Question about Baumatic B180 Electric Single Oven
Light i have a baumatic multifunction electric fan oven .the internal light needs replacing but i can't remember how to get the old one out .would appreciate some advice
  • fiona daly Apr 27, 2007
    i don't mean to be disrespectful but i found the answer a little bit patronising .if it was that easy to get the bulb out i wouldn't have written in the first place .as it turns out you have to remove the main side panel of the oven to get to the bulb .
    President:
  • 1,462 Answers
Easy. unscrew bulb cover then unscrew bulb. switch off at wall first.make sure you use a heat-proof bulb to replace
Posted on Apr 24, 2007
  • douglas smith Apr 27, 2007
    sorry was nmot meant to be patronising. all the baumatic i had met were just as i described. bit daft to have to remove the side panel
SOURCE:
Why has baumatic B501SS oven covered in light gray coating inside when heated, now not working
It sound like the heating element burned out. Check the element and see if there is a burned spot or blister somewhere along the element. If so the element will need replacing.
May 03, 2014 | Baumatic B180 Electric Single Oven
Electric oven dont work
sounds like the heating element, also check the thermostat
Apr 06, 2010 | Baumatic B180 Electric Single Oven
My b180ss oven will not come on.the fan and light are ok.
I would definately say that the oven element needs replacing.
You will find this located at ther rear of the the oven compartment behind a removeable cover.
Apr 06, 2010 | Baumatic B180SS And B60SS (Bundle)...
My Baumatic B180W-B oven does not heat up. The
If the oven is electrically heated, then more than likely, the oven element has failed.
This is located behind a removeable cover at the rear of the oven.
Feb 21, 2010 | Baumatic B187 Electric Single Oven
Baumatic B501SS Built In Stainless steel electric single oven
If the fan is working in the main oven and there is no heat, then it will be a faulty element.
Remove the cover at rear of oven
and you will see the round element. remove it and replace with new one.
Plz rate my solution .
Thanks.
Jan 17, 2009 | Baumatic B180 Electric Single Oven
Fan oven not heating up
If fan is working then the element has probably gone
Nov 29, 2008 | Baumatic B904SS Stainless Steel Electric...
Baumatic b180 oven
The oven cabinet is likely built for several different models, which means that the case could have been built with an extra hole or two that aren't used on your model. This a normal manufacturing technique for mass-product factories. I see from the Baumatic website that several of their models do use a meat thermometer probe, but even if you bought a probe you couldn't use it your oven. Your model doesn't have the correct circuit board and control panel that the oven needs to use the probe. In any case, if you need to order parts from the manufacturer or would like a downloadable Owners Manual for your model, they are available at this website link: http://www.baumatic.co.uk/products/discontinued-models/builtinovens/B185SS-B Hope that helps! ;)
Aug 05, 2007 | Baumatic B180SS And B60SS (Bundle)...
Baumatic bt180 oven
assume a fan oven.does fan turn and oven light come on? if so problem is the circular element. if no fan and no oven light, then clock probably needs setting - this will be in instruction book. clocks sometimes go wrong but not often. if clock is faulty, a cheap repair is to bypass the clock so auto function no longer works
Apr 09, 2007 | Baumatic B180 Electric Single Oven
Baumatic B180 Electric Single Oven Logo
221 people viewed this question
Top Baumatic Ovens Experts
Marvin
Marvin
Craig Butler
Craig Butler
Pie-man
Pie-man
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
