Maxtor 3200 error code 10 - Computers & Internet
  • 3 more comments
  • pattvin Dec 27, 2008
    maxtor 3200 error 10
    maxtor 3200 error code 10
  • pattvin Dec 28, 2008
    maxtor error code 10
  • pattvin Jan 02, 2009
    I still don't understand, almost after 2 yrs, my computer dos not recognize the Maxtor 3200 through the UB2 cable input.
    I'll give this a try.
    Thank you
  • 365 Answers
Upon searching i have found a similar problem which was similar to you and the solution here may help you,i think.
Solution:
Removed the drive from the box, and attach to computer Desktop as slave.
1) There are some slider latches on either length wise sides. Once disengaged top should come right off. Or just crack it open.
2) Once opened remove screws from metal Cage, and remove top of cage.
3) Remove three screws holding the USB adapter card. (All visible screws) Not the ones on the actual hard drive.
3) Carefully remove hard drive and the attached usb adapter card in one piece.
4) Remove the USB adapter card from hard drive.
5) Turn off computer to be installed, and unplug. Install drive direct, as slave. No jumpers to move since the drive is already set to slave.
6) Plug computer to test and if it is read and mounted, your ready to go.
7) turn off computer, and unplug. arrange cables in desktop case.
9) Close up the service panel and plug your computer back up.
I need to be sure before sending it in for recovery and spending $800. So I connected as slave to 2nd desktop computer and it mounted. This means that the "USB adapter card" that came with the maxtor3200 was faulty. It was recommended that the best way to back up on another hard drive is to directly plug your hard drive into your computer as slave.
this is the solution which one person have given in the forum when he have experienced the problem.i think it can help you
another reasonable posting from the maxtor site itself is that the object has been damaged.
any way try the first thing and i think the trying may result in a good result.thank you
Posted on Dec 28, 2008
    Scholar:
  • 113 Answers
Hello welcome to fixya! try using HDD diagnostic tools, like Disk Warrior or norton disk utilities, its a software package. It can help you fix your hard drive and it can determine also if your HDD needs a replacement.
  • 837 Answers
The power supply needs replacing for the computer. But to prove this out, if there is a "spare" lead left in the case from the power supply swap it otherwise disconnect, lets say a CD drive, use its power lead and connect to the drive. restart the pc ..
  • 15,935 Answers
If Code 10 appears, the drive has most probably failed. Verify by trying the drive with another USB cable or port, or on another computer. You can begin a drive replacement order online.
This is directly from maxtor... LINK .....
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD
    Scholar:
  • 145 Answers
Though I am sure that your drive has an electronics(hardware) problem. Still before going to the company for replacement. Try these two things. Update driver and update drives' firmware.If these two doesn't work, Replacement is the only option.
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Dec 27, 2008
  • 916 Answers
1) There are some slider latches on either lenth wise sides. Once disengaged top should come right off. Or just crack it open.
3) Remove three screws holding the USB adapter card. (All visible screws) Not the ones on the actualhard drive.
3) Carefull remove harddrive and the attached usb adapter card in one piece.
  • machadojr_fe Jan 02, 2009
    Please go to control panel>administrative tools>computer management click on disk management and see if the drive is listed,
    if it is listed right click and click format if there is nothing on the hard drive
    when the format manager comes up you will most likely want to make the file system NTFS.
    From there the computer will format the drive and assign it a drive letter after that it should recognize the drive.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, pls try:
  • connect the Maxtor to another PC, if the same error, then confirmed that is a Maxtor issue. In all likelihood the hard drive inside would require attention;
  • if error message is not displayed and Maxtor works, then it is the first computer's USB ports that would require attention;
  • if it is the computer's USB port(s), either update the USB driver or rollback the driver.
Good luck and Thank you for using FixYa.
    Sergeant:
    Novelist:
  • 327 Answers
Most probaly the drive is dead and needs replacememt but you can try this instruction as some time this gets solved.
So here is the solution. -----
WARNING! DOING THIS WILL VOID YOUR WARRANTY! ------
1- Disconnect the HD from USB and power supply. ------
2- There are 2 screws at the back. Unscrew and open the box. (The plastic is kinda hard to open be careful) ------
3- Now you have a metal box in your hands. Unscrew and open it. -----4- Now you will see a HD and a controller board. There are 3 screws that holds the controller board. Take them out.--------
5- Now slide out the hard drive and controller board out gently. ---------6- Unplug the controller board (power socket and IDE socket)from the Hard disk. --------------
7- Look at the back you will see jumper settings. (Mine was set on Cable Select.)--------
8- Take the jumper out and plug it to Master ON position. now put it all back together. and follow these steps, . I hope this helps.
for more details click the link below
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=83
  • 741 Answers
There is a list of all the error codes and what they mean on the Microsoft website. You can print it off and can use it for later if something else comes up.
    Scholar:
  • 172 Answers
This device is either not present, not working properly, or does not have all the drivers installed. (Code 10)
power off the pc, check the power supply to the drive is good, check the ribbon cable to the drive is good. If required swap a "known good one" to the drive instead, power on the pc, press del to enter CMOS in the first page on the menu, check the hard drive is shown as a piece of recognised hardware, if yes the cables are all good, save and exit, boot to windows see if this has cured the problem, if not then either drive is not working or the cables are faulty or the motherboard channel it is plugged into is at fault, if this is the case try and plug the drive into IDE 1 instead of IDE0 and try again.
compdoctor2005@btinternet.com
    President:
  • 1,257 Answers
  • 395 Answers
Many possibilities may lead to the problem, let’s use steps below to narrow them down:
1. Has the Maxtor External Hard Drive ever worked on Vista before? If it never works fine, please also try to connect it to other computers, including Windows XP-based computers. According to this, please contact the manufacturer to confirm whether it is a damaged device or an incompatible-with-Vista model.
