Question about MotorGuide Electrical Supplies
Motorguide trolling motor 370 ES
We put the trolling trolling motor in the down position and now we can't get the motor to go back in the orginal position.
  • 323 Answers
SOURCE: Motorguide Trolling motor has low thrust in all five speeds
I have a 4 speed with 48 lbs of thrust. On mine, 1 through 3 will move me out pretty well, however, 4th is similar to an overdrive gear in a car or truck and is meant more for maintaining a speed with less draw on the amps.
I certainly wouldn't want to take off with it. I suspect it is the same with your 5 speed. The boat needs to be up to speed and then those two gears will maintain it, with 5th being optimal as far as low draw in amperage.
Posted on May 23, 2009
SOURCE: new MotorGuide VariMAX trolling motor does not run
The motor should work without the circuit breaker for a test. The breaker is a safety device to protect the motor and wires if something malfunctions.
Posted on Jul 15, 2009
SOURCE: wanting to install motorguide 24v trolling motor
I have installed a selectable 12/24 volt trolling motor on my boat. When in the 24 volt mode, the motor works well for about 3-4 minutes the loses all power. After about a 15-20 minute "cooling off period" the motor will work again for about 3-4 minutes. In the 12 volt mode, the motor works well all the time, only at about half the speed of the 24 volt mode. Why is my motor losing all power in the 24 volt mode?
Posted on Mar 30, 2010
SOURCE: On my standard motorguide trolling motor the
put the motor in the water and ensure that the propeller is at the rear. On the head of the unit (where the direction indicator is) push down and turn the round plastic plate (this plate has the direction indicator on it) clockwise until the direction indicator mark (mine is blue and is about one inch long) is in line with the alignment bar on the non-moveable part on the head. You will hear several "clicks" and this means that the indicator plate is clicking around to the proper directional alignment with the motor in the water.
Posted on Jun 17, 2010
  • 24 Answers
SOURCE: I have a motorguide trolling motor and the front
With the top off take the six screws out and lift the cable and gear out. Next put your foot pedal at mid position. Then make sure the motor is pointed forward and reinstall the slider gear and the six screws. Last put the top on and make sure the arrow indicator is pointing forward and thats it.
Posted on Jun 29, 2010
My motorguide x15 trolling motorjust wants to spin around .. it has a remote foot control
Define 'wants to spin around'?
The propeller motor is supposed to spin around :>)
If the whole motor unit is spinning around you need to clamp the motor stem.
For factory support, you can get that from the website.
Xi5 Trolling Motor Xi5 Wireless Trolling Motor MotorGuide
Jul 19, 2016 | MotorGuide FW71 FB Freshwater Series...
They invite you to call them if you have questions... http://www.motorguide.com/about/contact but be sure to have your serial number ready.
Jul 16, 2014 | MotorGuide Boating
Need a relay for a MotorGuide Stealth 200 troll motor - part VF4-899F11
I have a Motorguide Stealth 200B trolling motor, works perfect but getting a new boat with a new motor. Trolling motor has original manual and paperwork with it, as well as 4 blade Ninja prop and prop wrench. Has some cosmetic scratches on motor. looking for $25.00
Feb 12, 2011 | MotorGuide Standard Motor Replacement...
Wanting to install motorguide 24v trolling motor in boat will it work on just 12 v system
It should but may not run at it's intended potential. It may also run your battery down a lot quicker.
May 13, 2010 | Electrical Supplies
No owners' manual
I have a Motor Guide Trolling Motor - Bow Mount - Model-71V- 24 Volt. Problem is arrow on top of motor does not align with the direction motor is going about 100 degrees off. Any solutions? wm.513@hotmail.com
May 12, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Mar 09, 2010 | MotorGuide Standard Motor Replacement...
New MotorGuide VariMAX trolling motor does not run
May 23, 2009 | MotorGuide Electrical Supplies
Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Electrical Supplies Logo
149 people viewed this question
Top MotorGuide Electrical Supplies Experts
Craig Butler
Craig Butler
jdthefixer
Mike
Are you a MotorGuide Electrical Supply Expert? Answer questions, earn points and help others
