I have changed ink, cleaned heads numerous times and alligned the heads but am still getting problems with missing lines when printing and the nozzle check is incomplete even after numerous head cleans
Sarah McHugh:
Just a suggestion: I would go to the Epson website and download an updated version of the printer driver for your machine... the problem may be with your software, not the printer!
SOURCE: Lines on prints
Hi kids! I decided to have another go at sorting out my 'lines' problem and have sorted it. See if this might work for you: I had previously done the head cleaning via the printer itself - holding the central ink/paper black button for 3 secs. This time I went to the Epson 1290 window on my Mac and clicked on the utility box. Though the Nozzle check print came out fine I went ahead and did the head cleaning in this box. The next print came out almost perfect so I ran the Head cleaning again and it printed a perfect print. Hope this might work for you. Keep on trying! All the best. Trant
SOURCE: Epson Stylus Photo R800 Print Head Nozzles ??
Don't use nozzles clean function, besides ink consuming it can cause damages that cannot be fixed: black lines on the back side of the page that will be permanent. Instead put two photo paper together (2x260 gr) and push the two papers together into the printer while printing a motive including many colors. Do so a couple of times and the clogg usually disappears. Good luck! jonk
SOURCE: Can't perform a nozzle check - Sensor error load different paper
Hi tom_kolasa,
Here is the manual for your printer model. Epson Stylus Pro 9800 Printer Guide
http://files.support.epson.com/pdf/pro78_/pro78_gd.pdf
Hope that the manual contains everything you need from nozzle check to sensor errors.
SOURCE: I have tried everything from head cleaning, nozzle
I had the same problem. What you need to do is manually clean it. Take the ink cartridges out and clean the bottom of the ink loading bay with a Q-tip. Than, inside the printer, there is a black sponge that lines the area below the printing heads, take it out (gently). Clean it with water over a sink by squeezing it, but be gentle. A lot of ink should come out of the sponge. Once it is thoroughly cleaned, let it dry (I used a hairdryer than let it air dry for a little bit). Reinsert the sponge (make sure it is dry!) and ink cartridges. Do one head cleaning on the computer and now it should print like new.
Testimonial: "Thank you so much for the advice I will try this!"
SOURCE: I'm trying to resurrect an old Epson 1280 Photo
It's time to "cut your losses"; either the electronics that tells the inkjets when to shoot ink is screwy, or the inkjets are totally plugged, despite the "cleaning" cycles.
Responsibly recycle the printer, and buy a new printer.
Maybe, try to find another Epson that accepts the same ink-cartridges that you recently inserted into the old printer.
