Question about Kenmore 84052 Dryer
Dryer works fine just makes this real loud clunking noise when i
Turn it on and of
  • Kenmore Master
  • 8,220 Answers
I have seen this before. One of your wheels has developed a flat spot or has seperated from the bearing.
Posted on Dec 27, 2008
My stackable dryer (417.94702300) makes a clunking noise. We just got it (craigslist) and it happened the 1st time we turned it on. Sounds like we're trying to dry a shoe in there - it clunks in rhythm...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Jan 16, 2011 | Kenmore Washing Machines
Washer makes loud clunking noise &so does dryer when moving around, you can turn the basket by hand to make it clunk.
heatman101
ghgf
Sep 03, 2010 | Splendide 2100 Vented Washer-Dryer
The dyer still works but it makes a loud noise and doesnt produce the same amount of heat as before
LOUD CLUNKING NOISE WHEN THE DRUM TURNS? IF SO, YOUR ROLLER BEARING IS BAD. AS FOR THE LESS HEAT, YOU NEED TO CHECK YOUR VENT, MAKE SURE IT'S CLEARED. IF SO, YOU HAVE BAD COILS
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Frigidaire Dryers
Loud noise when dryer is turning. It makes a loud clunk when it stops. the dryer is hot and turn it just is very loud
UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 26, 2009 | Maytag Dryers
Maytag Dryer clunking noise
Sounds like you need a blower wheel.you will need to remove the front panel and the houseing under the front panel.It is located on the bottom front laft side. if you need help on assembly or disassembly let me know hope i fixya :)
May 20, 2009 | Dryers
Gallery ser. front load makes loud clunking sound in all cycles
heatman101
fgsgsgf
Apr 19, 2009 | Frigidaire ATF6000ES Front Load Washer
Dryer squeaking & Clunking noise
Your particular unit has quite a few things that could be making a real loud noise.....The idler pulley, blower wheel, rear drum rollers, front drum glides. Bottomline is you have to get in there and take the unit apart..vacuuming while there and if the unit is making such a noise, it will be obvious where the problem is.....If I can help further, I am here.......
Eric Campion
Mar 04, 2009 | Dryers
Dryer making loud clunking noise
Make sure the drum is not catching the back panel, and that the fan is not loose on the motor.
Dec 14, 2008 | Kenmore Dryers
Clunking noise
The clunking noise may be a broken weld on the drum.  Every time it turns and passes through the guide wheel supports, it makes a thunk thunk noise.  You will need to have a qualified LG technician diagnose the problem correctly but that's what it sounds like.
Jun 07, 2008 | LG DLG5988 Stainless Steel Gas Dryer
Kenmore 84052 Dryer Logo
115 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
