Question about Maytag PYE2300AY Electric Dryer
Thumbing noise as the maytag gas dryer is spining
Thumping noise
When my maytag gas dryer ( M# ldg8624AAE S# 13124577MS) is spinning there is a thumping noise. Is it the belt? How is the belt on this dryer replaced? Would the noise be caused by a different problem? Would the noise be louder on start up?
  • 1 more comment
  • Anonymous Jan 19, 2009
    the dryer makes a clunking noise for a second or two after the drum stops turning
    My maytag gas dryer makes a clunking noise for a second or two after the drum stops turning....plus it's really loud when it's running....
  • ccut378 Mar 01, 2009
    I'm preparing to change the rollers to solve the thumping noise, Is it a good idea to change anything else at the same time.?
  • 640 Answers
No and its your rollers...babump babump...
Posted on Dec 30, 2008
Maytag dryer tha-thumps
It is safe to use the dryer, I don't see any foreseen future to other parts. But the idler definately is flat(tening). It should be replaced asap.
May 24, 2012 | Maytag Dryers
Thumps when running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
May 04, 2011 | Maytag Neptune MDG9700A Gas Dryer
My dryer stop working, it made a big noise and is not spining anymore, ts sounds as if it is out of place or something, and after 3 minutes it starts smelling like burn My dryer is a Maytag...
TRY SPINNING THE DRUM BY HAND. IF IT SPINS EASY, YOU HAVE A BELT BROKEN.
MOST LIKELY THE BANG WAS WHEN THE BELT BROKE. YOU NEED TO PULL THE DRYER OUT, OPEN IT UP AND REPLACE THE BELT. A SERVICE APPLIANCE REPAIR WILL NEED TO BE CALLED. - - SORRY
Feb 20, 2011 | Maytag Atlantis MDG7400AW Gas Dryer
How do i take apart the my dryer
Sounds like a drum roller bearing. When they go bad they form a flat spot and that against the drum will give a loud thump. Turn the drum by hand and you should feel the flat spot. You may have to remove the back panel to get a good look see and a repair access. Good luck.
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag neptune dryer making a thumping noise while drum turns, as if there were a tennis shoe in it, but there isn't? Ideas?
heatman101
Jan 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer makes clunking noise when it starts and stops. Also noisy during the drying cycle. It's a Maytag
May need a new blower wheel.
The wheel is mounted to the motor and if it is stripped out it will not move air past the heat element.
Have it checked before the heat element fails.
Jan 16, 2010 | LG DLE2515S Gas Dryer
Maytag dryer making a thumping sound when engaged
HI, rollers will need to be oiled,the slides will get thin and start metal to metal contact causing a noise,
thank you for using fixya,rate my answer
vijay
Oct 01, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag gas dryer makes squeeking noise
it is more likely one of the drum rollers
Dec 20, 2008 | Maytag Dryers
Neptune gas dryer
Did you check the baffles( fins inside the drum) loose of broken.
Can you turn it by hand and hear the same sound? does it turn easy or very hard...let me know I can help
krazytech
Mar 23, 2008 | Maytag Neptune MDG5500AW Gas Dryer
Pav2300aww spinning very slow,and not draining
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Nov 02, 2007 | Maytag Performa PAV2200
Maytag PYE2300AY Electric Dryer Logo
629 people viewed this question
Top Maytag Dryers Experts
Tim Whalen
Marvin
Marvin
Sal De
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
