Question about Sony PlayStation 2 (PS2) Console
Disc won't spin. won't read disc
My disc will spin for a second then stop..it keeps doing that..can't tell if the laser is working or not. this happened suddenly after playing guitar hero world tour...it says it can't read the disc. Any help would be appreciated.
  • farmclan Dec 30, 2008
    thanks for the info..now I have to replace the laser if i can find that part
Have you tried other discs? If so it could be that your laser crapped out. It happens sometimes with no warning. Or if someone really used the system a lot with the guitar hero thing - that kind of intense use can burn em out. I've repaired these for years & have seen this before.
Above all though, make sure your disc is CLEAN with no scratches. If another disc will play then you know your laser is good. You could try the disc on a friends machine & see if it works there.
I can only give suggestions as I cannot see the problem occur & don't have all the details.
Good luck
Posted on Dec 27, 2008
Why does my DVD player say STOP in Upper Right Corner?
Sounds like your laser mechanism is no longer capable of reading a disk. If it does it with other disks then you can be sure of the diagnosis.
And due to parts cost and labor a repair is usually not cost effective.
Apr 28, 2012 | Magnavox DP170MW8B DVD Player
Will not play
Hello Brandon
The fault is with its Laser Picku Unit itself. The sled motor, the motor that spins the disc inside the DVD player, should wok like this as you details here. Just see, when we put in a disc inside any disc player, it will sart spins, after it has been loaded properly into the mechanism. The the laser pickup unit will start scan the recording on the disc, reads it; recogonize its contents, then starts to play from the first track. This is an automatic process ot all disc players, and suring this reading process, the spin speed of the disc will vary, may stop, or rewind to a little and then spins again. This is a common process to all the playeres.
Here, with your DVD player, the laser pickup unit tries to read the tracks, but fails, the again it starts to readit, fails and finally show a 'No Disc' display, as it hasn't got any details about the recoding at the inserted disc.
There are three main causes for this fault. The first one is with a faulty strip wire. This wire is one, that connects the laser pickup unit with main board. You can see a flat ribbon type cable that connectes to laser pickup unit at the mechanism, to the main circuit board of the player. Replace this cable fist. This cable can be purchased from most of the electronic spare part shops at your town, and won't cost more.
The second chance is with dirty or dusty laser pickup unit lens. To cclean this lens, the easisest way is to put in a lens cleaning disc into the unit, play it for at least three times, by ejecting it out and get it into. This process will clean up any dirt or dust accululated on the lens, and will help you. The cleaning disc also can be bought from most of the electronic spare part selling shops at your town.
The third chance is with a faulty Laser Pickup Unit istsef. If so, there is no repair to this unit other than replacing it with same type and number. It is a skilled work, and you have to disassemeble and reassemble the deck mechanism. If you have experience to dothis, you can do it by yourself at home Ok
Please do rate this solution, if it found helpfull to you.
Dec 29, 2011 | Durabrand PDV-709
My dvd player tray does'nt open when it should and when i insert a disc to play, it only plays for a few seconds then it stops but the disc continues to spin
Hello
The laser pickup unit of your DVD player may either be faulty or dusty. Just put in a cleaning disc into it and play it for at least three times, and check. If it does not help you, the laser pickup unit of your device should be replaced with same type and number. Just check the loading belt too. OK.
Dec 16, 2011 | Zenith XBV443 DVD Player/VCR
When loading a dvd it displays, "NO DISK". Is it
Hello
There are mainly three motors for most of the DVD players. One to spin the disc we insert in, other to load the laser pickup unit to-and-fro inside it to read the disc and an other one to load the tray mechanism 'in-out'. According to your description, the disc spins inside, and you can hear its spin. So motor which spins the disc has no trouble at all I should say. Then comes to the second motor that moves the laser assembly inside it. If it do not work, the laser pickup unit won't move and no reading will take place and 'No Disc' display will be the result. The last chance is with Laser Pickup Unit itself. Just get this unit repaired by any well experienced service technician or by the authorised service center, because, there are special tools to open this unit. As it is a compactable one, more care should be given to it while repairing. Suspect the second motor I described earlier, and the Laser Pickup Unit. OK.
Jun 14, 2011 | RCA DRC628 Portable DVD Player
My Craig ESP 60S Portable CD Player won't work. It starts spinning then stops. I have tried mode and program, but nothing helps. This is my second Craig CD player to do this.
sounds like it has a faulty laser and it wont read so the player stops the cd spin motor. try cleaning it and see if it works
Good Luck!
May 11, 2011 | Craig Personal CD Player
On rockband 3 the disc loads but when I get to the track list it says disc unreadable. this happens at different times. some tracks play but scrolling to others this message comes up. the disc is new and...
you need to purchase a lazer disc cleaner it looks and works just like a normal dvd disc but it has brushes on it that when put through the player brushes the dust of the laser lens this needs to be done on a regular bases to keep your lazer working to its optimum level and hense fixing your problem.
XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console....
click here to download repair guide
Dec 28, 2010 | Microsoft Xbox 360 Console
Ps2 powers up, but disc is not spinning and
Following could be the reasons for not spinning any PS2 disc:
  • A dirty laser. Try cleaning the laser and see if it helps. If you can see crust or dust covering the laser eye, it may not be strong enough to read anything at all. If the laser looks clean, this is probably not the issue.
WATCH this video to clean lens
  • An unplugged laser cable. These things normally do not come out by themselves, but if you opened the ps2 that was spinning OK to clean the laser and/or removed the laser to clean it, plugged it in, now it's spinning 1/2 of a turn, the laser cable may not be in securely. If it is in securely, make sure it is plugged into the motherboard end properly.
  • A dead laser. On models 30001, 35001, and some 30001R, this is the most likely issue. These models are old and the original lasers were a bit unreliable.
No Spin At All If your spindle hub is NOT SPINNING AT ALL, NOT EVEN 1/2 OF A TURN, it may be bad or unplugged. A tell tale sign of it being unplugged is if you hit eject, the laser moves down the rail, and starts grinding because the PS2 keeps trying to move it down the rail even though it hit the end. There's a small switch on the spindle hub that tells the unit to stop pushing the laser because it's reached the end. Spindle hubs usually do not go bad by themselves, usually either the PS2 too a bad fall and it became bent [try spinning it by hand], or someone the cable out and put it in too many times [or incorrectly] and the silver contacts on the cable were detached.
Nov 18, 2009 | Sony PlayStation 2 (PS2) Console
Disc read thing (PLZ HELP!)
If you find out that it is spinning then the laser was probably knock ajar and will need adjusted. There are good step by step instructions on several sites if you search for that. I had to do it to mine that would spin and then say disc read error. The whole thing does have to come apart but when you have it apart the adjustment is the easy part.
Oct 28, 2009 | Sony PlayStation 2 Slimline Console
Cd drive led light flashes orange four to five times then stops
Given all the things that you ahev done, clean the drive with a CD/DVD cleaner and / or air duster. Check the device is enabled in Device Manager and it shows no errors. If it does then read the explanation. If not and it looks OK you will most likely need a new drive!
Sep 09, 2009 | Computers & Internet
Sony PlayStation 2 (PS2) Console Logo
103 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
