the sensors out. I disconected them and tried to jump out the wires but without the wire diagram I don;t know for sure HOW to jump it out.
  • Anonymous Dec 30, 2008
    I have the "AccessMaster" version of the Liftmaster garage door opener. The door will only go down if I hold the wall button down until it completely closes. If you try to use the remote or just push the buttom, it will reverse and give the five flashes which indicates that there may be an obstruction.
  • ray2751 Dec 31, 2008
    my liftmaster garage door will only go down if i hold the button on the wall down. any ideas
    thanks
I used to work for Sears & Lift master made our openers. The sensors MUST be connected for the opener to work. If you disconnect them, it thinks there is something in the way.
Posted on Jan 01, 2009
I UNHOOKED THE SENSORS ON MY DOOR AND IT STILL WONT GO DOWN UNLESS I HOLD THE BUTTOB ON THE WALL IN. ANY IDEAS
Posted on Dec 31, 2008
    New Friend:
  • 45 Answers
Your sensors may be bad. the little eyes on either side of the door
Posted on Dec 29, 2008
My garage door all the sudden stopped going down when I push the button once...I have to hold it down
SEnsor issue. If not hooked up properly or something is in the way, the door will not close unless you push and hold button till it closes.
Aug 28, 2017 | Building Materials
Why does the power window button blink on and off and the automatic feature doesn't work in the 2008 Toyota Sienna?
NOTE:
Anytime the batteryterminal has been disconnected, please initialize the driver's door power windowand front passenger's door power windowafter reconnecting the batteryterminal.
With ignition switchin the "ON" position, do the following:
1. Push down and hold the driver's door power windowswitch to completely open the window.
2. Pull and hold up the driver's door power windowswitch until the window closes.
Continue holding the switch for approximately one second until the switch changes from blinking to a constant illumination.
3. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
At this time the power window switchfor the passenger's door windowshould be blinking.
4. Push down and hold the passenger's door power windowswitch to completely open the window.
5. Pull and hold up the passenger's door power windowswitch until the window closes.
6. Check for proper operation of the "one-touch open and close" function by fully pushing the switch briefly to the "DOWN" and "UP" positions.
Feb 09, 2016 | Toyota Cars & Trucks
I push the button and the door goes up but i push it to go down and it stops and the light starts blinking but it will go down if i hold the button until its all the way down
holding the button over rides the safety and is not advised until you know the door is free from obstructions and afe to operate. disconnect door from motor and be sure it operates smoothly. reconnect and check safety eyes at bottom right and left of door tracks. should be green and yellow lights( liftmaster) check the downward pressure setting on the rear of motor. it may need to be increased slightly
Oct 16, 2014 | Building Materials
Door goes down and when it stops at botton, it turns and goes back up ??? Need adjusting ..How can I adjust???
Adjust the position of the door by using the black and purple buttons. Black moves the door UP (open) and purple moves the door DOWN (close)
Setting the up position: 1. Press and hold the black button until the LED starts flashing slowly, then release. 2. Push and hold the black button until the door reaches the desired UP (open) position 3. Push the door control or programmed remote control. This sets the Up (open) position and begins closing the door. 4. Immediately when the door begins to close press and release the black or purple button. This will stop the door Setting the Down position: 5. Push and hold the purple button until the door reaches the desired DOWN (Closed) position. 6. Once the door is closed, If there appears to be too much pressure on the door, you may toggle the door back and forth using the black and purple buttons to reach the desired closed position. 7. Push the door control or programmed remote control. This sets the Down (closed) limit and the door should open.
Aug 11, 2011 | Chamberlain 3/4-HP Whisper Drive Plus...
I have a canon pixma mp250 and error P07 flashing.Now,I refill blac and colour cartridges,and clean ink absorber,but still flashing P07.How to reset printer? Best regards, Misko
its mean absorber full..(i think)
Check this steps :
1: Unplug power and USB
2: Open door and hold power button.
3: Connect power.
4: Close door, then release power button
5: Connect USB and an press power to use.
1 Press the power button to turn off the printer.
  • 2 Hold the "Stop/Reset" button while pushing the power button. While still holding down the power button, release the "Stop/Reset" button and then push it twice in a row.
  • 3 Wait approximately 20 to 30 seconds until the LED shows 0.
  • 4 Push the "Stop/Reset" button four times in a row.
  • 5 Push the power button twice.
  • 6 Turn off the printer by pushing the power button one more time. The printer is now reset. Next comes resetting the counter on the cartridge.
  • 7 Unplug the power and the USB cables from the printer.
  • 8 Open the cartridge door and hold down the power button.
  • 9 Reconnect the power cables while still holding down the power button.
  • 10 Close the cartridge door and release the power button. The ink cartridge is now reset.
  • Aug 11, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
    The garage door will only go down if I hold the button attached to the wall down until the door is completely closed. It will not go down with the remote control in the car . This started last week. Also I...
    HOLDING DOWN THE WALL BUTTON OVERRIDES THE SAFETY EYES.
    WHEN HOLDING IT DOWN MAKES THE DOOR CLOSE PROPERLY THE PROBLEM IS IN THE SAFETY EYES.
    ARE BOTH LEDS ON? - CHECK FOR A LOOSE OR BROKEN WIRE.
    ARE THE EYES WIRED CORRECTLY?
    ARE THEY AIMED AT EACH OTHER?
    Jul 15, 2010 | Sears Craftsman LiftMaster Chamberlain...
    Garage door won't close w/o holding down push button on wall
    Check the door sensors. They must be properly aligned to work. Both of them has a small light that must be lit and will only light when they are pointed at one another.
    Aug 02, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Garrage door opener ability to close the garrage door
    Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Have to hold the button untill door is all the way down
    The sensors are required as a part of a safety system. If they are not installed, then the down function can be overridden by holding the button down. Holding it down assumes you are watching the door and no one will be trapped underneath it.
    Buy and install sensors, and the door will work correctly.
    Reply if you have any further questions.
    Feb 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
    Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
    183 people viewed this question
    Top Sears Building Materials Experts
    Glenn Mayer
    Glenn Mayer
    Mike
    Are you a Sears Building Material Expert? Answer questions, earn points and help others
