Question about Panasonic DMR-EZ47V DVD Recorder/VCR
No Power for Panasonic DMR-EZ47V
After watching a dvd, the unit went into it's 'usual' freeze mode then shut off. The fan works (hence the one fuse I found inside is fine). But there's no power to anything else. The clock does not turn on, nothing other then the fan. Naturally it's one month out of warranty. Is there another fuse someplace?
    Problem Solver:
  • 4 Answers
I have the same unit w/ a different problem. I called pan @ 1-800-
211-7262 and talked to John @ ext 5070. He seemed very informed and sent me a CD update which fixed my timer recording
mode. My unit is about 18 months old and the CD was sent @
no charge. Give him a call, maybe he can help.
Posted on Jan 03, 2009
Code F60 on DMR-Ez47V
Unfortunately, the F60 error means that the video processing board (digital PCB board with the HDMI port on it) has a failure. Often this happens when the capacitors on the board fail. Replacing the board or the failed components on the board is usually necessary. Some of the components may be available here: https://www.encompassparts.com/model/MSCDMREZ47V/_/_/Panasonic/DMREZ47V/DVD_RECORDER .
First you can try to reset the unit. Unplug it. Then plug it in after a few minutes. Then when you see the string of 0's, press and hold the power button. Then try to power up the unit normally. Alternatively, press and hold Stop and Hold while you power on the DMR-EZ47V.
I hope this helps. Unfortunately, I am not sure which part number applies to the part you need from the PC Boards available from the site above.
Dec 13, 2015 | Panasonic DMR-EZ47V DVD Recorder/VCR
DVD Recorder will not turn on.
You must check its power regualtor baord to get the fault. Sometimes, it may need replacement as card basis. Contact the nearest authorised center for pansonic.
Apr 15, 2012 | Panasonic DMR-EZ47V DVD Recorder/VCR
Message appears unable to decode HD channels
DMR-EZ47V and EZ48V models do not feature a built in HD digital tuner - it is only SD - hence the reason it cannot decode HD. It is a model/design limitation; not a fault.
Jan 26, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder / VCR Combo RC1 errior message how do I fix this problem
http://www2.panasonic.com/consumer-electronics/support/Video/DVD-Recorders-Players/DVD-Recorders/model.DMR-EZ47VK
http://www.retrevo.com/support/Panasonic-DMR-EZ47-DVD-Players-manual/id/2811ag420/t/2/
To get into Service Mode, first put the machine in STANDBY mode, then press the buttons ChUp OPEN/CLOSE and REC all at the same time on the front panel (Ch Up is hidden inside the AV3 input flap). Eventually the front panel display will show "SERV" (after its "HELLO" messages). Anyway, pressing [6] then [5] on the Remote Control tells me that I have an Error Code of "04" which is a Digital PCB or Communication Error (whereas an Error code of "02" means a "Defect of RAM drive"). (To exit from Service Mode, press [0] then [0] which should get you back to "SERV" and then POWER-OFF the machine).
Hopefully, your manual will display your error codes.
Perhaps the remote control is not set to the same control code as your DMR-ES40V. Codes may be set to 1, 2, or 3 on the remote by holding down the enter button and one of those number buttons for several seconds at the same time. The factory default is code 1. Try 1 first. If that doesn't work try 2. If that doesn't work try 3. If one of those codes doesn't work you may have a bad remote or a bad sensor on your machine. On DMR-ES35V models the sensor is located just to the right of center behind the black window
Jun 23, 2010 | Panasonic DMR-EZ47V DVD Recorder/VCR
Shows unformat when DVD+RW inserted
Disc need formating. While disc is in the unit press Function on the remote then arrow down to Other Function then OK button then select DVD Management then select Format disc.
Sep 21, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dmr es35v is frozen
The unit freezes due to the activation of one of its safety devices. (Press and hold [í/I, POWER] on the main unit for 10 seconds.) or unplug the power cord for more than 2 minutes.
Sep 06, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
DMR EZ47V freezes occasionally, will not play certain discs
i hope ,too.if its only months since you bought that ,avail of the warranty package that comes with it.
May 27, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR EZ48V will not go into Functions
HI I WILL LIKE TO DO A FACTORY RESET ON MY panasonic dmr-ez48v, WHAT DO I HAVE TO DO?
May 03, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic dvd/vcr DMR-EZ47V model.Code OOOOOO keeps going across.
You must manually hold in the on/off button on the machine itself (NOT on the remote) for approximately 30 seconds. This will shut the unit off. Then you can restart it.
Jan 20, 2009 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V Fuzzy horizontal line in VHS mode
Dirty heads or the recording was from a different brand VCR and the Panasonic cant get the right tracking. Try manual tracking just a little in either direction to you get the right one.
May 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
147 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
