Question about Whirlpool Dishwashers
My Whirlpool GU2600XTP dishwasher is making a loud grinding noise
It's so loud we cannot run it at night, or even if we are in the room. Any help would be greatly appreciated
  • 640 Answers
Somethings stuck in the shedder...bone,,plastic ,,
Posted on Dec 27, 2008
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
FGHD2433KB1 noise
Sometimes a little piece of debris such as a toothpick, chicken bone, etc. can get past the screen and make it into the pump. The wash arm pulls right off and the part holding the screen can be remove with a twist. remove the screen and then you will see the impellar in the pump whee the debris is at. Hope this helps.
Nov 05, 2017 | Frigidaire Dishwashers
Whirlpool GU1500X dishwasher motor noise got loud
Hello- Yep- it's toast. A small seal on motor shaft failed, causing water to destroy bearings. Motor is about 100$. Installation instructions available if you choose that route. Let me know if this info helps- have more if needed.- Thanks - Ed
Mar 12, 2010 | Whirlpool 24 in. GU1500XT - Multiple Color...
Loud rattling grinding noise when pump is running, no water enters the machine.
Make sure the water is turned on to the machine, if it is then it sounds like a faulty water fill valve, just replace the fill valve, they can sometimes be cleaned but I would never trust one, they can always stick in the on position later and flood your house. Check to see if the valve is geting 120v ac before replaceing the valve, if it's getting voltage and no water is flowing then the valve is bad. You will need to borrow or buy a multi-meter for this test.
Feb 01, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Our dishwasher is making a loud noise during wash cycle.
if you have a torx 20, and torx 15 screw driver, you an remove the screws from the top plate of the wash motor, and underthere youll see another t15 screw converingthe "chopper" assy, sounds as if a seed, of chicken bone, perhaps apiece of glass hasgottne down there
Jan 25, 2009 | Whirlpool GU3600XTSY Stainless Steel...
Whirlpool Duet Washer Making Loud Grinding Noise
not nesseccarrily your pump, possible you have a rear bearing going bad, which will sound as if a helicopter is coming through your laundry room. ( noisy pump can be the issue , honestly a better and cheapre problem to have) in order to determine if its apump problem you can remove the lower access panel and unplug the pump then start the spinn cycle, if it still loud the pumpms not hte issue.
Nov 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Dishwasher suddenly making a grinding noise...
Motors for tall tub whorlpools are over two hundred dollars. If its less than a year then its under warranty. You did not indicate model. If you can get back to me I'll look more in to seeing if it is feasable to repair or replace.
Jul 24, 2008 | Maytag 24 in. MDB5600A Jetclean II...
Kitchenaid Dishwasher - LOUD
i've found that if a glass or a dish breaks little pieces get caught in the grinder that is built in with the motor in time it will go away.
Jan 25, 2008 | Dishwashers
Dishwasher Making Loud High Pitched Noise.
A loud high pitch whine while running the dishwasher means that there is something caught in the chopper assembly. To get to the chopper assembly you need to take the racks out and take the pump apart from the inside of the dishwasher. The chopper assembly looks like a metal grate with holes in it. And it might not even be stuck in the grate but somewhere in the pump area due to the water being pumped out, so the best idea is to take the whole thing apart and clean everywhere. However I do not recommend doing this unless you are completely certain you will remember where the screws and gaskets go, otherwise you risk damaging your pump or house from a leak or improper installation. You have been warned.
Dec 25, 2007 | Whirlpool 24 in. DU900PCD Built-in...
Dishwashers Logo
298 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Smitty
Level 1 Expert
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
