Question about Kenmore 73952 Gas Dryer
Kenmore Gas Extra Capacity heats only on timer,not Fabric Master.
My Kenmore Extra Capacity Gas Front load Dryer heats fine on timer, but no heat when on the "Fabric Master" setting, which is as you probably know, the auto shut off at adjustable clothing dampness.
Sorry I do not have model #, I am working and my wife is home and cannot find the #'s. I assume it must have a moisture sensor which may have failed, kind of hopeing that there is seperate fuses for this fabricMaster setting, any idea's?
Thanks.
  • Kenmore Master
  • 8,220 Answers
Get some windex and clean the sensor strip located behind the filter ousing similar to this picture. Their might be something on it that is interfering with its moisture sensing ability. Check out my youtube channel about section for a link to a free dervice manual for you model. Thanks
Kenmore Gas Extra Capacity heats only on timer,not - 2011-04-10_152724_dryer-moisture-sensor_330x200-j2rqmywrjn05nkl43ld3f3b0-5-0.jpg
Dan Webster
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 30, 2017
SOURCE: kenmore heavy duty clothes dryer will not heat
most problems with dryers not heating is the thermo fuse is blown. bout 20 buck to replace it looks like a small white flat football. but most likely if it went out that means the the high temp thermostat is messed up too
Posted on Feb 07, 2008
jsrock516
  • 5911 Answers
SOURCE: kenmore, heavy duty dryer, 70 series extra capacity, not heating
The following link explains how to diagnose a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
If you require addtional assistance, please let me know. I hope this helps you diagnose your problem.
Posted on Aug 12, 2008
SOURCE: No heat in kenmore 97273100 72731 front load gas cloths dryer
check the ignitor under the door panel on the left side of the burner if it gets red when you turn the dryer on.if yes than see if gas shoots out and yes than how long it stays on if in few minutes it turns off than need thermal fuse checked so let me know up to this point if it works or not .
Posted on Nov 11, 2008
  • 1122 Answers
REMOVE THE BACK AND CHECK THE HEATER FUSE AND THE HEATING ELEMENT-MIKE
Posted on Feb 26, 2009
  • 686 Answers
SOURCE: Kenmore Elite dryer heats but does not dry
Make sure that your vent tube is not kinked or crushed behind the dryer and it all this is ok then you need to change your cycling thermostat. is it gas or electric
Posted on Mar 12, 2009
Timer has quit working and not getting heat in a Kenmore Extra Large Cap. electric dryer?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Apr 25, 2011 | Dryers
My Kenmore 60 Series Extra Capacity dryer is not heating.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 25, 2011 | Kenmore 800 7983 Dryer
Sears Kenmore super capacity plus dryer won't heat up 90 series, about 7 years old. It heats up for the first few minutes and then gets cold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 08, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
I have a front loading large capacity kenmore dryer about 6 yrs old. All of a sudden it has stopped heating. To Heatman from Hartman
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Aug 31, 2010 | Dryers
Dryer runs fine but heating unit will not ignite
heatman101
Jul 11, 2010 | Kenmore 77632 Gas Dryer
Kenmore HE4T Gas Dryer not heating
It can be tested using a mulitmeter or ohmmeter. Check for continuity. If it has no continuity, then it is defective. Hope this helped and best wishes.
Aug 29, 2009 | Kenmore HE4t 3.8 Cu. Ft. King Size...
No heat, motion, but light is on and timer ticks
Check the thermal fuse on the blower housing. It is for over heat condition and non resettable.
eric
Jun 29, 2009 | Kenmore Dryers
Dryer timer is not working and won't heat but runs fine
check the ignitor. That's a very common cause for no heat in a gas dryer. other possibilities are the coils, or it could be that you have a bad fuse in the dryer.
Dec 26, 2008 | Kenmore 73952 Gas Dryer
My dryer will not get hot
My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Dec 15, 2008 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Kenmore, heavy duty dryer, 70 series extra capacity, not heating
Aug 12, 2008 | Kenmore 63942 Dryer
Kenmore 73952 Gas Dryer Logo
128 people viewed this question
Top Kenmore Dryers Experts
Sal De
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
