Question about GE Refrigerators
Refrigerator freezing food
About a week or two ago my water filter light came on indicating it needed to be replaced. Being the holidays i did not have the money to replace it right away. Then the ice stopped working. Then the water stopped coming out. Then the refrigerator started freezing everything in it, even on every level. I removed the filter and it was frozen solid. I replaced it with a new one. I have turned both refrigerator and freezer down to 1. Still nothing. Is thins something I can fix myself or do I need to call for repair and what is my problem?
  • kvmwallace Dec 27, 2008
    I am capable of reading troubleshooting recomendations ..... the information given me I have already READ from another web site... I need someone who knows what they are talking about.... not someone who can READ a MANUAL. The last response was NOT HELPFUL and if you have no one who can help me I want my money back.
    so is this something I can fix myself or do i need to call for help from a repairman?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Have you considered defrosting the unit? Might not be practical if lots of food stuff in there and with the holiday season and all but defrosting would heat up certain sections of the fridge. An alternative is to reset the unit by unplugging from the mains for an extended period of time with the door open but then again the problem of where to keep the contents for the time being.
Good luck and Thank you for using FixYa.
Posted on Dec 27, 2008
  • 334 Answers
The unit has probably frozen up into the water/air channels because the filter was clogged causing water back up and then freeing that water.
You will need to unthaw all that ice.
Remove the food into a cooler or another freezer/fridge.
Unplug the unit. and open the doors. Remove the filter and let it set for several hours to that thouroghly.
Put the filter back in, plug it up, and give it an hour or so to insure all is well.
Dont forget to reset the thermostat.
    Genius:
  • 1,550 Answers
The symptom that you described will need to be repaired by a technician. The repair will require some dis assembly and parts.
Your problem is air is bypassing the rear diffuser through the opening next to the baffle motor. The technician will install a kit it will include a foam gasket and user's interface board.
I recommend calling a service technician to diagnose and repair your refrigerator.
    Genius:
  • 3,422 Answers
This is a common problem that often doesn't have a clear, permanent solution. The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try:
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Dec 27, 2008
    • 916 Answers
    Replace the thermostat and it should be working again
    • machadojr_fe Dec 27, 2008
      its the thermostat isn't shutting down the compressor when the set temperature has been met.
      you should be able to fix this yourself most appliance and hardware stores sell them with instructions included
    My turbo boost light dims but does not go out and the food in the refer is freezing
    Lower the refrig therm - if that does not do it then the assembly that regulates the amount of cold air that is being blown into refrig from freezer is sort of stuck on wide open position and your refrig is like a second freezer.
    Assembly needs to be repaired/replaced/
    To see part go to attached link Search Over 2 1 Million Appliance Parts
    Sep 09, 2015 | GE Profile Series PSE26KSESS PSE26KSESS...
    My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
    first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
    Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
    My Maytag side by side refrigerator [mod. #MSD2656KES, Serial #50518503JL] is freezing everything on the frig side on the two top shelves. Coils have been cleaned. Temp set:Freez=3, Frig=2. One week ago...
    I have this same refrigerator, also purchased in 2006. Same exact problem. Fridge freezes, starting actually in the water line, you will notice water on door does not work, then top two shelves start to freeze. Lasts for a few days, then prob does not happen again for 6 months almost to the day. I've had this problem for almost 3 years!!! My service tech said to buy another, glitch in this system he can't figure out. Replaced damper x2, control board, and thermostat x2. Not sure what else to do. I hate the thought of more food lost to spoilage!
    Aug 09, 2010 | Maytag 25.6 Cu. Ft. Side-by-Side...
    FROZEN WATER FILTER - UNRELIABLE TEMPERATURES
    About the dual water control valve the side that feeds the ice maker could be defective. Fill the ice maker with tap water and let freeze. If it dumps and does not refill the water control valve will need replaced. Here is a link to the water control valve.
    WR57X10032 Water Control Valve
    As far as the temperature control here is a link to the Temperature Control Here=>
    WR55X10095 Temperature Board Encoder Below are some photos. If I can help answer any questions let me know, Sea Breeze appliancepartsse@yahoo.com 6b49f39.jpg053ba1a.jpg
    Jul 28, 2009 | GE Profile Arctica Stainless Steel Top...
    Refrigerator is freezing food AND broken ice container part.
    Just lower it one number at a time , wait 24 hrs each time you re set it until you reach the right temp. 34-40 deg.
    Your filter light has not came on most likely because it has not had the time to. You do not need to replace your filter every six months. This is a safe guesstamate from the manufacture , it depends on water quality and use of water , some filters will go years and years , the filter indicator does not even know if the filter is bad.
    When you notice water pressure slowing when dispensing from the door you know the filter needs replaced.
    Hope this gets you out of that service fee. This should FIX IT!
    If you have any questions let me know.
    Phil
    Apr 14, 2009 | GE Profile CustomStyle PSC23MGSWW 36" 22.7...
    Food and water freezes but ice cream is soft
    Check the door gasket seal.
    Open the door for a few seconds and then close.
    Immediately open the door again, and, if sealing properly, it should take more pulling force to open the door.
    Mar 30, 2009 | Refrigerators
    Samsung RS263BBWP Side by Side Fridge: Water line continually freezes
    higher numbers on the tempature set make the fridge
    colder lower numbers make wormer
    May 23, 2008 | Samsung RS2556 Side by Side Refrigerator
    Food freezing in refrigerator.
    I have a side by side GE Refrigerator only about 4 years old, the setting on the Refrigerator is set at 37 degrees but it continues to go to 20 degrees and freezing my vegtables. Help.
    PS - i did vacumn the back filter a week ago with no help.
    Jan 27, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
    The water filter keeps freezing and food in door and on shelves keeps freezing.
    clean lint from coils in back. could also be low on refrigerant (freon)
    Jul 09, 2007 | Admiral 26 cu. ft. Side-By-Side...
    Refrigerators Logo
    23 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    Randy Justice
