Question about Zenith DVT412 System
Only backround sounds play, no talking
When i put in a dvd and play, there is only the backround sounds. when i press the "sound" or "audio" buttons the screen box says "bypass" and i cannot get it to change to 3-d, pro logic, movie, or anything. just bypass. the sounds works perfect on regular tv, cds, game ps2, but not on dvds.
  • Anonymous Mar 22, 2009
    im hookin up zenith surround system to plasma and cable box can u guide me through proper installing this cause i tried and i get no voice at all HELP PLEEZE
Find the info/display key on the remote and press it,go down to the box that show head speckers it should show 2 ENG and CH2.
if not change it by pressing the down key then press ok key
Posted on Dec 06, 2007
SOURCE:
When playing a DVD music and backround audio is ok but actors have no sound (talking) any idea ??
Check the connections to the centre speaker which is where the actors voices come from.
Jan 29, 2011 | Bose 3 2 1 Series I DVD Home Entertainment...
Backround sound is fine but voices speaking are muted
I'm not sure of this system but if this was mine I would say it sounds like your playing this in a 2-Channel mode which eliminate the center channel.
you music may be set up fine, but the mode you play a dvd in may be set up for 2-channel mode. try a dolby prologic 5-channel or some other mode if you have one.
Mike
Oct 18, 2009 | Audio Players & Recorders
Problem with voice sound on DVD player FX900 Sony. Can hear audio (music) fine but voices are muted.
you have probaly changed audio tracks on the dvd,just go to menu and audio,and pick another audio track,a lot of DVDs come with more than 1 audio track (im talking the actual DVD not the player
Aug 17, 2009 | Sony DVP-FX810 Portable DVD Player
No audio
sounds like the Balance on the volume control is set to one extreme. Put it in middle. Use Control Panel - Audio - Play settings
Nov 16, 2008 | E-Machines T3256 PC Desktop
Sound
To everyone having sound trouble... there is a solution! First make sure your TV is OFF. Unplugg the 2 main cables going into the DVT 412 for 30 seconds. Then re-plugg them. Press down for a few seconds on all the BLACK tabs connecting the sound wires and release. Without a disc in the player... and the TV still OFF, turn the power on and immediatley hold the down the STOP button on the DVT412 for 5-10 seconds. Your picture, vocal and backround sound will return to normal. Feel free to make changes to the sound now! Happy tuning... GO STEELERS! LOL!
Sep 05, 2008 | Zenith DVT412 System
Sound problems
TRY PUTTING A SET OF PHONO CABLES INTO THE VCR INPUT THEN TO THE ANALOG OUT PUTS ON TOUR DVD/VCR SWITCH AMP TO VCR PRESS DIGITAL INPUT BUTTON ON FRONT OF AMP UNTILL YOU GET _ _ _ SET SOUND TO PROLOGIC 2.THIS SHOULD WORK.
HOPE THIS HELPS.
CABLE GUY.
Jun 18, 2008 | Onkyo TX-SR605 Receiver
I can hear cds and see video on my hp dvd 1040i multiformat dvd writer but I can not hear audio to the movie/dvds i have rented.
Sounds like you might have a setting that is incorrect for DVDs in the setup menu.
Grab your DVD player remote and press the SETUP button. Navigate to the audio menu. Make sure Spdif is turned off (unless you're using an optical cable for your sound), that the audio stream is set to PCM (standard for CDs) or RAW, and turn off any Dolby/Digital Dolby/Surround Sound/etc. Now play a disc.
There's also another way if your remote has an AUDIO button. While the DVD is playing, press the AUDIO button and you should see a small windo that pops up that will tell you what the audio is set to. Press the button and wait a couple of seconds between presses to see if the audio starts playing.
May 12, 2008 | Televison & Video
HDMI sound?
I had the same problem with my PS3. I have a HD cable box with HDMI out, a Sony DVD player with HDMI out. The Sony receiver STR-DG800 only has the HDMI inputs (sat/tv and dvd) and the HDMI is only a pass through port and will not decode audio.
I purchase a HDMI 4 port switch from Newegg (HS-41A0 http://www.newegg.com/Product/Product.aspx?Item=N82E16812168003&Tpk=HS-41A0) to hook up the DVD and PS3 to the DVD HDMI and switch between the DVD player and the PS3. It took me several days to figure out how to make this work with the settings on the reciver.
1 the DVD player must use the coaxial in jack for sound on the receiver.
2. the PS3 must use the optical connection on video1
3. the sound settings in the PS3 must be set to PCM
4. set the sound setting on the receiver to the following
a. on the remote press AMP button then the MENU button, next press the down arrow to you see 5- AUDIO SET - then press enter.
b.set sound decode priorty to PCM
c. next scroll down to you see digital assign - press enter
assign VID1 OPTICAL to DVD ( this allows the pcm output from the PS3 to play through the receiver), next assign DVD to COAXIAL setting DVD to DVD (this allows the digital sound to play from your DVD player).
So when you use your remote and select DVD, you can use your PS3 or DVD through the 1 DVD HDMI port.
Feb 04, 2008 | Audio Players & Recorders
Zenith DVT412 System Logo
820 people viewed this question
Top Zenith Audio Players & Recorders Experts
Damen Wong
Damen Wong
Gagan Telecom
Gagan Telecom
Level 1 Expert
Steve Allison
Steve Allison
Are you a Zenith Audio Player and Recorder Expert? Answer questions, earn points and help others
