Question about Indesit 18 in. D41 Slim-Line Free-standing Dishwasher
Indesit D41 1st flashing light, stops 30 seconds into run time.
Dishwasher is reset, put on 1st programe and runs for about 30 seconds, at which time it stops and 1st light flashes. In background you can hear like a burping noise. Water is getting into machine, no blockage in pipe. If water is not being pumped out will this stop water coming into the machine? Can anyone help? We have tipped machine and drained off excess water but this didn't fix the problem.
  • 27 Answers
SOURCE: Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Posted on Jun 26, 2007
  • 27 Answers
SOURCE: indesit dishwasher DV62
You have a blockage in your drain pump. Remove all filters and scoop out as much water as you can from the unit. Check in the bottom for any objects stuck there. Some models have a cover on the bottom inside the unit, which once removed, will expose the drain pump impeller. If yours does, remove the cover(usually 1 screw only) and free the drain pump impeller. NB: DO NOT REMOVE THE SCREWS WHICH HOLD THE BASE TUB IN PLACE! These are the screws on the edge of the white plastic "bowl" inside the unit. The drain pump cover will be INSIDE this bowl and will be quite small, no more than 5cm dia.... If this does not work, you will have to remove the drain pump from the bottom or front of the unit to get the blockage out. Oshie
  • 159 Answers
SOURCE: Indesit D41 dishwasher problem
you need to check the inlet walve . when you start the unit you say it drains. so after the drain do you hear the water entering the dishwasher? If you hear a sound like a buzzing noise that would be the inlet valve working. if thats the case there is a clog at the screen in the valve not allowing the water or enough water in the tub. seeing that this is a portable unit you will also want to check to make sure the fill hose is not kinked up anywhere in the cabinet or under neath the dishwasher. If you hear no buzzing noise you need to check the inlet valve with a meter to first make sure your getting power to it and that the valve itself if good. check these things out and let me know what you found and we can go from there
Posted on Aug 06, 2007
  • 209 Answers
SOURCE: indesit d41 dishwasher
try testing the door interlock, actually this is only a micro switch inside the door behind the plastic front panel, there could also be the possibility there is a broken wire behind the door skin just above the hinge part, take care when working on appliances do not force parts to remove them and always unplug at the mains hope i have helped, if so please rate me well
Posted on Sep 26, 2007
SOURCE: Indesit IDL 50 Dishwasher
Had a similar problem (flashing lights 1 and 2). Drained the machine by diconnecting the outlet hose and using a shallow bowl on the floor. Removed and cleaned filters. Forced clean water through by using a garden hose pipe(you can only do this one way, you cannot force water down the outlet pipe). Removed and cleaned the pump (you have to do this from under the machine but easy enough). Finally ensuring the waste trap under the sink was clear. Bingo!! No parts, no expensive engineer.
Posted on Oct 06, 2009
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
Wont let me set program just beeps when pressing program so wont run ( indesit dishwasher
Hi. Are you still having this problem? I just experienced exactly the same thing with my D61 for the second time and eventually I just got cross and held down the P button for a couple of seconds and the machine beeped 3 times and the green light went out. I was then able to select the program as normal. Then, it froze on me again so I held down the button again, it reset again and I tried it on a different cycle. Now it's actually going through the cycle. It's so random (the first time I didn't hold down anything and just shuffled stuff around inside for a bit and then it worked ) it seems to be a actual fault with the programmer, so I can\t say for sure that this will work on yours or even on mine again but it's worth a try!
Mar 04, 2010 | Indesit 24 in. D61 Free-standing...
Indesit idl530 2 flashing lights
no, turn the on / off button off, then turn off the power for about 5 minutes and then it should work again. and at some point do contact someone to look at it.
Jun 13, 2008 | Indesit 24 in. D63 Free-standing...
The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
Nov 01, 2007 | Washing Machines
Dishwasher problem
My dishwasher Indesit DI67S will not run on the number 1 cycle. It will fill and then when that programme finishes it jumps straight to the drying cycle missing all the rinses out etc. If on the number 2 programme it goes all the way through but then doesn't dry. I've also noticed that the water doesn't seem to be heating up much and certainly isn't drying. Is this the element or something else? Once its reached the drying cycle the light for this just flashes then I have a job to try and reset the machine. It can take endless attempts. Will switching the machine off at the mains solve anything or is it the element?
Thankyou
Oct 09, 2007 | Indesit 24 in. DI67 Free-standing...
INDESIT IDL705
Sounds like an water inlet valve problem
Jun 28, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Indesit 18 in. D41 Slim-Line Free-standing Dishwasher Logo
56 people viewed this question
Top Indesit Dishwashers Experts
Eric Taylor
Marvin
Marvin
NOEL
NOEL
Are you an Indesit Dishwasher Expert? Answer questions, earn points and help others
