Whirlpool GS6NBEXR Side by Side Refrigerator Logo
Steven Tagawa Posted on Sep 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Icemaker leaking water is leaking out of the icemaker
Anonymous
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 36 Answers
  • Posted on Sep 22, 2012
Anonymous
Expert
Level 2:
New Friend:
Cheetah:
Answers
36
Questions
0
Helped
12361
Points
107
GE model GTS22KCMBRBB. Icemaker doesn't fill entirely, small cubes are produced and ejected all over freezer. Now leaking water from back of refrigerator where water line enters icemaker.
Refrigerator Leaking From Icemaker
If it's leaking from inside the freezer then it's coming from the icemaker or the drain. Lets start with the icemaker. If it's the icemaker there will likely be an ice hanging from the icemaker or just a big block of ice in the ice bin. In any case, it will be obvious.
There are a few reasons this will happen: one is the icemaker will stop turning when it gets to the fill cycle. This will happen when the gears in the icemaker break. On GE icemakers that were made before the year 2000, you can see the gears by taking off the cover on the front of the icemaker. However, if the small gear is broke you can't buy it as far as I know. I have been taking them off of junk icemakers for years. So this part may be hard to find. But if the big gear is broke replace it. Another reason icemakers leak is the fill tube is stopped up and I already discussed this earlier (replace water valve and clean out tube).
Another reason icemakers leak is that the water comes in too fast so it over fills the first cube mold. When this happens you will get a few drops of water when it fills. To fix this you have to take the icemaker out and remove the piece on the side of the icemaker. I don't know the name of it so for this we'll call it cube separator because that's what it does (most of them just snap off others have a screws). Now take silicone (RTV) and put a small amount around the first cube mold only under the cube separator. Now reinstall the cube separator and wipe off excess silicone and it shouldn't leak anymore.
Another reason that icemakers leak is that the refrigerator water valve sticks after the icemaker goes out of the fill cycle. When this happens the valve stays on and the icemaker keeps on turning, in which case, replace the refrigerator water valve.
http://www.appliancerepair.net/refrigerator-repair-1.html
Water dispenser is continually flowing & won't turn off!
Water will not stop running when filling up the tray.
Why does water drop before ice is made?
Icemaker leaking despite replacement
is the ice maker actually leaking or do you have a crack in the ice bin allowing it to leak from cubes?
How to fix a kenmore ice maker leaking water
Ice maker leaking water
2answers
Ice maker leaks or runs over Causing big chunks of ice in the drawer
It's very possible that the water inlet valve isn't cutting off completely. I had that to happen on mine.
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
