Question about Technics SL-MC7 110-Disc CD Changer
Technics SL-MC7 message "F-26"; cd changer won't work
The changer worked up until today with no problems. I have unplugged and replugged per the manual, but no luck. Any help is appreciated. Thank you.
SOURCE: Technics CD Changer SL-PD887
this is a standard plug you should be able to get from radio shack or other electronic stores. just take a picture of where the connection is on the unit with your mobile phone and show it to the sales person. cheers, mark
Posted on Sep 28, 2007
SOURCE: Need some help with the cable and spring
sc-375
Posted on Feb 27, 2009
  • 6 Answers
SOURCE: Technics 5 cd changer Model sl-pc11 will pick up
System will not play Mp3 or data format cds.
Audio cds only . Also Clean lenses with a cd lenses cleaner .
clean cd also straight away from center ,soft cloth
Check for scratches .
Posted on Mar 01, 2009
SOURCE: Looking for a drive belt
A rubber "O" Ring as a belt solved the problem.  At our local hardware store:  1 1/16 OD x 15/16 ID - 1/16" wall  $0.39!
Posted on May 21, 2009
donnydo77
SOURCE: technic sl-mc7 110-disc cd changer
The problem is likely the carriage drive belt. The player is well over 10 years old so the belt gets stretched with use. Then it is unable to transfer power for moving mechanisms.
If you feel comfortable about opening the cover using proper electrical safety procedures then you can observe what the carriage is doing upon turn on. Unplug the player, remove the cover by unscrewing four fasteners (I think, but you can easily figure it out), plug in and power up. The carriage should go through a positioning calibration and disk checking sequence (simply, it moves out of the home position, travels across the player and repositions itself to await front panel input).
Yours probably doesn't so look at the belt on the top of the carriage. If it is off the drive wheels, remove electrical power, then simply put it back on, power up, and recheck.
If the belt is spinning on the wheels and seems loose then it needs replaced. Fortunately, here is an inexpensive and attainable replacement courtesy of another FixYa poster
http://www.fixya.com/support/t1616894-looking_drive_belt
Also, a clean up and lube of the mechanisms would be a good thing to do. That takes some technical know how to clean without damaging and applying the correct lube in the right amounts to the appropriate mechanism components. Some general references are available in electronic service books or online. I should probably launch a site!
Otherwise, without knowing the conditon of other components in the drive assemply, a service manual is required to proceed with further troubleshooting specifically for the player.
Hope that the K.I.S.S. approach helps you enjoy your player again.
Posted on Aug 06, 2009
Stuck in "checking discs" mode
Obviously your device is not working and you should seek professonal assistance..
Jun 08, 2015 | Technics SL-MC7 110-Disc CD Changer
The cd changer buttons do not work
Could be a broken drive belt. Sounds like the same symptoms that mine exhibited. You will need to open it up carefully, so you don't dislodge any CDs. See previous posts here for the exact size o-ring that you can find at your local hardware store as a replacement.
Aug 03, 2014 | Technics SL-MC7 110-Disc CD Changer
Technics SL-MC-7 Multi Disk CD Player- When I put a CD in it says
What does it stay? I am (Hooch) Please get a different CD (PLayer) I have (Retired)
Nov 09, 2012 | Technics SL-MC7 110-Disc CD Changer
My Technics SL-MC7 was zapped by a power surge. I am looking for a power supply. The part number on the PS is CMKS-P3X but when I search it I get hits for a copier PS that does not look like the one I...
You will need a service manual to get the correct part number. Go online to Technics, contact customer support and technical department to see if they can provide one.
Apr 07, 2012 | Technics SL-MC7 110-Disc CD Changer
When i turn on my technics cd player model number sl-mc409 it comes accross the screen f-26 and won't do anything. what does f-26 mean
I've just bought a used changer, that shows the same error. The instuction says " unplug the changer from its outlet, replug it in an turn the changer ON again"
That doesn't help in my case.
Have you found a solution?
May 01, 2010 | Technics SL-MC400 110-Disc CD Changer
This unit has no remote or manual...was wondering if it has a random mode, and how it works? Thanks, Sean
Copy and paste this link in your internet address bar in a new tab and it will bring you to your manual.
http://the-manuals.com/technics-sl-p-770-manual/
Mar 29, 2010 | Technics SL-MC7 110-Disc CD Changer
Looking for a drive belt for a SL MC300 Technics 110 CD changer
Jan 29, 2009 | Technics SL-MC7 110-Disc CD Changer
Technics SL-MC7 110-Disc CD Changer Logo
82 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
