Hi does anyone know the device code for the lg lht854? I need it to program my dish network dvr remote control. The code is not listed in my dish network book. help thanks
SOURCE: Lg remote control
one or more of these codes will give you basic functions. no set of codes will allow you to duplicate full functionality with another controller. you will need the original remote to be able to program advanced settings.
0807, 0022, 0020, 0422, 0122, 0222, 0322, 0002, 0520, 0919, 0521, 0621, 0430, 0247, 0901, 0402, 0408, 0109, 0210, 0310, 0715
good luck
mark
SOURCE: Dish Network Remote
not every remote is capable of controlling every unit via remote codes. however, there is a set up in the manual that takes time to use. basically you will use the output from one remote to establish the same output for the new remote. its a step by step process. try a universal remote such as theater master which allows you to use a computer to control functions by assigning them to certain keys. this will be far easier. the mx700 is a capable unit for complex functions on multiple equipment and has a screen to guide you during actual use as to what each key is going to do. you will set up the specifications yourself, such as channel up or channel down, or menu or guide. you get to use already established key locations or choose from 10 along side the screen to state whatever you want, and then after its set up, those buttons do the work you programmed them to do.
good luck
mark
SOURCE: LG DVD Remote to control TV
The procedure is simple. Hold down the TV POWER button and press a number botton. Release the TV POWER button. The manuel gives the following list of codes:
LG/GoldStar....1 (predetermined), 2
Zenith...1, 3, 4
Samsung... 6, 7
Siny... 8, 9
Hitachi... 4
I have an RCA and 6 worked for me.
-olivares1900
SOURCE: panasonic quintrix tv code for lg v271 dvd/vcr combo remote
From another post, 0650 worked for me.
Panasonic TV 0051 0250 0650 0055 0162 0226 0338 0375 0637
SOURCE: lg lht854 does not work tv sound
Ok your dish network wont play through the LHT854? Which Dish network receiver do you have 211, 311, 625, 612, 722? From the owners manuel for the LHT854 it looks like you can only hook up the audio from another source by an optical cable, so how is the LHT854 hooked up to the dish network receiver?
I can't find the universal code for the lg lht854
