Hi I have the swa-4000 and the speakers try to connect then just go to standby mode. I am useing a dolby 5.1 dvd and everything is set to prologic 11, and tried 0-1-3-5 and nothing, tried turning the unit on from the front (not using the remote), removed my phone.unplugged the wii and still nothing, turned both units on at exactly the same time yep you guessed it still nothing.Any Ideas? Thanks Owen
My SWA -4000 finally linked up to my unit. The "Link" light stays blue, the "Rear Chx" is gone from the display, but I still don't get sound to the speakers. I swapped with working speakers & still nothing. What am I missing? Can anyone help?My SWA -4000 finally linked up to my unit. The "Link" light stays blue, the "Rear Chx" is gone from the display, but I still don't get sound to the speakers. I swapped with working speakers & still nothing. What am I missing? Can anyone help?
AnonymousFeb 27, 2009
My system was set up and worked fine for a year. This week, we moved the whole system to the opposite side of the room. Now, we cannot get the SWA-4000 unit to connect to the main unit. Blue light blinks for a minute or so, then goes to the red standby light. The main unit intermittenly shows teh Rear Check error on-screen. 0-1-3-5 does not work. I've tried the initial setup method and the reset method in several different orders, none of which have worked. If anyone has any advice, I'd appreciate it. My system was set up and worked fine for a year. This week, we moved the whole system to the opposite side of the room. Now, we cannot get the SWA-4000 unit to connect to the main unit. Blue light blinks for a minute or so, then goes to the red standby light. The main unit intermittenly shows teh Rear Check error on-screen. 0-1-3-5 does not work. I've tried the initial setup method and the reset method in several different orders, none of which have worked. If anyone has any advice, I'd appreciate it.
You can't post conmments that contain an email address.
If it's the home theatre system i think it is that error refers to the rear speakers in which the wireless connection is either unstable or not working at all. make sure to give more info when asking for help.
With the home theater system off, press the 0-1-3-5 buttons in that order on the home theater's remote control.
Power on the home theater system.
With the wireless module on, press the [ID SET] button on the back of the wireless module for five seconds.
If your home theater continues to display rear check after you have tried the steps above, call Samsung Customer Care at 1-800-SAMSUNG (1-800-726-7864). Have your model number and serial number on hand to set up service.
swa-4000 wireless module isn't compatible with htz310. You need to buy Samsung's swa-3000 to work with your htz310. I had the same problem. It tells you in your owners manual under conectivity where it explains about hooking up a wireless module(pg.55-60). I hope this helps.
I have had the same problem with the wireless unit and thought the same, it didn't work. The way to fix this is simple. You need to do the 0, 1, 3, 5 on the remote and turn on the home theatre system on the main switch on the front panel (as I was doing this on the remote, and it was failing). The blue light should then stay illuminated. If not just switch the main on/off button again, and it shoud work.
turn the main dvd player off, and press 0,1,3,5 on your remote, then turn on the player and the rear wireless receiver at as close to the same time as you can. should then light up the blue "link" light permanently.
Test the speakers by changing source to the disc mode, and inserting a dvd into the HTS. If you get sound on all 5 speakers in DVD mode, then your speakers are still good. If you don't get sound on all 5 speakers, then press the "SURR" button to try the sound in stero, dolby, or other modes - one of these should give you sound on all 5 speakers. If you still don't get sound on all 5 speakers in dvd mode, then there is a problem with the speakers or speaker wires.
If you do get sound on all 5 speakers in disc (dvd) mode, but not when in TV mode, then take out the red and white AV cable, go buy a digital audio or SPDIF cable, and plug in the digital audio or SPDIF cable from the digital audio OUT of your TV or cable/satellite box to the "DIGITAL IN" of the HTS.
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1.
According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected.
Hope this helps.
Radiotech