Windows Vista Hardware Compatibility List may help you to check it:
http://winqual.microsoft.com/hcl/
2. Based on my experience, Code 10 error is also very possibly caused by legacy drivers for USB devices. Please contact the manufacturer to confirm whether this is a driver problem and require further support.
3. In case of other possibilities, I also provide you a KB article containing a hotfix. Only a few USB device errors with Code 10 may be caused by the this reason. Therefore, I highly recommend you not to try this step before contacting the manufacturer for information in step 1 and step 2:
Note: I suggest it for your reference and I can’t guarantee it’s the right solution.
Error message on a Windows Vista-based computer that is running a USB composite device: "STOP 0x000000FE"
http://support.microsoft.com/default.aspx?scid=kb;EN-US;934796
You may get the hotfix in the following page (fill the KB Article Number blank with 934796):
https://support.microsoft.com/contactus2/emailcontact.aspx?scid=sw;en;1410&WS=hotfix
If I misunderstand anything, please let me know.
  • Bernie Reeves Dec 27, 2008
    General Symptoms
    Exclamation mark appears beside Microsoft WPD FileSystem Volume Driver under Portable Devices in Device Manager; Uninstalling & Installing the driver has been tried, but fails and prompts Error 10.
    Other Symptoms
    1. Maxtor External Drive doesn't work;
    2. : Media player can’t play audio files and has red X mark beside them;
    3. But if deleting the Microsoft WPD FileSystem Volume Driver, playing sound goes fine.
    Based on my experience and research, I suspect a confliction between Microsoft WPD FileSystem Volume Driver and some 3rd party drivers in these issues. That leads to collapse of the former one.
    Genius:
  • 3,422 Answers
The Code 10 is" can not start" error is the problem.
Keep the Maxtor connected, restart your computer and go via Control Panel, System to Hardware Properies and finally Device Manager. Click on the driver with marked with the yellow spot and uninstall this (USB Storage) driver.
Restart the computer (in my case the Thinkpad T41 notebook) and it will automatically detect "new hardware" and re-install the required driver.
  • Priya darshan Dec 27, 2008
    The above solution has worked for few people.Let me know the result.
    Genius:
  • 1,550 Answers
Try reset unplug and plug back sometime error gets cleared.
Maxtor 3200 Won't back up any longer. Says error, cannot backup
It may be corrupt with bad sectors if so go to mycomputer right click the maxtor drive goto properties then tools and select check drive for errors.
Maxtor are awfull, do your self a favour and replace it with a weston digital. If a harddrive starts getting errors its just a matter of time before it gives up completely
Nov 13, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor 3200 has a gren light that is now blinking and the computer cannot start the drive. Code 10. What does this mean?
I had this problem. I learned that the power supply was defective. You can purchase a 12V 2amp power supply. This solved my problem. My green light was coming on but my computer didn't recognize the drive and I got the same Code 10 cannot start drive. I purchased a 12V 3amp power supply. It doesn't hurt to have more amps but you need at least 2amps.
Jan 08, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
Need to locate a working identical Maxtor 3200 200GB
Well this is not how I like to answer questions on this forum, but here is a place to start looking for your drive. I hope this helps, there are some listed.
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=+Maxtor+3200&_sacat=See-All-Categories
Sep 15, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200
Seagate troubleshooting Error Code 10, states that drive has failed. (Seagate bought out Maxtor)
Before you resign yourself to everything is lost on this harddrive, how about trying one more thing?
How about putting the harddrive inside in a new external enclosure, and see if it works? I suggest that perhaps the external enclosure it's in, is bad.
The harddrive inside is a 3.5 inch harddrive. Same width as used by a desktop computer. It is a Sata harddrive.
Here's an example of a 3.5 inch Sata, external enclosure,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901268&CatId=2780
Just pop the external enclosure open that holds it now, take it out, and install it into an external enclosure like the example above. Plug in the USB cable.
Don't know if this applies to your particular Maxtor Personal Storage 3200, but when I went to search for the type of harddrive it uses just now, I ran into thsi, and thought I would pass it along. http://www.seagate.com/www/en-us/support/downloads/personal_storage/ps3200-sw)
May 10, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
I have a Maxtor 3200 USB drive. It stopped working and dont know why Has Error 10. I try to reboot computer, but everytime i do this the computer freezes. I guess the computer has a hard time figuring...
hi
please pres dell WHILE BOOTING YOUR SYSTEM GO TO THE BIOS AND BOOT OPTION DISABLE BOOT FROM USB AND GOTO THE USB SETTING AND MAKE THE USB AS GENAREC AND EVERY THING WILL BE FINE
GOOD LUCK
Jan 04, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
My Maxtor 3200 ext. drive which I had for one year now (no pbs.) not being recognized by my system and I see a Code 10 error in the Device Manager.
first you can use your troubleshooter in your device manager to find out what that code 10 error is or you can go to the maxtor website in the support or troubleshoot section and tell them your code 10 error,it might be a driver needs to be updated.
Dec 05, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Code 10 on drivers
please post if you found an answer for code 10.
Sep 24, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Maxtor 3200 not working
Check for error code 10 in the Windows device manager. You likely have a power supply problem.
View my related posts on this FixYa site or on the Seagate Knowledge Base website.
http://forums.seagate.com/stx/board/message?board.id=PersonalStorage&message.id=1258
If it is a power supply problem view my FixYa post below for help finding a new power supply.
http://www.fixya.com/support/t2911563-go_about_getting_new_power_chord
Aug 29, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Cannot find hard drive
I got the same problem on my 3200. Found out that the adapter was bad. Changed it and everything worked ok.
Best regards
Trond
Aug 12, 2008 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
Alun Cox
David Payne
David Payne
