Question about RCA Lyra RD1080 MP3 Player
My rca lyra rd1080b
When i turn on my mp3, it says "bad or missing rca_sys folder." but, when i connect the device to my computer my songs show up, but if i try to listen to it w/o it being hooked up to the computer it wont play. how can i get it to work again? thank you, claudetta allison
  • 16 more comments
  • izebel Dec 07, 2007
    mi lyra rd1080b, cuando prende dice bad or missing eusa.exe y no reproduce las canciones
  • Anonymous Dec 09, 2007
    when i turn on my mp3, it says "bad or missing rca_sys folder." but, when i connect the device to my computer my songs show up, but if i try to listen to it w/o it being hooked up to the computer it wont play. how can i get it to work again?
  • gfaj Dec 09, 2007
  • clabe Dec 14, 2007
    it says "bad or missing lyra sys folder" how can i get another.
    my computer sees it as RCA-LYRA but when i try to play the music it doesn't play.
  • Anonymous Jan 04, 2008
  • Anonymous Jan 07, 2008
    rca lyra 1080b
  • techietoys Mar 11, 2008
    I had the same problem. I tried the first solution and I was able to play my mp3's immediately after the upgrade.
    thanks a million. I actually thought I was going to be forced into buying an ipod, which is something I really don't want to do right now or in the future.
    thanks again.
  • Anonymous Mar 25, 2008
    ya hice este procedimiento, pero no tuve exito. que otra coa puedo hacer. gracias
  • jayy1077 May 03, 2008
    same problem
  • Anonymous May 13, 2008
    my folder are missing
  • katpatton May 17, 2008
    bad or missing lyra system folder
  • bikeute Jul 08, 2008
    Same problem as Claudetta Allison, bad or missing sys file, but works fine when hooked up to the mother ship
  • Anonymous Jul 13, 2008
    same problem and i dont know how to put music back on it
  • wahi Jul 14, 2008
    Ihave the same problem ,when I switch it on it shows bad or missing lyras folder' and shuts off
  • Anonymous Jul 24, 2008
  • Anonymous Oct 02, 2008
    i tried what they suggested us but it says the following message when i try to update the system files: Errors occurred during upgrade. Please verify device is working properly and is not being accessed by another application. Please repeat the upgrade. If problems persist, device firmware may be corrupted.
    Help!!!
  • terdbergler1 Nov 26, 2008
    when i turn it on it says bad or missinglyra-sys folder
  • Anonymous Dec 22, 2008
    EL ARCHIVO EXE ESTA DAñADO Y NECESITO BAJARLO DE INTERNET ¿COMO PUEDO HACERLO?
This is the best solution you have update your lyra rd 1080/rd 1090 for download the updating click her http://download.rca.com/download/RD1080_90FWUpgrade_v4.26.exe and after instaling this update follwo instructions provided below ? To update your Lyra RD1080/RD1090, make sure you have it connected to the computer via the included USB cable. You will need to make sure that no external memory has been inserted and the Lyra RD1080/RD1090 display reads: "USB Connected Int. Mem". (If it does not, please refer to the users guide for the section on how to switch between internal and external memory.) ? Once connected, locate and run the Lyra Systems File Update Utility if it didn't open automatically. Installshield Wizard will have automatically created this icon on your desktop as well as under "Programs", "Lyra Personal Audio Player", "RD1080/RD1090" in your START menu. ? Click the "Refresh" button until the RD1080/RD1090 player shows up under device. ? Once displayed, highlight the drive letter by clicking on it, and click the "Update SYstem Files" button. ? When successfully completed, you will see the message, "The Lyra Personal Audio Player Device system files were successfully updated." ? Click the "OK" button, and then "Done". This will close the Lyra Systems File Update Utility. ? Disconnect the Lyra RD1080/RD1090 from the USB cable, turn the unit off and back on.
Posted on Jun 02, 2007
Try pluging in the device with out the card in it download the file
Posted on Dec 09, 2007
I cant listen to my music on the mp3
Posted on Nov 16, 2008
Go here and download the firmware update. TAKE THE FLASH CARD OUT OF THE LYRA! Plug the Lyra in using a USB cable and run the firmware update.
Works like a champ.
http://support.rcaaudiovideo.com/downloads.aspx?product=160
Posted on Nov 05, 2008
When I try to run this fix I get the following message regardless of how often I refresh.
