Question about Acer Aspire 3613WLMi Notebook
Connct Acer 3613 -did not include all info in previous ques.
Hello again, I still haven't figured out how to respond to a solution (aside from rating) so this is additonal info
I did receive 15-pin D-Sub Cable to connect the VGA video cable to the computer. It is the second connct that is the 24-pin DVI cable and this is the one I can't figure where to plug. Would this one go USB? Or can I use the monitor only with the first one plugged in and not both?
Thanks
Canon iX6820 is in error state
  • Si la impresora muestra estado de error", puede haber un problema con la propia impresora. Aseg?rate de que la impresora est? encendida y conectada a tu equipo mediante el cable. Comprueba si tiene poco papel o tinta y aseg?rate de que la tapa no est? abierta y de que el papel no est? atascado.
Jul 03, 2018 | Canon Office Equipment & Supplies
Mi hyundai accent GLS 2002 tiene el check encendido y tiene los errores p1401 y el p0442, que puede ser y como puedo solucionarlo, ademas la luz del dasch se apaga y se enciende constantemente que puede...
The 2000 model year Accent adopts a different "pressurized" leak check system capable of detecting a 0.020" (0.5 mm) diameter leak (previous Hyundai systems detect a 0.040" [1mm] diameter leak using engine vacuum). The new system uses a Diagnostic Module for Tank Leakage (DM-TL) to close and pressurize the fuel evaporative emissions system. The DM-TL replaces the fuel tank pressure sensor and the canister close valve from previous systems. Other significant changes were made to the system logic, including several new diagnostic trouble codes. It compares the differences between the 2000 model year Accent and previous evaporative emission systems... Que puede ser? Tiene dos opciones. Primero, puede pagar que un tecnico diaga el problema (exactamente) o sigue, secudariamente, su adivnaza.
Jul 11, 2011 | 2002 Hyundai Accent
Need to replace the dc jack in my acer
here u go dont pay do it urself if u know what is the problem
http://www.filestube.com/531dfe5c9be90e1803e9/go.html
pls rate me FIXYA fo rhelp
Apr 24, 2009 | Acer Extensa 5620 Notebook PC
Acer Aspire 3613 cracks near hinges.
you can lift up the little round circles take out all screws,take top off, to lcd find the little gold nuts that the screws go into, try to put them back in plastic holes with super or gorilla glue,
or order screen parts on ebay, hinges usually get worse unless you find a way to secure those brackets attached to hinges
Mar 13, 2009 | Acer Aspire 3613WLMi Notebook
Cracks near hinge Acer 3613 laptop
Apply a lubricant to the hinges themselves - not a ton of lubricant, as you don't want anything running down into the laptop proper.
What sound like has happened is that the display has somehow been in a bind, and therefore the hinges are in a bind. This makes it harder to moved the hinges, and thus when you open the lid it is making the cracks.
You may also want to unseat / unscrew the hinges and re-tighen the little screws that hold them in place.
Mar 12, 2009 | Acer Aspire 5050-3242 Notebook
Trying to connect Acer X213W monitor to Acer 3613 laptop. First Q-My laptop does not support 1680 x 1050 resolution, can I still use the monitor?Second Q- I can't seem to locate where to connect (hardwire)...
1. Yes, the monitor will just display the resolution set by your laptop.
2. There should be a VGA port on your laptop, it's a trapezoid shape with 3 rows of 5 holes and usually blue. Since your monitor only has a DVI cable, you need to get a DVI to VGA adapter to be able to plug your monitor into this spot.
Dec 27, 2008 | Acer Aspire 3613WLMi Notebook
Can we connct furuno gp31 to pc
Hello!
Yes, the GP31 can connect to a PC.  With the wiring harness, it has an RS-232 port, which allows it to connect to most PCs, laptops, and even most palmtop systems.
Hope this helps you out,
Ken
Sep 19, 2008 | Furuno GP31 GPS Receiver
Wireless connection problems
Download driver Acer Aspire 5100 for Atheros Wireless adapter ar5007ag
Aug 22, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 3613WLMi Notebook Logo
59 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
