Question about Mitsubishi WS-65611 65" Rear Projection Television
Gray box filling screen after about 5 secs
Just recently fixed a red convergence problem and open fuse that failed when the convergence IC failed. (F9A04) Went through all the on-screen circuit and convergence adjustments and it was all working great for a couple hours,.....until this stupid gray box starts appearing in the middle of the screen. It now shows up after about 5secs and takes up all but about the outer 6" of the screen!!! I can make it go away by selecting and deselecting "menu", but then it comes back again after about 5 secs every time. Any idea what is causing this? Coincidentally, I was messing with the Vchip options just before this started happening. Could that be related? Have you seen this before? If you have, I'd love to know what causes it. My email is ah2wa@hughes.net
  • Paul Murphy Apr 22, 2007
    I figured it out. It was stupid oversight on my part. In the process of going through the on-screen set-ups after repairs, I inadvertently selected the on-screen captioning and that was causing the gray box. Turned off the captions and it's back to normal and working great.
    Genius:
  • 1,153 Answers
That's good it's fixed, but if more problems you can find here in the threads.
Posted on Oct 08, 2007
I have a toshiba 61h70. the tv had been shutting down after and few minutes and the red bulb was flashing also. I replaced the IC Chips and it resolved the flashing and shutting down issue. the green and...
You need to look with a meter at the resistors around the chips, they are usually gray in color with bands that denote value--a good guess is one or more were taken out by the chips--in these sets they will look fine---typical is 1.8 ohm (brown, gray, black bands).
At least one is open (bad--no reading across--like checking a fuse) and there will be several with identical color bands on them.
Let me know if I can help.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
SD TECH
Sep 16, 2010 | Toshiba 61H70 61" Rear Projection...
I have an RCA HD52W59 HDTV and my kids were watching the other day and all of a sudden the screen went bad. The sound is ok and you can still see the picture however it looks like your watching in 3D...
This is normally an easy fix. I've fixed several of these. When you get the back off of the set, there are 3 small square brown fuses located at the back left corner of the set, if looking at it from the back. They are located next to the right side of the flyback transformer( the large gray or black thing sticking up with the thick red wire coming out of the top). One of those fuses will be open and needs to be replaced, and the pins on the flyback transformer need to be resoldered on the bottom of the board. They will come loose and make the fuse blow. This will fix the problem 95% of the time on this set.
Sep 02, 2010 | RCA HD52W59 HDTV Projection Television
Philips 50p8341a - the red converges, the blue does no move. the screen is all reddish with orange lines in it. the sound is ok. took the back off and the red and blue big lights are on, but the other big...
Hi, convergence IC`s have failed, set is usually a good one, call your local tv shops and get a price to replace the "convergence IC`s ", good luck, video-tek
Jul 01, 2009 | Philips 50P8341 50" Rear Projection...
Convergence lines are SLANTED. Red line is above horizontal center on left side on screen and below horizontal center on the right side of screen. Also left of Vertical center at the top of the screen and...
did you check the six 3.5 pico fuses that are next to the ICs? They will often be open ( blown) when the ICs fail. Also check the two 5 amp IC protectors on the G board as those protect the two ICs so its possible they have blown also a 5 amp pico can be substituted for the two IC protectors.
Apr 26, 2009 | Sony KP-46WT500 46" Rear Projection...
Picture flickers in and out rapidly,gets blurry for about 5sec then looks like new for about 5sec then back again
Did you replaced 2 IC convergence as well or just 2 resitors 3.9 ohms ? if you did replaced 2 IC then you might have probelm in convergence drive it is1 of the PCB mount vertical on the left side from the rear view under part BP95-00415C you need to readjust the convergence by using your remote control just follow in the servive manual
Nov 22, 2008 | Samsung HC-P4752W 47" Rear Projection...
TV turns on only after disconnecting convergence cable to red yoke
Projection TV2_bing.gif sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung2_bing.gif, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith2_bing.gif, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash2_bing.gif focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Sep 23, 2008 | Philips 50PP9202 50" Rear Projection...
HOW TO FIX CONVERGENCE IC FAULT & HOW MUCH COST APPROX
Panasonic Flashing codes:
1: ----------------- +140 v.
2: ----------------- Low DC
3: ----------------- Convergence
4: ----------------- HHS
5: ----------------- IC 4011
6: ----------------- IC 4018
3 is convergence, either one of the two convergence ICs faulty, or something else (capacitor etc.) has blown on convergence board.
Jul 13, 2008 | Televison & Video
Convergence
check for loose connection by the convergence ic's
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
there is high voltage in this area be careful.
Jan 29, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Red Convergence on JVC AV- 65WP74
convergence amp ic bad
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 28, 2008 | JVC AV-65WP74 Rear Projection Television
Sony kp-51sw500
Everybody here seems to have basically the same problem so I will write a general fix for these Samsungs. First what you got is known as Convergence failure, A Ic or resistor, fuse or some other component has failed in the convergence circuit. So finding the service menu and trying to align the colors or spinning magnets on the CRT’s or a real bad idea of tipping a CRT or mirror would be the equitant of ripping the transmission out of your car because it had a flat tire. When the convergence fails no adjustment will bring it back, and if you do one of these stupid things then you have two problems. Now most of these Samsungs have an easily replicable board that all the convergence amplifiers are on. This can be found by removing the back and seeing if there is a board about 9 X 5 inches big and mounted to the CRT mounts, there will be 5 connector to this board. Now if your set does not have this board and instead has the two convergence Ic’s (these are about the size of a playing card and have the numbers STK392-040 on them) mount down on a board below and to the right ( this is known as the deflection board) this repair will not work for you. Instead you will need to component level repair the convergence circuit. But if you do have this separate convergence board the repair is fairly straight forward. Go to www.vancebaldwin.com or some other supplier and order BP95-00142E this is the convergence board. This board has been crossed several times through the years but this is the current version. Now once you get this board simply replace it making sure to get al the connector back in there original spot. The fire up the set and run Flash focus and for about 95% this will fix the set
Jul 21, 2007 | Samsung PCJ522R 52" Rear Projection...
Mitsubishi WS-65611 65" Rear Projection Television Logo
54 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
