Question about Kenmore 46462 Front Load Washer
Ip address wont work on ps3 anymore
When i try to connect my ps3 to the internet it says go to network settings i go their and go on internet connection test, it then says obtain ip address failed but it didnt do that before
  • 15,935 Answers
It is likely your internet connection is not working properly.
Unplug your modem, router, PC, and power down your PS3.
Plug in your Modem.
Wait for it to run it's full diagnostics.
Plug in your router and let it do the same.
Power on your computer and let it obtain an IP address.
Then re-try your PS3.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
Error 8001000b wont allow me to connect to the playstation 3 network anymore. everytime i turn the ps3 on it says error 800100b on the screen then i go to the network settings to try and connect and the...
1. Locate the PS3 MAC address number: Settings - System Settings - System Information
2. Open the software controlling the rounter. This is usually done my typing the router's IP address on your browser. ie http://192.158.0.1
3. Locate a tab for FILTERS
4. Slelect MAC filters.
5. Enter the PS3 MAC address from previous step as an allowable MAC address.
6. Save entry. At this point rounter will reset itself.
7. Go back and set up the wireless connection on PS3. Select all settings automatic or EASY as the case maybe.
Read more: http://www.ps3news.com/forums/ps3-guides-tutorials/how-fix-wireless-internet-error-8001000b-ps3-98772.html#ixzz1FxUHQxte
Hope this helps. Please Rate
Dec 28, 2010 | Sony Playstation 3 (PS3) Console
Error when connecting to the internet: error (80130804).
This means that your PS3 is not able to get an IP address from your wireless network/router. I would suggest set the IP address manually on your PS3 including the DNS IP address.
May 11, 2010 | Sony Playstation 3 (PS3) Console
Can't get internet on ps3
Okay, i'll see if i know what we're talking about here. There are a couple of things you could try. For one, try logging into your router, (usually at 192.168.0.1 and looking in the Client or Address lists for a PS3, or whatever you have named it, and then see if you can either disconnect or renew it. Then, redo the whole WiFi setup on the PS3 setting all the settings as you would but leave the IP settings as they are (should be Auto). If that still doesn't work, go into the PS3's connection settings and manually set an IP address. My suggestion is to use the same address as an already connected (and working computer), but change the last number. Whatever you do, make sure there are not two of the same IP address on the router. Hope this helps...
Nov 08, 2009 | Sony Playstation 3 (PS3) Console
Ps3 wont connect to wireless
Reset your router, then give your PS3 a static IP address and go into your router interface, find the DMZ feature and put in the IP address that you gave the PS3, just make sure the IP you give it is within the DHCP pool of IP addresses.
The PS3 will now be sat outside the routers firewall giving you FULL access to internet content and gaming online.
Now test connection settings and you will notice you will now have an open connection to the internet.
Thanks
Sep 02, 2009 | Sony PlayStation® 3 (60 GB) Console
My ps3 internet doesn't work
Easy Pie! This is a cinch anda guarantee work through. It involves putting your PS3 into a DMZ (demilitarized zone) which simply means opening all of the ports on it.
If you have the following problems, this is likely to fix it.
  • Not being able to join rooms
  • Not being able to speak over your headset
  • Not being able to hear other people over their headset
  • Not being able to join private games
  • Any problems to do with connectivity to the PSN, especially if your computer will connect to the internet, but your PS3 won't.
Part 1-(On PS3)
  • Firstly, you will need to assign your PS3 a static internal IP address. Normally whenever a device connects to your router it will be assigned a different internal IP address. These are normally 192.168.1.2, 192.168.1.3, 192.168.1.4 and so on. Assigning a static one will ensure that your PS3 will get the same one every time it connects.
  • Go to the "Settings > Network Settings > Internet Connection Settings" option on the PS3 XMB. Choose whether you are using wireless or wired.
  • Both selections should show a page called "Address Settings". Here you will need to select "Custom". Another page will then display entitled "IP Address Setting". The option "Manual" will need to be selected.
  • This will display a page where customizable IP Addresses are available to be entered.
  • IP Address - This will need to have the Static IP address in it. Use 192.168.1.80, simply because it is unlikely that 80 other devices will be connected at the same time.
  • Subnet Mask - always set to 255.255.255.0
  • Default Router - Is the internal IP Address of your router.
    1. To get the exact ip of your router you should go to
    2. Start
    3. Run
    4. cmd [Hit Enter]
    5. Type in ipconfig and hit enter, this should come up with all the ip addresses to do with your computer and the network. The address you will need to enter in this option is listed as "Default Gateway".
  • Primary DNS - Same IP Address as "Default Router"
  • Secondary DNS - Same IP Address as "Default Router"
  • Proxy � When you get to the proxy screen, select "Do not use Proxy"
  • MTU � Automatic
  • UPnP � Enabled
Part 2-(On PC)
  • In your Internet Browser, type the address of your default gateway, this will take you to your Router Configuration Page. Look for any mention of DMZ
  • When you have found this, it will ask you for the Static IP of the DMZ host. This is simply the Internal IP that you assigned your PS3. We used 192.168.1.80.
  • Finally, turn off your Router, PC and PS3 for a few minutes to ensure that the new settings are loaded. Then you're ready to go!
Courtesy of http://www.cod4forums.com/index.php?showtopic=3460
Feb 03, 2009 | Sony Playstation 3 (PS3) Console
Cant get internet connection on my ps
first check wether you received a valid ip address for your local network. usually, this should be something like 192.168.x.y. if so, then you might indeed face a dns issue. dns is used to resolve web site names to ip address. usually, your ip service provider will broadcast the external dns servers for your router to recognize.
try to connect with a computer first. if it works, check the ip settings. if your computer also cannot connect without explicit dns server settings you can do one of the following:
- explicit dns server address in ps3. go to "advanced internet connection settings", and then to "dns settings" and set the dns server address
- purchase a 30$ network router and hook it between your internet and the ps3. in the router settings, set the dns server address to be broadcasted to the clients. you can use 168.126.63.1 and 2 which are dns servers in korea (i live in korea), but you might want to find the server near to your location or promoted by your isp
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
PS3 can't obtain IP address through LAN switch
wonderful! that's always a good thing to hear - sometimes it is the "make sure you're power cord is plugged in" problem, eh :)
Jan 31, 2008 | Sony Playstation 3 (PS3) Console
My ps3 will not connect to my wireless internet
Try setting a static ip address on the PS3:-
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the PS3 but add 1 to the last number for the IP Address as this has to be unique on your network
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
I can't connect to the internet
Make sure that when u go to internet connection settings to hit the scan icon and then it will show a list of wireless networks that are in range. Then click yours and click no for security. Hope this works
Dec 17, 2007 | Sony Playstation 3 (PS3) Console
Kenmore 46462 Front Load Washer Logo
93 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