No Lyra devices were detected. Please connect your device(s) to the computer and select refresh.
The dislpay on the player shows USB Connected Internal Memory
Posted on Oct 07, 2008
Posted on Oct 01, 2008
The first solutiopn worked right away. Thanks a lot.
Posted on Jul 15, 2008
Bad or missing sys folder
Keegan, Check the attached links,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://voxrightnow.custhelp.com/app/answers/detail/a_id/9678/~/troubleshooting-the-rca-rd1080-digital-mp3-player
lyra 1080 bad or missing sys folder RCA Lyra
http://www.ecoustics.com/electronics/forum/home-audio/92143.html
Mar 02, 2016 | RCA Lyra RD1080 MP3 Player
No me reproduce las canciones me dice bad or missing lyra sys folder
dont come out nothing just say bad or missing lyra sys folder
, can you help me please. thank you
Jul 05, 2011 | RCA Lyra RD1080 MP3 Player
Formated RD1090A in XP now will not turn
Try this device using windows 7....if theres any problems with your divice windows 7 fixes them...you need no drivers at all..windows 7 really improved this device
Apr 30, 2010 | RCA Lyra RD1090 MP3 Player
What can I do??
If you have any problems with ur RCA RD 1090 Try plugging it into a computer running windows 7....Two of my friends have the same device with the same problems...who took my advice after taking there device out of the closet they both plugged it in and they got the same pop up saying you have a problem with ur device would you like windows 7 to fix ur problems and now there both using there devices again and the sweet thing about it they didnt have to download any drivers
Apr 27, 2010 | RCA Lyra RD1090 MP3 Player
Bad or missing lyra sys folder
If you have a computer with windows 7 all ur problems will be solved....just plug it in and windows 7 will fix the problems....but one thing it will only run well on 7 so think about changing
Apr 16, 2010 | RCA Lyra RD1090 MP3 Player
The RCA Lyra 1090a says bad or missing lyrasys
What i do is i never put songs in my internal memory...this way you never have to worry about formating the internal memory....so i have several exteral card i use say one for country or rock and its so easy to format a exteral card just place it in ur card reader if ur using a laptop them go to my computer right click on ur card that youll find then youll notice on the list theres format so its so easy...im sure its asking you to format ur drive because you must have a few corrupted files....best of all when adding music just pull ur external card out place it in a reader fill ur card with music then insert it back in ur device...this way ur getting away with using any firmware....by the way take any disc that came with ur Lyra and chuck it in the garbage that 90 percent of all ur problems
Nov 25, 2009 | RCA Lyra RD1090 MP3 Player
Dear FixYa,
Ohms was helping me, I am guessing that he tried to download some info for the fix.
However, because we have pony express dial-up the material was never fully sent.
Help ! My mp3 is my link to success in triathlons ( got one this sat) I am sunk without the support. Again the error message reads "bad or missing lyra sys folder"
Thanks Jeff
PS Is there a physical address that could put humpdy dumpdy back together again in the SLC or Ogden area.
Jul 07, 2008 | RCA Audio Players & Recorders
Bad or missing lycra sys folder
you need 2 update the software go to rca.com
Mar 08, 2008 | RCA H100 MP3 Player
RCA Lyra RD2317
Remember when you format memory like a hard drive you erase everything. Move music to your internal mp3 memory and do a profile - folders should appear. If you have flashed your player with the firmware update you can get 520 songs on the player for both internal and external combined but be warned that if you exceed this count your player will start to forget the earlier loaded songs - listed but not addressable (playable). The same is for the folder count eg. add album = artist + ablum title (min 2 folders). Plus always profile your songs after loading new music or deleting as this is an index build process to play song 152 = title x. This includes accidental radio recordings to MP3s. RD2312 , RD2315, RD2317 Lyra™ mp3 flash player Firmware/Application Upgrade Version 3.11 fixes:
  • Supports a total of 520 songs, in up to 50 folders, with up to 8 levels of subfolders.
Aug 06, 2007 | RCA Lyra RD2317 (1 GB) MP3 Player
Go to RCA support http://support.rcaaudiovideo.com/select.aspx?u=downloads and find your player and download the firmware and drivers (if needed) upgrade and install to your player its very easy and instructions are at the same site.
Aug 06, 2006 | RCA Lyra RD1080 MP3 Player
RCA Lyra RD1080 MP3 Player Logo
1,531 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
