Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
Tv won't turn on?
Mitsubishi wd 62725 I have no lights on or screen on? Whats the issue?
  • thunderranch Dec 27, 2008
    Same problem with a Mitsubishi VS-5055. Push the power button and it clicks once like it's going to come on but no green light on the power button and no power in the TV. I found 4 fuses inside all look good, are there more fuses than 4? Any other ideas?
    Thanks
  • 38 Answers
Your main boards are bad. The FMT, DM, & Power Supply. They are no longer available, You have to have the chasis rebuilt. Mitsubishi is rebuilding these chasis. You have to pull it without any cut wires & ship to Georgia.
tvdoctor
Posted on Mar 13, 2009
My Mitsubishi WD-62725 projection tv is blinking yellow and wont turn on why?
Check air filter on side, clean and make sure the door is seated right, if not then you will need to have tv serviced, probably internal fan issue.
Nov 27, 2011 | Mitsubishi WD-62725 62" Rear Projection...
Describe your WD-62725 62 in. Rear Projection HDTV-Ready Television Problem Green light is blinking the TV won't turn on. We've unplugged it and tried to push the reset button and the green light...
If the led light flashes green continuously, the fault came from the DM power supply. The faulty parts there are the electrolytic capacitors. Let me know if your handy with electronics and I will assist you to fix it yourself.
Jdvillanueva
Sep 16, 2011 | Mitsubishi WD-62725 62" Rear Projection...
I have a wd 62725 mitsubishi digital tv. the timer light keeps blinking fast and cant turn on the tv nor watch it what could be the problem
Try pressing power button for 10 seconds or until it turns off. Wait for 1 minute and turn it on again.
BTW, I own a 73 inch model.
Jun 22, 2011 | Mitsubishi WD-62725 62" Rear Projection...
WD 62725 timer light continusly flashes green TV won't turn on! Push reset button as soon as you release it ,it starts flashing again. Unplug TV 3-4 Hours No help.
The V26 DM repair kit from www.tvrepairworld.com will usually repair that issue. The kit contains the replacement capacitors and the step by step instructions on CD
Dec 07, 2009 | Mitsubishi WD-62725 62" Rear Projection...
My television is cutting off and takes forever to restart. the green light stays on. I have tried to reset the tv. same ol thing. replaced the lamp its not that. a big blue screen pops up before shutting...
Hello! If you haven't replaced the lamp before, I recommend you do it, since it's already 4 years old. If you already replaced it, there is a possibility you might be having a ballast issue. The ballast is the board in charge of sending all the power to the lamp so it can light up. www.discount-merchant.com/?Click=48427 These part are not that expensive and will get your TV up and running.
Nov 18, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitubishi WD 62725 - Ballast Problem??
the capacitors on the power board are the most likely the cause of the problem.
Jun 21, 2009 | Mitsubishi WD-62725 62" Rear Projection...
WD-62725 DLP TV Automatically Turns Off
Its usually your DM control board!!! it needs to be replaced!!!
Mar 29, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 constant blinking of green light
Check the lamp to see if it is damaged(this is in your owners manual for removal)If not please contact me for more info
Mar 24, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
189 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
